Editing dvds how can I edit dvds of church servi?e that have been finalized on another recorder using my samsung?
I HAVE A TOSHIBA DVR PLAYER THAT WON'T LET ME GET INTO THE SETUP MENU DUE TO THE PROGRAM BEING IN DR-3 AND IT WAS SET FOR DR-2 CAN'T GET BACK INTO SET-UP MODE
Posted on Feb 21, 2008
I have a Magnavox ZC320MW8 DVD recorder. I am having a devil of a time gettng it to finalize DVDs. What do I need to do?
This I believe will come down to software. The DVDs are all copy protected but by no means is it high security. I would check into some firmware update or additional software to download on to the recorder to open and finalize.
Jan 21, 2013 | Magnavox ZC320MW8 Multi-Format...
This morning while trying to copy from vhs to dvd I kept getting an on screen message OTR Pause....record. What is OTR as the tape did not copy this is model DRC832ON
OTR is one-touch recording on most of my VCR/DVD burners where you set the length of time to record from the tv. In my manual it is the Express Record feature. Press the REC button several times to advance the record time by 30 minutes. In your case it might refer to On Timed Record.
Use the COPY button on the front of the unit when the tape you want to record is in the VCR and a blank DVD is in the DVD tray. If you have the A/B Edits set, only the A/B editted sections will copy. (Copy protected tapes and DVDs can't be copied.) (Or the timed transfer described below)
Copying DVDs to VCR tapes can be done in a timed record mode. You can either use Menu > Disc > Copy Disc then press OK or Menu > Timers > Set Transfer and press OK. Then press Info to name the timed event followed by Done and OK, if desired. Press OK to highlight Copy From/To and make sure to select the correct source and destination and press OK. Next set the day and time that you want the transfer to take place (a couple of steps, press OK between them and when done). Then adjust the quality if needed and press OK. Finally highlight Keep Timer and press OK again. Make sure the correct tape and DVD are in place for the timed event.
Depending on what you set the unit for, I'd look for signs of power failures (which mess up most timed record functions). Then I'd double-check the time you set it to transfer and the A/B edits function. (A/B edits lets you grab small clips from an Indexed tape. Either index the tape by playing it and pressing the Insert A/B edit button (on the VCR/DVD, possibly on the remote) or delete A/B edits.)
I hope this helps.
Jul 23, 2010 | RCA DRC8300N DVD Recorder/VCR
Dubbed DVDs will not play
You have to use the Magnavox dual to finalize the discs, and then they should be able to play on other players. I don't have a manual for that exact recorder, but in general you would go to the Settings Menu of the DVD player --> go to Disc Edit --> and then select Finalize - the exact pathway might be a bit different on that particular recorder. Once you have finalized one of your discs, try it on another DVD player and see if it works. Good luck!
-Tha Mp3 Doctor
Feb 15, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Recorded dvds wont play in other dvd players
You have to finalize the disc. if the disc goes to the end it will finalize the disc automatically. If there is some part of the disc not used you have to do it yourself. IN DVD MODE PRESS SETUP, THEN DISC EDIT, THEN FINALIZE. FINALLY PRESS YES. That should do it.
Sep 03, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Recording error
mine was doing the same thing.and we found out that if you recorded something and dont finalize it will not recored anything else till you finalize what you recored then it works again
Jul 07, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Transferring video files to a computer for further editing
First you have to make sure they are NOT recording in VR mode.
But i would say it sounds like they have not finalized the discs.
To get them onto your PC you would need to convert/cut them with something like total video converter. If you want to edit more than just cutting you would need another program for that.
May 14, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
I can't see the dvds into any dvd player
Most DVD players can't play DVD-R or DVD-RW unless it's finalized (if you record to DVD+RW, it may work ok, but fewer DVD players work right with RW format discs).
Obviously, you need to ensure you are actually writing to the DVD (eg, will they play back on the camcorder). You should see if there's a menu for finalizing the DVDs, that might do it. There are occasionally problems with finalizing discs on some of these DVD camcorders... these discs may not be readable on any DVD player, but might still work in a PC.
The other problem is that some camcoders record in DVD-VR format, which is a special "easily edited" format for DVD camcorders only... regular DVD players don't usually support this (well, some new ones might... this is one of those "evolving standard" issues). You'll probably need a PC to read the disc, edit, convert to a conventional DVD, etc. if you're using this format.
Jan 02, 2008 | Samsung SC-DC164 DVD Camcorder
How to finalize
i have spent 2 months looking for this answer myself... and at last success! i downloaded the user manual from funai(they made this model) available here: http://www.funai-corp.com/6pdf/om/MWR10D6.pdf on page 38 it instructs you to press setup on your remote, from the drop down menu you need to select disc edit and then select finalize. this aggravated me at first because nothing happens when i hit the setup button, i powered off the unit and hit setup before the disc loaded. this step is not mentioned but is necesary. you cannot finalize a disc after it has loaded to the title menu.
Jul 25, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
Electro Med Services...
