Question about Denon AVR-1907 Receiver
Center channel is too quiet for dialogue from PS3 movies
The receiver is hooked up to a PS3 through an optical cable on the Aux input. When playing movies through the ps3, the actor's talking gets drowned out by any surround sound noise. Even when there is no other sounds, hearing the dialogue is very difficult. I moved the center channel decibel level from 0.0 dB to +12 dB and it may have made a little difference. The surround sound mode is currently 5.1 Surround. Please let me know if you need any other information. Thank you.
Turn the other speaker decibal levels down then increse main volume until you are satisfied.
Posted on Feb 06, 2010
Only background sound, no dialogue when playing blu ray
do you have a center channel speaker hooked up? Most dialogue in movies should come from the center channel.
Feb 28, 2014 | Onkyo TX-SR605 Receiver
HOW TO INSTALL BOSE 321 SERIES THROUGH TV AND SATELITE RECEIVER
Hi! It would just be easy. Just prepare RCA cables and connect the cables to the tv and satellite receiver. Link the TV and satellite audio output to the BOSE audio input. Good luck and have a good one!
Apr 13, 2010 | Bose 3 2 1 GSX System
I can only get 2.1 sound from my Playstation3
optical cable connection in tv is only input and same in receiver it is both inputs.you need to find the right encoding in your receiver mode/set-up
Apr 21, 2009 | Sony DAV-HDX500 System
Unable to get ps3 to play when hooked to receiver
The audio inputs on the receiver need to be set to receive the Optical signal on the switch you set the ps3 to. ie Game, DVD, AUX. Each switch needs to be set to receive the audio signal coming into it. Usually on the remotes setup feature.
Feb 10, 2009 | Denon AVR588 Receiver
Denon AVR 2800 digital hookup to PS3
If your TV has an HDMI input, hook up the PS3 w/an HDMI cable to the TV. This will give you a high def picture (set up the PS3 to output the max resolution your TV displays). That will take care of the video side.
Next hook up an optical cable from the PS3 to the receiver. In the PS3 menu, you have to change the audio settings to output the sound via the optical cable.
Finally to get sound out of the receiver to the speakers, you have to setup the receiver source input. For example if you setup the PS3 to play thru "VCR" input, then you have to make sure the VCR input is setup to use either optical 1 or optical 2 for sound (whichever one you have the optical cable plugged in from the PS3).
  • I found this solution on a different site... it worked for me. I needed to change the sound settings in my ps3 to optical... then i selected dolby 5.1.... that took care of my sound.
Dec 12, 2008 | Denon AVR-2800 Receiver
Optical input from Sony PS3 Playstation.
Have you tried setting the PS3 on linear PCM output instead of bitstream? The DVR 50 may not say Dolby Digital since the optical cable goes directly from the PS3 to it but you may get the surround channel output you're looking for.
Mar 13, 2017 | Jamo DVR-50 System
Optical inputs
In short yes!
If you have two optical inputs and two equipment (PS3 and HDVD) then you shouldnt have a problem at all. Just make sure you change the mode of the receiver to TV/SAT when you want to use the HDDVD. Your problem may be the video out put.
If i was you i would do the following:
1. Get rid of all your optical cables as you won't need it.
2. If your receiver support HDMI then by default HDMI will send both video and digital sound.
3. Plug the HDMI of the PS3 to the HDMI input of the receiver, plug the HDMI of the HDDVD player into the HDMI 2 of the receiver and plug 1 HDMI cable from the receiver to the tv/monitor you have.
That is the best set up so when you play PS3 you select dvd/ld and when you watch hddvd you select tv/sat.
However having said all that the fact that you have dvd/ld suggests you actually don't have HDMI at all on the receiver(...i just checked the specs of the receiver). Which means you will need to have 2 hdmi inputs for your tv and you will need to have the 2 optical connections.
But in short yes to your question.
hope this is not too confusing.
good luck
smeags.
Feb 05, 2008 | Sony STR-DE595 Receiver
I am not getting any sound from my center speaker ... please advise.
The movie you have played seems to have been recorded in that way try playing some other movies and see what happens.
Jan 10, 2008 | Wave Audio CS801 Speaker
Hooking up a sony playstation 3 with digital optical cable
Here's one solution, if you have an audio output from your tv, you can go from the audio output on your tv to the audio input on your receiver that way anything that is playing on your tv for example, playstation 3, dvd player etc. Anything playing on your tv will have audio on your onkyo home theater system. The other thing I would try if you want to hook ps3 directly to receiver is go to your connection settings on your ps3 menu and change your connection method to digital optical cable.
Dec 27, 2007 | Onkyo HT-S790S System
Center Channel Audio
There are probably several sound settings on the receiver :
Dolby surround , stereo, theater, SACD etc.
Try another setting other than the one you have
Dec 16, 2007 | Yamaha RX-V661 Receiver
Denon AVR-1907 Receiver Logo
728 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
