Question about Air Tools & Compressors
I have a two cylinder singel stage pump. It pumps up and then blows bake at the regulator. Where the tube comes from the head to the regulator. I put a new regulator on the pump.
  • tim_n_janetc Feb 13, 2010
    my problem is.... the compressor is pumping up to 130 psi, and once it shuts off it will blow off air until it drops to 115 psi at the tube thats on the regulator that comes from the head of the pump
  • jaap schildmeijer May 11, 2010
    what type of regulator. mostly there is oly tybe on bottom of it.
    1 connection to feel pressure and 1 conn to blow off after pumping
    Champion:
  • 243 Answers
Ok then now i understand the problem. it seems to me that the checkvalve is not closed after pumping checkvalve is placed between cilinder and tank. mostly a brass thing with small hose to the regulator and large screwcap. inside is spring and rubbervalve. clean seat. and valve, when worn out maybe turn valve upside down. BEFORE OPENING CHECKVALVE RELEASE PRESSURE. checkvalve makes pressure stay in tank in smal line blows of to start easier. and blows of cilinderhead, and tube to valve. cleaning is less work then reading tyis story. good luck.
Posted on Feb 13, 2010
I HAVE AN AUDI A4 TDI X REG, IVE GOT THE CYLINDER HEAD OF. WHAT IS THE HEAD BOLT TORQUE AND IS THERE A SEQUENCE TO TORQUE THEM CHEERS.
Audi A4 1.9 TDI-PD (Pumpe Duse)
Cylinder head tightening sequence:
Renew bolts!
Torque settings:
1. Stage 1 = 40 Nm
2. Stage 2 = 60 Nm
3. Stage 3 = 90 Degrees
4. Stage 4 = 90 Degrees
Please do rate my response. Thanks!
Sep 01, 2011 | Audi A4 Cars & Trucks
I have a leak on my older T30 compressor. The
The valve is a unloader valve that should shut when the compressor is running and open when the pump stops to relieve the head pressure for the next start of the compressor. if air keeps coming out long after the pump has stopped then you have a defective valve in the left hand head.
Apr 23, 2010 | Ingersoll Rand Type 30 Electric Driven Two...
How to replace head gasket on 1999 2.5 cyl ford ranger
Cylinder Head Removal
  1. Disconnect the battery ground cable
  2. Relieve the fuel pressure.
  3. Drain the cooling system. Disconnect the three way catalytic converter Loosen the water pump pulley bolts.
  4. Remove the drive belt.
  5. Remove the water pump pulley, fan and clutch assembly.
  6. Remove the intake manifolds
  7. Remove the ignition wires from the spark plugs .
  8. Remove the spark plugs; .
  9. Remove the oil level indicator tube
    • Remove the bolt.
    • Remove the oil level indicator tube.
    • Remove the EGR valve to exhaust manifold tube
    1. Remove the valve cover
    1. Remove the drive belt .
    1. Recover the A/C refrigerant; refer to Disconnect the engine control wiring from the A/C compressor
    2. Remove the A/C compressor mounting bracket (2882) with the power steering pump (3A674) attached and position out of the way.
    3. Disconnect the engine control sensor wiring connector from the generator
    4. Disconnect the (1) lower radiator hose and the (2) water pump inlet tube
    5. Remove the upper radiator hose
    6. Remove the water pump inlet tube.
      • Remove the bolts.
      • Remove the water pump inlet tube.
    7. Remove the generator.
      • Remove the bolts.
      • Remove the generator.
    8. Remove the generator mounting bracket.
      • Remove the bolts.
      • Remove the bracket.
      1. Remove the ignition wire and bracket; refer to Section 303-07A .
      1. Remove the outer timing belt cover; refer to the procedure in this section.
      1. Remove the timing chain/belt (6268); refer to Timing Drive Components—Timing Belt in this section.
      1. Remove the exhaust manifold (9430); refer to Exhaust Manifold in this section.
      1. Remove the cylinder head .
        • Remove the bolts and discard. (should get new ones)
        • Remove the cylinder head.
        • Remove the head gasket and discard.
Installation
  1. Clean all gasket mating surfaces.
  1. Install new gaskets as necessary.
    • Use new cylinder head bolts.
