Question about Estate TAWS800JQ Top Load Washer
Will not spin
Washing machine makes a spinning sound but will not spin
It will fill but not wash ,it will drain but not spin at all
  • 12 more comments
  • Anonymous Feb 24, 2008
    My washing machine will fill with water. However it is keeping a loud noise, but the machine is not agitating the clothes e.g. the machine is not spinning. After the rinse cycle the clothes also comes out totally wet. What can I do?
  • DoubleUBe Mar 23, 2008
    My top loading washer is not spinning at all. It sounds like the motor is working, but the basket does not move when washing or spinning.
  • jed608 Apr 02, 2008
    Same problem here it will complete thru the cycles except the spin unless you turn the basket til it engages. How do repair this???
  • springnow Apr 13, 2008
    My Whirlpool Ultimate 2 top-loading washing machine will not spin. When you close the top it makes a spinning sound, but it is clearly not spinning. PLEASE help, I have three boys and always a ton of laundry, and a new machine is expensive. Is there anything I can do myself?
  • Needawashnow May 17, 2008
    After placing the clothes in, and setting the dial. The washer will go through all cycles yet without spinning
  • blk1022 May 23, 2008
    my washing machine will not spin. it will fill up. then drain when outtime to.
  • Anonymous Jun 01, 2008
    Washer fills but doesn't spin
  • Rabun Jun 11, 2008
    Washing Machine will not spin. Makes humming noise as if it wants to spin but will not. Rinse and drain cycle seem to be working fine. It is a Kenmore 80 Series Top loading washer.
  • Anonymous Jun 15, 2008
    makes a noise sounds like gears in the bottom but will not spin
  • frettyp Jun 18, 2008
    washing machine fills up when time to wash, it just humms, not movement? I haven't done anything not sure what to do?
  • elisi39 Jul 20, 2008
    my machine washes but when its time to spin it just makes the noise but thats all, no spining,
  • Anonymous Jul 22, 2008
  • Anonymous Aug 31, 2008
    spin wont work
  • Anonymous Sep 13, 2008
    same problem
I haved look all solution but nada...everything was fine. Finally I've worked it out, playing my last card: the hammer..., no just a joke ..or almost! If your machine didn't work for a long time,you might have to play with mecanism of the cluth in order to free it from rust residu (resulting automaticaly to trigger an alarm (i.e.: unbalance, clogging or something like that..) which disengage everything. Just gently push it on each side until you ear a clear ting, tok or toing( do not confuse with the spring)!
Hope it will work for you as well,
Posted on Sep 15, 2008
Try this site. They have many faults that you can check.
http://www.acmehowto.com/howto/appliance/washer/diagwasher.php
Posted on Apr 26, 2008
2 Suggested Answers
  • 78 Answers
SOURCE: My washing machine will not spin or drain,only fill up with water
Couple things could be happening;
Scenario 1: Your motor is dead, or the electrical connections leading to it are chewed up and no longer send electricity to the motor. If you have a voltage tester, you should see if you are getting power to it.
Scenario 2: The safety switch that stops the motor from spinning when the lid is open is compromised.. This is possible, but less likely, as the motor would still spin in agitate mode..
Posted on Jul 12, 2010
I have FAFW3574k- Fills w/ water. Starts to run cycle but then wont spin. Pump sounds like its running but water doesnt come out. Thanks Jeromy
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 07, 2011 | Frigidaire Washing Machines
My washer was filled with water but wont spin.. makes little noise but no spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Jan 18, 2011 | Maytag PAV5157A Top Load Washer
Top load washer filling, emptying but tub not oscillating or spinning. Motor sounds like it is running fine. Colin
heatman101
Dec 27, 2010 | GE Washing Machines
No spin... makes a clacking clattery noise
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 24, 2010 | Samsung WF337AA Front Load Washer
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Washing machine wont wash or spin, just fills and drains
THE MODEL NUMBER IS USUALLY FOUND SOMEWHERE AROUND THE OPENING OF THE TUB OR ON THE LID ITSELF
Washing machine will not go thru it's spin cycle.
I just replaced the 4 rubber straps on the tub. Washed a load and it worked fine. Washed a second load and it did not spin on the rinse cycle. Checked the wiring on the switches. All OK. What do I check next. Did I mess up something around the tub ?
Nov 13, 2008 | Washing Machines
Washing machine wfm 2010 not rotate just fill and drain water
sounds like the carbon brushes in motor,Or motor has had it.
Oct 11, 2008 | Bosch Washing Machines
Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Jul 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Hitachi SF-H900TPX Washing Machine not working properly
Open machine's service panel and check whether the motor spins. Let us know with your results and we will see how could we assiste you further.
Aug 31, 2007 | Washing Machines
Estate TAWS800JQ Top Load Washer Logo
157 people viewed this question
Top Estate Washing Machines Experts
Marvin
Marvin
Justin Duby
Justin Duby
Jim Goldsmith
Jim Goldsmith
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
