Child Lock Philips DVP3100 DVD Player/ VCR Combo The Child Lock appears to have become engaged and there is not a Child Lock Button on the remote control supplied.The unit has DVD in that will not play and when you push the DVD button on the remote it has no effect. Is this a common problem? Is there anything I can do? The machine plays back VHS fine but as the Child Lock is on the buttons on the front of the machine do not work
  • kevinbott200 Jun 23, 2008
    The Child Lock red key appears in the front window and there is no Child Lock Button on the remote control supplied.The unit has DVD in the machine but will not play and when you push the DVD button on the remote it has no effect. If I press the open/close on the front of the unit it tells me safe in the window. Is there any answer to this problem, or do I just bin the thing & buy something else? The VHS works fine but because the Child Lock is on none the buttons on the front of the machine work.
4 Suggested Answers
SOURCE: Philips Universal Remote with Emerson VCR/DVD Combo
http://www.urc.philips.com/
US2-PM335
There you will find all needed information
Posted on Jul 05, 2008
SOURCE: rca DRC 8335 dvd/vcr combo
Call this number 877 805 0519
You need to have the model number (DRC 8335) and the serial number before you call.
Apparently this model has had a lot of problems as they have set up this number specificaly for this model. They will ask you a few questions and then they will send you another unit. You will to pay to ship it yourself. You should read the reviews on Amazon.com.
As for geting your VHS Tape out ...Hopefully when they send you a new machine they can send your tape back with it...but dont count on it.
Posted on Jul 10, 2008
  • 3 Answers
SOURCE: VHS won't play, sounds like tape will load then power shuts off.
This is similar or identical to another post, but here is an answer...
Hi, I have a solution you can try.
I had exaclty the same problem. When I tried to play a tape it would load (However, I recall I had to push hard to get the tape to be accepted, which is part of the problem) but would shut off after about 12 seconds, then when I powered back up the tape would eject. Finally I took the unit completely apart and attempted to use it with the covers off. Lo and behold, I found I could play a DVD on the unit without the unit powering off, but only if the room lights were on! If I tried to play a tape it would shut down the unit. So that led me to diagnosing the infrared loading and reel sensor circuits.
Background on that is there is an infrared LED that shines up through a plastic light pipe lens. The light from that LED (you can't see it) should shine on two photodiodes that are on either side of the tap mechanism, plus down through a gear with holes in it on to the reel sensor. When there is no tape inserted the two photodiodes will be illuminated and have about 0.2 volts across them. When a tape is installed the light will be blocked and the voltage goes up to above 2.5 volts across the diodes. You have to check this with the room lights dim as the diodes will respond to that light. When you block the light on either side of the plastic light pipe with your finger (with the unit disassembled) you should see the load motor engage, and it will back off when you take your finder away. For some reason in my unit the light from the LED was insufficient to turn on one of the diodes, and also to pulse the reel sensor when the gear turned. That could be due to component aging, or even if the light pipe started to cloud due to age, I don't know. However I was able to get the thing working...
In short I got the unit working by adding 3 resistors.
To do this you'll have to remove all the covers and remove the main PCB from the bottom chassis, unplug the power supply from the PCB, and the two ribbons going to the DVD unit. But you won't have to take off the VCR assembly, which is a pain. You just need some basic soldering skills, and remember where all those screws go...
First, I adjusted the voltage across the right-hand side load sensor diode to get the diode to switch on and off. I recall that I added 1meg across the diode. So the voltage then went from about 0.5v up to 2.8v from light to dark condition.
Second, I increased the current to the IR LED. I added a 330ohm resistor across the feeder to the LED. I recall that was R511 and was originally 220ohms. That was not quite sufficient to get the reel sensor working reliably. I didn't want to stress the LED by putting too much more current through it so looked for another idea.
Third I added 56k across the reel sensor diode to bring the voltage across it down so it would switch on and off as the reel sensor gear turned.
I now have a tape playing continuously in the unit and it seems ok for the time being. Hope that might work for you too.
Craig Townsend
Posted on May 26, 2009
How do unlock without remote
This is the child lock and can only be deactivated from the remote control!
Dec 25, 2014 | LG V-280 DVD/VCR KOMBI DVD Player / VCR...
Hello. My problem is that it keeps saying" "S A F E"
Hello -
You've accidentally switched the Child Lock feature ON.
To de-activate the Child Lock on most GoVideo DVD/VCR players, press and hold the POWER button on the GoVideo remote control for about 10 seconds. The SAFE message should disappear and you should be able to use the player again.
(To activate the Child Lock again, press and hold the POWER button for about 10 seconds)
I can't be 100% certain this will work for you as you didn't include the model number of your player. If you need further assistance, or you don't have the original GoVideo remote, please reply to me with the model number of your player.
Hope this helps.
Regards,
BElectric
Mar 20, 2011 | GoVideo Go Video DVD/VCR Combo
MY CHILD OF 3 YRS OLD ACCIDENTALLY PUT PARENTAL CONTROL ON MY DVD/VHS COMBO IS THERE ANY WAY TO UNLOCK IT
By parental control I don't know if you mean child lock. If that's the case you should be able to turn it off by pressing child lock on the remote control until off shows in the display window.
Aug 07, 2010 | GoVideo DV1140 DVD Player / VCR Combo
NEC NDT-40 DVD/VCR how to turn off "child lock"
on your remote down on the left hand side at the bottom of it its the second last button called c.lock its right above easy rpt press n hold till the little red key flashes and disapears off your unit !
Jul 07, 2010 | NEC NDT44 DVD Player/VCR
Need to unlock child lock
Child Lock
The control buttons on the front of the unit can be
switched off so that your unit can only be operated using
the remote control.
1Press C.LOCK.
and SAFE will appear in the display window.
None of the buttons on the front of your unit will
work.
If any buttons on the front of your unit are pressed
SAFE will flicker in the display window for a few
seconds.
2Press C.LOCK again to switch off the child lock.
OFF will appear in the display window.
Note
– C.LOCK is not available on the DVD mode.
Oct 28, 2009 | Philips DVP721VR DVD Player/VCR
Recieving "Locked" display message but don't know how to clear it. No reset switch or panel lock button
I have the manual and it is called "child lock" go figure it stumps us adults. Anyway...holding the power button down for approx. 8 seconds can toggle this feature on / off
Jun 18, 2008 | Apex Digital ADV3800 DVD Player/VCR
Child lock problem
Go visit the philips.com site. Search for the product and download the relevant manual. It's all free and there's a child lock reset code! :) ....
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=DVP721VR/05&scy=GB&slg=ENG&grp=HOME_ENTERTAINMENT_GR&cat=DVD_HOME_THEATER_CA&sct=DVD_COMBIS_SU
Michael
May 18, 2008 | Philips DVP721VR DVD Player/VCR
PHILIPS DVP721 COMBO
You have pressed C.LOCK (child lock) which turns off the control buttons on the front of the unit Press C.LOCK again to switch off the child lock. OFF will appear in the display window. See: http://www.p4c.philips.com/files/d/dvp721vr_05/dvp721vr_05_dfu_eng.pdf
Mar 05, 2007 | Philips DVP721VR DVD Player/VCR
Televison & Video Logo
174 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