  1. Follow the removal procedure in reverse order.
  1. Tighten the bolts in sequence, in three stages, to 70 Nm (51 lb/ft).
    • Stage 1: Tighten all bolts to 70 Nm.
    • Stage 2: Retighten all bolts to 70 Nm.
    • Stage 3: Tighten all bolts an additional 90-100 degrees.
  2. Install generator bracket. Install bolts in four stages.
    • Stage 1: Hand-start bolt 1.
    • Stage 2: Install and tighten bolt 2.
    • Stage 3: Install and tighten bolt 3.
    • Stage 4: Tighten bolt 1.
  3. Install the A/C compressor mounting bracket. Install the bolts and the stud.
    • Tighten the M10 bolts and stud to 48 Nm (35 lb/ft).
    • Tighten the M8 bolt to 25 Nm (18 lb/ft).
Mar 10, 2010 | 1999 Ford Ranger SuperCab
900 CFM 120 PSI 8 YRS OLD BLOWS OFF RELIFE VALVE BLOWS OFF AT 150 PSI NEED A DRAWING OF REGULATOR
when the regulator switches off it will push a needle into the blowoff valve. it blows off air in cilinderhead and pipe going to checkvalve. when it is blowing off constantly please check blowoffvalve under regulator. when it keeps blowing after stopping please clean up checkvalve very often smal rustparts causes these problems. good luck.
Feb 10, 2010 | Campbell Hausfeld Single Stage Air...
My compressor fills up fine then air leaks out around the pressure/ on-off switch. I think it is coming from the copper tube coming from the head.
Those are simple compression fittings.A hydraulic repair shop should be able to get you the parts for the repair.A truck or trailer shop would have them too.
Jan 31, 2010 | Campbell Hausfeld Single Stage Air...
I have a 2 stage twin v. the motor runs and it is pumping air but it will not build any pressure.
The compressor should pump into a final check valve where the pressure switch is located. Check the condition of that valve. If the compressor itself is not pumping, the cylinder heads need to be removed and the valves in each head checked. Check the condition of the cylinder walls which should be smooth without any lengthwise grooves. Is the tank rusted through? Any leaking safety valves? Make sure you have proper oil level in the crankcase. Make sure the intake filter is clean. Check the tubes between the cylinders and the tank for leakage (splits or rust throughs). Just work from intake to tank in a progression, checking output at each point.
Oct 29, 2009 | Air Tools & Compressors
Compressor is building up pressure very slow.
It could very well be the valve plate however before you order parts take a look at the cylinders. Unplug the unit, remove the cover from crank side and turn the compressor by hand till the/a piston is at top of stroke. Examine upper cylinder for scratches /wear or failed vinyl piston ring. On oil-free compressors, dirt and grit is sucked-in from the bottom of the cylinder and causes leaks between cylinder wall and piston. If scratched, air pressure is leaking down thru cylinder wall. Failed reed valves cause a pulsation at the intake port (air seems to be pumped out the intake). If you see a model number anywhere on the pump that begins with " WL", your pump is made by Campbell Hausfeld. Parts can be ordered from www.chpower.com. other-wise order parts from sears parts. Cylinder kits are around $40. Good Luck on the repair and email if you have questions.
Apr 02, 2009 | Air Tools & Compressors
With compressor running the relief line blows off
check that the non return valve is not stuck closed
hope this helps ian
Feb 24, 2009 | Campbell Hausfeld Single Stage Air...
Small black tube found loose under top cover, blows air uncontrol
It should be a compression fitting on the bottom of the pressure switch. The tube is what supplies the air for the pressure switch. Disconnect the power before working on the unit.
If you remove the cover, you should be able to get access to it easier.
If you need more help, post a comment.
Thanks,
Tim
Jan 30, 2009 | Campbell Hausfeld Single Stage Air...
Im putting a 2 stage pump on my compressor
I would be glad to help with your project, sounds like you are a tinker-er. Most all compressors whether one or two stage are plumbed the same. The important difference is that two stage compressors are made for a higher pressure range. This means that the tank must be able to safely hold more pressure than single stage. Other considerations are that the pressure switch, safety valve, check valve, regulator and all the tubing would need to be upgraded. Finally two stage compressor takes longer to cycle because of lower volume. If you want to continue, post again listing the parts that you already have.
Nov 30, 2008 | Craftsman Air Tools & Compressors
Air Tools & Compressors Logo
67 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
