Question about GE (PSS26MSRSS) Side by Side Refrigerator
Fridge stopped cooling and freezing and making ice all of a sudde
I noticed the fridge stopped making ice then it started getting warmer and warmer.the freezer is more like the icebox side now.dont have much money husband just started a job what can i do to fix this myself
  • 4,793 Answers
Is the unit free standing ? if so have you defrosted it using hot water.please dont.need more info ............
Posted on Feb 06, 2010
Fridge portion doesn't get cold
The defrost circuit is not working, there are usually 3 things that normally go bad, defrost timer, defrost heater, and thermal switch. Would have serviceman check it out as cooling fins on coils will cut you like a razor.
Jul 24, 2017 | Whirlpool Centralpark 25.6 Cu. Ft....
G.E. Bottom freezer evap drain keeps freezing up and ice build up stops fan so no cooling in fridge compartment. How can this be solved?
When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.Its defrost problem. Try manual defrost by unplugging the refrigerator from main power outlet for 24 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Feb 22, 2011 | Refrigerators
LG GR431SCA fridge will not cool properly and top half of freezer and ice maker section will not freeze. The bottom half of the freezer (below the shelf) freezes well, but above the shelf and the ice...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 04, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
Hear fridge/freezer running but not freezing & not cooling @ 9.
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 22, 2010 | Hotpoint HSS25GFP Side by Side...
Freezer has stopped
If it is a frost free side by side fridge/freezer, check evaporator fun in the freezer. While doing that, check is evaporator is full of ice.
if the evaporator is iced up and the fan can spin freely, you have a broken fan. Replace it.
If evaporator and the fan are iced up, you have a broken thermostat. Defrost ice with hot water.
Turn it on, if it starts to cool effectively, replace thermostat.
Oct 11, 2009 | Refrigerators
Freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
Chilled water stopped .chiller frozen in bottom of fridge
SR-32 EMB MODEL, FREEZER OK, BOTTOM NOT COOLING PROPERLY. ADVICE SETTINGS
May 28, 2008 | Refrigerators
SAMSUNG RS253BAWW NOT WORKING
the ice maker wont cycle untill the temp of the ice is around 10 degrees so if the freezer is at 15 or 20 due to some other malfunction then you will see the maker full of ice but it wont harvest and make another batch. so you could have a sensor bad, control malfunction, refrigeration issue, compressor, defrost system malfunction(you mentioned ice build up)
May 08, 2008 | Samsung RS2534 Side by Side Refrigerator
Freezer temp too high
Air must circulate in the freezer when working properly. I am guessing the recirculating vent in the freezer may be blocked which would not bring warmer air back to the coil to be cooled. As for the door, I theorize there may be too much negative pressure which pulls the door in while you were pulling out ... don't have solution yet.
Apr 01, 2008 | Samsung RB1955 Bottom Freezer Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
107 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
