Question about Mitsubishi WS-73513 73" Rear Projection HDTV
Its like the picture is zoomed in cutting edges off, like sports games it cuts scores off top, i can only get to seich between standard format and wide expanded its been fine uuntil now i dont kow if maybe kids did something
  • 88 Answers
Pls be sure the tv is in 16x9 format(the original tv remote) then check the cable or sat remote to be in the "normal" Cable remotes often press cable then the pound or zoom key..........Sat remotes press sat then the format key
Posted on Feb 06, 2010
I have a magnavox 47"
Is there a button on the remote marked aspect, zoom, picture size or format?
Sep 01, 2011 | Televison & Video
My Vizio LCD HDTV 32in. doesn't seem to "center" the picture on sports programs so when they have a score box in the upper left corner most of it is cut off and can't be seen. Doesn't matter how I adjust...
This is a common complaint. To be frank I don't have the exact term for your Vizio, but most recent LCD and plasma TVs have the ability to "zoom" or adjust "picture format" (those are two commonly used terms) depending on the signal source and format.
it has to do with the fact that currently there are both classic style format 4:3 signal sources as well as new HD 16:9 signal sources and on top of that it may happen that a 4:3 signal source is distributing adjusted image from a 16:9 or other signal source. Think cinema adjusted to run on classic TV - remember the vertical strip of image with two huge black areas below and above it?
Well the ZOOM or PICTURE FORMAT allows to adjust such an image so that you cut the "void" are by scalling (enlarging) the visible area to fit the whole screen.
A problem then appears when the signal source is normal and showing full screen. Then, because of the enlargement, you start missing some of the picture. Before there was nothing there because it was showing adjusted wide (cinema) format to the TV box format, but when the new TV box format gets enlarged it sure starts missing around the edges.
That's what you're seeing.
More and more TVs do not have the ability to adjust that through the TV itself. Don't ask me why, but they can only do it through the remote.
So if you have an original remote there MUST be a button there that's called ZOOM or FORMAT.
It does the trick.
Hope this helps. If it does do not forget to rate it.
Cheers,
www.coppelltvrepair.com
Oct 18, 2010 | Vizio L32 32 in. LCD HDTV
SCREEN DOES NOT SHOW ALL CONTENT? ESPECIALLY SCORES DURING SPORTING EVENTS.
All LCD televisions, including the Aquos have a ZOOM setting, allowing several different image representations.
They are done because some TV programs are in 4:3 format, some are in 16:9 format and on top of that there are some which are 16:9 pre-modified to fit 4:3 screen.
So the TV has an option to switch between several different modes and I guess you're stuck on one of them, which usually zooms in , cutting in result the outer parts of the screen.
Feb 14, 2010 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
Part of the picture is being cut off, how do i
Just called Sony about this same problem...taking your CABLE BOX remote, push the # key on the bottom right of the remote (it also says HD Zoom on mine). You can cycle through 4 or 5 zoom options...make sure you are on an HD channel to see the changes. :)
Nov 27, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Mitsubishi WS-55513 55 in. - Picture to latge for scheen
Change your Display Format (widescreen mode) . You're using ZOOM. Press FORMAT on the TV remote control to cycle through the available display formats.
Feb 09, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Full Zoom Mode Problem
Look on your remote and see if there is a "Format" button, press this to cycle through the different format options, and find one that fits.
If there is not a Format button on your remote, try looking in the setup menus and see if there is an option for formatting or zoom.
Jun 11, 2008 | Mitsubishi WS-65411 65" Rear Projection...
Cant see full picture w/ Vizio 32in HDTV
You would look for a format button on your remote.
Dish Network: bottom left the asterisk "*" button
DirecTV: top left, second from the top labelled "format"
Cable remote: look for format, zoom, or aspect ratio
Pressing this button should scroll you through the options.
Apr 16, 2008 | Vizio L32 32 in. LCD HDTV
Picture Size
Also, try adjusting the settings on your cable box, not on the TV. The usually solves the problem and will then allow you to adjust the size of the picture.
Mar 03, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
Mitsubishi WS-73513 73" Rear Projection HDTV Logo
165 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
