Question about Microsoft Windows XP Professional
I put in a CD namely Turbo Tax to do my taxes like always and it will not load. I tried another CD and it will not load either. I have windows XP Professional. How can i get it to load. I have no computer knowledge really. So I will need step by step in plain English to follow. I have run scan and fixed errors and I have3 defraged. Thank you, Carol
  • Microsoft Master
  • 11,800 Answers
Open My Computer , look for the cd unit - it will be identified as D , most likely. If when you enter the disk in it the unit name doesn't change to the name of the disk then the cd unit is dead and must be replaced. If it changes then most likely the autostart has been disabled. Leave it this way, it's an additional security feature.
To run the disk just open it after the name has changed, find a file named after the program in question that ends in .exe and launch it (double click on it).
Posted on Feb 06, 2010
Did turbo tax material for 2015 get hacked?
My understanding is not that they were hacked but people were filing for tax returns under another name and getting multiple refunds. This was discovered when doubles of the same return were coming in of the same name. Turbo Tax was not going to be accepted as a return medium but I do not if that was taken care of or not.
Feb 18, 2015 | Computers & Internet
Need insructions for inserting a Turbo Tax disc. How is it done?
Insert the CD into your cd/dvd drive on your computer (print side up/shiny side down).
Close drive.
select Run from the autoplay menu that pops up, this will install Turbo Tax on your PC.
If autoplay does not start, open my computer and right click the drive with the disc in it, select auto play, then run or install.
after insallation you should have a icon on your desktop for Turbo Tax.
Let me know If this helps
Post as a reply or comment and I'll be notified.
Thank you
Feb 05, 2011 | ASUS Computers & Internet
Microsoft Framework 3.5SP1 willnot load through my Turbo tax soft
please perform a recovery and then witout updating please install the turbo tax software
Feb 26, 2010 | Microsoft Windows Vista Ultimate Edition
HI..i cant seem to get any cd or dvds play,what do i do?
hi
your lens is getting weak, i suggest you have it cleaned if problem persists then you should have it changed
goodluck
Feb 17, 2010 | Microsoft Windows XP Home Edition
I was installing Turbo Tax 2008 and Windows XP crashed
Madam/Sir --
I none of the mode is working you need to boot from the cd to do any further steps.
inorder to boot from the cd you need to go to the bios and change the boot sequence to boot order.
It varies system to system once to you boot from the cd try to log on to recovery console and do a manual system restore by following the below steps - :
Step 1:
Boot with the windows XP CD
At "Welcome to setup screen" Press R
Select the appropriate path for windows and press enter
If it asks you for the administrator password, normaly there is not password but if you have a password type the administrator password and
press enter or just hit enter
We will now see the Prompt c:\windows>
Step 2:
cd system32\config
ren system system.old
ren software software.old
ren SAM SAM.old
ren security security.old
ren default default.old
Then type cd Type cd system~1\_resto~1 and press Enter
If you get "access denied" (Error) then
Restart the computer by type Exit and get back to recovery console
type cd \ and it will display C:\>
type cd system~1\_resto~1 and press Enter
Step 3:
Type dir
It will list you restore points
(e.g. RP1, RP2, RP3, RP4, etc...)
Select the one from the list except the last one
Say RP4
· type cd RP3 (or RP2 or RP1 or RPn) and enter
· type cd snapshot and enter
· type copy _registry_user_.default c:\windows\system32\config\default and enter
· type copy _registry_machine_security c:\windows\system32\config\security and
enter
· type copy _registry_machine_software c:\windows\system32\config\software and
enter
· type copy _registry_machine_system c:\windows\system32\config\system and enter
· type copy _registry_machine_sam c:\windows\system32\config\sam and enter
· type exit and enter
The computer restarts and the system will be
Successfully restored
Mar 20, 2009 | Microsoft Windows XP Home Edition
Unable to load program
did you get the right operating system for turbo tax...that might be for MAC...and you are using PC. check the system requirements...
second open the auto run file in cd using note pad..and you will see which directory the setup or install exe is.
or if you are upgrading to delux edition there might be upgrade command in your current version of turbo tax...good luck
Mar 13, 2009 | Computers & Internet
Windows XP Home Edition Crashed After Loading Service Pack 2
hey coco
nothing happens when you try to use the recovery console right by pressing "r".
try this again and again , sometimes it idles but its still running, if the error appears, restat again.
some corruptions maybe beyond our control and sometimes the only solution for this is to recover the inportant files you have on that HD and do a reformat...
Jan 24, 2009 | Microsoft Windows XP Home Edition
Problems installing Turbo Tax 2008 with Windows XP Home Edition
go to Microsoft update and you will see on the page everything you need to know God Bless You Greg
Dec 22, 2008 | Microsoft Windows XP Home Edition
Service Tax Return
Try Turbo Tax.com FAQ
Nov 13, 2008 | Computers & Internet
Microsoft Windows XP Professional Logo
57 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
