Question about LG DLE2050 Dryer
Just bought a new DLE2050W electric dryer, plugged it in and got a P5 code in the time display window. Dryer not will not turn on at all now, but light still comes on inside dryer. Any ideas?
If you just bought it, why don't you file a warranty claim with your vendor or the manufacturer?
Posted on Aug 30, 2010
Dryer began cycle for a second then stopped, screen dark, wall power on
http://www.repairclinic.com/PartDetail/b200p8/LG-Dryer-Main-Control-Board/EBR36858801/1369218?modelNumber=DLE2050W&ss=a8b200d865040&mr=1
Nov 23, 2015 | LG DLE2050W 7.1 cu. ft. Front Load...
We have an LG electric dryer Model number DLE2050W and when I turn it on it starts and runs but after awhile the illuminated board goes black,but the dryer continues to run. But it will not shut off.
I have an educated guess for you. A part of each control of a washer and a dryer is a little electric "clock". Those things can fail. I sounds like you may have a timer clock that is sticking and not advancing.
These " clocks" are a part of the times, and are not sold separately.
One way to possible tell would be to put your ear to the area of the control panel where the timer is and listen. Most of those "clocks" tick, and you can often hear them, or you can watch the dial, and it should advance with a click every so often.
Be blessed.
Feb 13, 2014 | LG Dryers
Dryer displays F 70 code. How do I get it to stop?
Unplug the dryer for 30 minutes. Then reconnect the power cord to the outlet. This will reset the code temporarily. Unfortunately, the code means that the central control unit (clock) isn't communicating with the rest of the components correctly. You probably will need a new clock or dryer (depending on the warranty status). If the unit is under warranty, contact Whirlpool or the store where you bought the dryer (if it is brand new).
I wish that I had better news for you.
Jun 05, 2013 | Whirlpool Duet Steam WED9500TW 7.2 Cu. Ft....
DLE2050W
Hi Ron Arsenault
Sounds like your timer is faulty and not allowing the dryer to shut off...replace your timer, they are not re-buildable
Go to the following webpage for parts.
Note: Try to replace the timer with the same mfg,..and replace only one wire at a time to keep from getting confused.
Please take time to rate me
Bud
http://www.appliancepartspros.com/search.aspx?model=dle2050w
Oct 09, 2012 | LG DLE2050 Dryer
LG DLE2050W Dryer has power but will not run
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 26, 2011 | Dryers
Its a burnt wire past the plug in outside the dryer area ,but you can see it without taking things apart just inside the machine do i just order the wire or what caused it i bought the dryer a couple...
if the wire is burned at the plug then cut it and redo,loose connections cause wiring to burn so make sure connections are as tight as can be to avoid this.........
Feb 18, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore 110.6807 Dryer won't run properly. In diagnostic mode, everything checks out, Dryer runs and heats. Getting F2 error in normal and diagnostic modes. I disconnected P5 and checked the switches on...
One of the first things to do when a F2 error code appears is to perform a simple reset. To do this, turn the dryer off and disconnect power to the dryer. Wait 30 seconds to one minute, restore power and turn the dryer on. Choose a new dryer cycle and push "Start" to begin. If the error code does not return to the display, the reset was successful and no further action is necessary. Hope this helps.
Read more : http://www.ehow.com/info_12001824_kenmore-elite-dryer-troubleshooting-f2-error.html
Dec 06, 2010 | Kenmore Dryers
Electric Duet Dryer starts, then stops after about 10min.
Your dryer is overdue for retirement.
Jan 29, 2018 | Dryers
LG DLE2050 Dryer Logo
621 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
