Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
FAN ON OUTSIDE UNIT BARELY TURNING - Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
  • Carrier Master
  • 1,151 Answers
If the proper amount of power is being delivered to the fan motor, check the capacitor. If capacitor is good replace both the motor and capacitor. If power is not being delivered to the motor, fix that problem first. Don't just replace the motor.
Hope this helps.
Posted on Feb 06, 2010
Outside unit will only run for a short amount of time with A/C before the fan stops turning and starts humming, squealing/screeching and the top of the outside unit gets hot.
The bearings are bad in the motor and after the fan runs enough it eventually gets hot, making the bearing screech and the fan locks up. Need to replace motor again. See if it has a warranty. The reason it gets hot is because the fan is what removes the heat from the coil and if the fan isn't running there is nothing to cool it off so to speak.
Apr 19, 2016 | Heating & Cooling
Inside unit comes on, outside unit buzz's fan does not come on. ac has stoped cooling
TRY TO PUSH OUTSIDE FAN WITH A SMALL STICK IF FAN IS TIRNING ALRADT THE CONTACTOR IS GOING OUT.FAN NOT TURNING STARTUP COMPASITOR IS GOING OUT
Aug 11, 2011 | Gibson Heating & Cooling
Duo-therm heat pump model # 630035-331 Unit compressor comes on but fan does not
Can you give us some more helpful information-- so we can help diagnose the problem:
Like-- what is the outside temperature?--
Have you been able to get heat out of your heat pump before, at this low of an outside temperature?
And which fan are you talking about-- the inside fan, or the outside fan?
Is the inside coil getting nice and warm-- or just barely warm?
and is there frost on the outside coil-- Can you defrost it, but shutting the unit off until the ice is cleared?
Let us know, and we'll better be able to help you to the next step.
Mack B
Jan 15, 2011 | Dometic 57915531 Air Conditioner
THE FAN IN THE OUTSIDE UNIT IS NOT WORKING. INSIDE UNIT RUNS BUT NO COOL AIR IS COMING OUT OF VENTS. IS THERE A REST BUTTON OLN THE OUTSIDE UNIT?
either the fan has went out or the capisitor for the fan is bad and needs to be replaced.if you have run the outside unit very long without the fan turning you might be replacing the compressor as well as the fan or capisitor.if the fan isnt pulling air through the cond coil outside,the compressor gets very hot very fast,and it locks down(burns up). get it looked at asap before it cost more because of other broken parts caused by the fan not working.
Sep 24, 2010 | Bryant Heating & Cooling
The fan is not turning on my outside air unit but it is still blowing hot air through the vents. There is also ice build up at the bottom of the unit. It is making a humming sound.
You will need to replace the outside fan,or condenser fan motor.
Shut unit down,before the compressor gets damaged.
Without the condensor fan the heat will not be blown to the outside air and the unit will not cool.
You may be low on freon too,have it checked.
Jan 19, 2010 | Samsung AW0603B Air Conditioner
Carrier 38CKC042300. oUTSIDE UNIT FAN WAS TURNING REAL SLOW. ac UNIT IS OFF BUT FAN TO OUTSIDE UNIT IS STILL TURNING. sHOULD NOT BE TURNING AT ALL WITH AC UNIT OFF
The outside fan may run if the unit is in defrost mode this is normal for most heat pumps it is there way of trying to keep the outside unit from staying iced over so the next time the unit runs it will have air flow through the coil and the ice will not be there to prevent air flow.
Jan 12, 2010 | Carrier 38CKC042 Air Conditioner
Outside fan not turning
Either the fan motor's brushes are wearing out, or the relay is going bad. If there is power to the motor, than the motor is faulty.
Jul 02, 2009 | Ruud Central System Air Conditioner
Fan not turning outside
Is the outside compressor running? Check the fuses in the outside disconnect by the outside condensing unit. Also check the breaker for the A/C in the main power panel.
Jul 06, 2008 | Heating & Cooling
AC unit
if its a a window unit suspect a faulty fan capacitor or bad fan motor same with outside, if it ain't moving or turning on the fan is faulty or the capacitor is faulty
Apr 18, 2008 | Bryant 463AAC008BA Air Conditioner
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
42 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
