Question about Canon PowerShot SD1100 IS Digital Camera
I cannot see the screen on my canon camera powershot sd1100. pressing the disp button doesnt help.
  • 50 Answers
SOURCE: I won't be able to copy photo from pc to Canon
I'm sorry, but canon's cameras only can copy the pictures which taked by them with no software edit...
But! if you use a card reader, there is a chance that camera recognize them...
I hope this helps...
Posted on Mar 24, 2009
t00nz
  • 4738 Answers
SOURCE: my canon powershot SD1100 IS camera lcd screen
You may have just accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the screen on and off to save batteries. You would then use the optical viewfinder in its place. Press the DISP button once with the camera turned on to see if that corrects the problem. If this doesn't correct it...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Posted on Jul 31, 2009
Code
  • 33 Answers
SOURCE: Need Canon Powershot SD1100 IS accessories
Battery and charger here http://astore.amazon.com/hubp0336-20/detail/B0017R6QGM
USB cable to transfer pictures to your laptop here http://cgi.ebay.com/USB-2-0-Data-Cable-for-Canon-Powershot-SD1000-SD1100-IS_W0QQitemZ390092684083QQcmdZViewItemQQptZCamera_Cables_Cords?hash=item5ad355fb33
Good luck!!
Posted on Oct 22, 2009
t00nz
  • 4738 Answers
SOURCE: Computer Not Recognizing Canon PowerShot SD1100 IS Elph A
Depending on your OS, you can download the latest driver for your system directly from Canon here. Remember to select your OS in the dropdown tab to be able to see the available downloads.
But I'd also recommend that you take this as an opportunity to consider utilizing a much safer method of downloading your pictures and videos. Please see this link, as it describes the use of a USB card reader as a much easier, faster, and less error prone way to download your photos. Note that card readers are also VERY inexpensive these days (some places less than $2 online with shipping).
Posted on Nov 15, 2009
  • 102366 Answers
SOURCE: Lens error, restart camera message
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 23, 2010
Black screen
You may have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the screen on and off to save battery power. You would then use the optical viewfinder in its place to center your pictures (that little glass peephole near the top of your camera). Try pressing the DISP button once to see if it turns the screen back on.
Jul 09, 2010 | Canon PowerShot SD1100 IS Digital Camera
Camera's screen is black, but still takes pictures.
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, try pressing the DISP button once with the camera turned on.
Dec 18, 2009 | Canon PowerShot SD1100 IS Digital Camera
View screen won't work
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Dec 05, 2009 | Canon PowerShot SD1100 IS Digital Camera
LCD screen is black in Photo mode Canon SD1100;
Press DISP. button, and repeat untill the display shows up
Aug 10, 2009 | Canon PowerShot SD1100 IS Digital Camera
My canon powershot SD1100 IS camera lcd screen isn't working. Its black when i try to view the picture and take the picture
Jul 30, 2009 | Canon PowerShot SD1100 IS Digital Camera
Black screen on canon sd1100 is
Actually, the problem was that the DISP button was pressed causing the screen to turn black to save battery life. Easy fix. Just pressed the DISP button again until the display showed what i was looking at through the view finder.
Jun 23, 2009 | Canon PowerShot SD1100 IS Digital Camera
The screen is black when in mode to take pictures
Sounds like you accidentally hit the DISP Display button on the back of your camera. This manually turns the screen on and off (you can then use the optical viewfinder to save battery power). To turn it back on, just press the DISP button one more time.
May 11, 2009 | Canon PowerShot SD1100 IS Digital Camera
It won't turn on
Did you accidentally press the DISP button on the back? This button manually turns the display on and off in order to save battery power (thus you could use your optical viewfinder to take many more pics than you normally would be able to). To turn it back on, turn on the camera and try pressing the DISP button.
Feb 01, 2009 | Canon PowerShot SD1100 IS Digital Camera
Canon PowerShot SD1100 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
