Question about RTO Automatic Transmission And Engine Oil Pressure Tester
It won't shift into overdrive by itself, i can
It won't shift into overdrive by itself, i can shift into od at 50 manually and it shifts fine. I am mechanically inclined but not real savy on transmissions. Is this a shift solenoid problem or something more.
  • 3,640 Answers
Check the kick down cable to transmission, it may be stretched out, out of adjustment, or bad. hope this helps.
Posted on May 02, 2010
1997 ford escort quit shifting onto overdrive
The OD solenoid in the transmission or the transmission control module is defective. It's also possible the torque converter clutch plates are worn. That's where over drive comes from
Aug 22, 2016 | 1997 Ford Escort
Why won't transmission shift into overdrive?
OD clutches are gone, leaks at the valve body, Or bad seal for OD.
Dec 26, 2015 | Cars & Trucks
2001 vw tdi want shift in to overdrive
check your trans fuse. some vws have a fuse for od. otherwise could be the cable out of adjustment or a blown od cluch/ tork converter. check fuses and reset computer by un hooking battery for 60 seconds
Mar 14, 2013 | 2001 Volkswagen Beetle
1997 Camry Won't shift into overdrive
look for knock sensor codes in the history on the engine computer
Aug 26, 2012 | 1997 Toyota Camry
Where are my transmission sencors my car dosent shift right can u post a picture
there inside the tranny you have to remove the pan to see them but thats not going to be your problem go buy a can of TRANSX first!! and try that if that helps then you need to plan on rebuilding your tranny or replacing it
Jan 14, 2010 | 2003 Ford Focus
99 silverado will not shift into overdrive
have a 1998 K3500 silverado 4x4 with 454 motor and 4L80E transmission. I can not get over 55 or 60 mph. At that speed the transmission down shifts from 4th (OD) to 3rd. The speedometer also drifts from about 50 to 65. If I try to speed up it will down shift to 3rd. I have replaced the VSS on the trasfer case. Is there another speed sensor somewhere? Or could it be the TPS? The truck drives and shift normal up to this point. where should i look next. thanks
Apr 13, 2009 | 1999 Chevrolet Silverado 1500
F150 transmission neutralizes when shifts to overdrive
I have that exact same truck and transmission and My Transmission did the exact same thing about a year ago and there was some kind of snap ring inside the transmission that broke. I originally thought it had to be an electirical problem because the truck shifted fine until OD or if i turned OD off. The 4r70w is a light transmission and i would suggest you have a shift kit put in and they make a heavier kit to beef it up.. Sorry its probably not the new you were looking for.
Apr 06, 2009 | 2004 Ford F150
No overdrive in mazda3s
the OD shift solenoid is malfunctioning or has failed. changing this will bring back the OD. the solenoid is located in the bottom of the transmission pan.
Mar 16, 2009 | 2005 Mazda 3
98 Ford Explorer wont move in reverse or overdrive
Probably low oil pressure in the transmission or worn clutches.
Mar 09, 2017 | 1998 Ford Explorer
1989 lincoln mark vll automatic transmission
you may have damaged the overdrive gear, a local transmission shop would be your best bet. for good troubleshoting and estimate.
Nov 10, 2008 | 1989 Lincoln Mark VII
RTO Automatic Transmission And Engine Oil Pressure Tester Logo
75 people viewed this question
Top RTO Measuring Tools & Sensors Experts
jdthefixer
Steve
Vuk B
Are you a RTO Measuring Tool and Sensor Expert? Answer questions, earn points and help others
