Question about D-Link DWL-G700AP (S2984376) 802.11g/b Wireless Access Point
I cannot access the utility utility and i cant ping it, but it is working without the security
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Sniper:
  • 81 Answers
Reset the router with the help of the manufacturer and set it up once again it will work
Posted on Feb 06, 2010
Unable to login to WAP4410N using web based administration utility after factory reset. it's reporting as invalid username or password
Please see the Reset the Default Factory Setting please read it the Detail I have a WAP4410n wireless access point, I have reset it to factory default by pressing the reset button for 30 seconds. I am able to ping its default ip 192.168.1.245 through its default ssid "ciscosb" if I configure my static ip was solved by connecting through the lan cable, and setting manually the ip to 192.168.1.0/24 network, and accessing 192.168.1.245 through web, the reason why the connecting through WiFi was working because the management web access through wireless is disabled by default
Thanks
Apr 21, 2015 | Cisco Small Business WAP4410N WirelessN...
I HAVE 20 COMPUTERS CONNECTED THROUGH LAN SYSTEM HAVING XP SERVICE PACK 2 & 3 OS. I HAVE INSTALLED NORTON 2010 ANTIVIRUS SOFTWARE ON EACH SYSTEM 10-11 MONTHS BACK. I HAVE ERP-SYSTEM IN FOXPRO FOR DOS...
Dear Walia,
We need to check weather you are getting any error message while trying to access the Network Computers..
Could you please go through the following steps and check weather you are getting any error message or Dos system getting hanged..
Disable the Norton program from the First 2 systems and try to access the Computers with Ping command...
To use the ping command please open the Command prompt and type ping [ip address of the Second system] ...
If u can access the Computers after disable the Norton program means surely it due to the issue with the Norton firewall...
In that case we need to create the New firewall rule for the Norton program to access the Specific Application
Thanks
Alexander Xavier
Nov 30, 2010 | Norton Internet Security 2010 Antivirus +...
Netgear access point cant open configuration page
Typically you should be using configuration software until a real IP can be setup and you either address it statically or turn on DHCP. As for the gateway and other information, on a wireless gateway, it should all be routed through the network. Also, I think you have to be wired to the WAP to access the config page, I don't believe it can be seen over the wireless connection as a security feature.
Aug 02, 2010 | NetGear WG602 54Mbps Wireless G Access...
I have a problem in asa5510 eth0 ip is 192.168.100.51 (inside) eth3 is static ip i can ping 4.2.2.4 from asa but i cant ping 4.2.2.4 from inside please solve this problems
It sounds like you have not allowed ICMP (ping) through the firewall, and you may need to put an access list in to allow this.
Jan 12, 2010 | Cisco ASA 5510 Firewall
Why cant i access sites on my laptop it comes up with security certificate also i cant acess my email account on google its all new to me never used a laptop before and im not sure if it comes with any...
If you cannot access any website on your laptop check if you have interent connection first. Check if your laptop is set to connect using a proxy server check the Local area connection. If your using wireless check if you wireless setting is correct. Run ping test to determine your internet connection For windows click START > RUN > type ping yahoo.com if the message is reply from then your connected check you laptop security settings. If unable to connect or request timed out contact your internet provider
Nov 20, 2009 | Google Gmail
There are websites that are blocked and I want to know how I can unblock them without getting in trouble.
in the school right!?
use online services like http://anonym.to/
or try to access the website by it's ip address, not the name.
Some firewalls just block the url, not the ip ;)
to get the ip, simply ping the website like:
C:\>ping www.facebook.com
A fazer ping para www.facebook.com [69.63.181.12] com 32 bytes de dados:
Resposta de 69.63.181.12: bytes=32 tempo=205ms TTL=244
Resposta de 69.63.181.12: bytes=32 tempo=207ms TTL=244
And then enter http://69.63.181.12
in you browser
Sep 14, 2009 | Computers & Internet
Systems cant ping each other
can u ping ur gateway? and the router too? then make sure all the system workgroup have the same name. use the same IP for all that is automatic use automatic for all, and if manual setting use manual setting for all.
Jun 17, 2009 | Linksys Business Series WAP4400N...
Will not let me on http://192.168.1.1. to config the security
go to start>>run. type in cmd and press enter.
type in ping 192.168.1.1 and press enter
you should be able to see the return message as reply from 192.168.1.1 and the time.
if you see timeout then the unit is not connected to your computer.
if it is connected then try without the http:// just the 192.168.1.1 in the brower address line.
May 01, 2009 | Computers & Internet
Cannot "ping" 192.168.1.1 (default gateway)
1) yes, referring to the router's IP address.
2) I determined the IP addresses of all my computers and tried to "ping" them but could not "ping" any of them. I can "ping" the IP address of the computer I am working from but I don't think that helps in TS this situation.
3) I'm wondering if my router is fully set up correctly. Do each of the computers have to be "saved" in the router's settings?
Jan 11, 2008 | Cat5e Unshielded Twisted-Pair Patch Cable...
ActionTech Wireless Gateway can't route Wireless to LAN
Disable firewall on all devices. All types of security sofwares should also be disabled in order to ping each devices.
Oct 07, 2007 | Actiontec GT704WG Wireless Router...
D-Link DWL-G700AP (S2984376) 802.11g/b Wireless Access Point Logo
81 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
