Question about Remington Optics 9X63 Premier Series Binoculars - 8000 w/ FREE UPS
I have a pair of Remington Premier 9x63 binoculars that give a double image. I need to get them fixed. Can you help me?
  • 112 Answers
Sounds like the optics have shifted and needs alignment...cost is usually 35 plus shipping good luck larry@reichinstruments.com
Posted on Feb 14, 2010
    Brigadier General:
  • 3,006 Answers
The yoke which connects the eyepieces and keeps them aligned as the focus changes is damaged. If you can easily move one eyepiece back and forth with respect to the other then the yoke has broken, if not then it's bent, probably cracked and waiting to break.This is probably the most common fault on most binoculars, and it's usually uneconomic to repair except on really high priced and fully supported models such as some Nikons and Leicas (amongst others). Remington are not a specialist binocular manufacturer; most likely they just buy them from a Chinese factory and have their badging stuck on so although they're not especially cheap binoculars (although they are very cheap for 9 x 63's) I doubt very much that spare parts are available for them.
If bent, the yoke *might* be able to be straightened, but it will be weakened and the alignment afterwards will rarely be spot-on. If broken, then the yoke must be replaced professionally but the repair often costs more than replacing the binoculars with new. The break cannot be simply glued: the contact area is too small to carry the loads it has to carry, and you also usually find that the yoke bent before breaking anyway so you then have all the same problems as you do with a bent yoke.
The fragile nature of the yoke is why binoculars must always be inserted into their case with the objective lenses facing down; this avoids shock loads on the delicate yoke assembly.
If you have a telescope and binocular repair specialist located conveniently to you then it may worth getting an estimate for repairs, but there are few these days with the skills to do so. But if you're in the UK, then visit or phone Kay Optical for advice. If in north America, then contact Optics Planet for advice as they shift a lot of Remington stock.
I hope that you've found my posting to be of use and in return ask only that you take a moment to rate my answer.
Posted on Feb 13, 2010
I have a pair of Plastimo military binoculars which have been fine up to now, but suddenly, despite being able to focus using the two eye piece controls, I cannot get anything other than a double image, no...
Hello - I never had Plastimo before but I have had a similar problem with double vision on a very similar looking pair of binoculars.
The eye piece movement just re-aligns eye focus differences , a double image usually means one of the lenses has moved inside the main tube. (usually from a knock/fall etc)
Can you rotate either one of the tubes ? On my pair I had to rotate anti-clockwide and found a prism inside that had slipped after a fall -
Close one eye and try to gauge which side is the best side -- Ray
Feb 05, 2011 | Plastimo Optics
Our grandson dropped our binoculars and now we have a double image.
This is a common problem with binoculars. One of the prisms has shifted and the two sides are therefore no longer in optical alignment (collimation). Unfortunately, fixing this requires a degree of expertise, which may cost more than you will want to spend. I have often taken old binoculars apart or found external adjustments that allowed me to realign them, but I have ruined a few pair this way. Not a good idea if they are valuable.
If you can find the paperwork and they are still in warranty, you might try to get Canon to repair them, but I suspect that they will say they have suffered an accident, not a manufacturing fault.
Nov 18, 2010 | Canon IS Binocular
Nikon Action 10x50 6.5degree-seeing double image,did not do this until recently. Can it be fixed?
The double image is caused by the most common killer-fault on almost all binoculars: the yoke assembly which the eyepieces is mounted on has either bent or broken.
The only fix is to replace the yoke assembly: unbending it is not accurate enough and usually breaks it, gluing is no good as the contact surfaces are far too small for the adhesive to carry the mechanical loads, and usually results in a yoke which still needs unbending...
It's not a cheap fix and is only worth doing on really expensive models: given that you can buy the same pair again for less than £60 in the USA and around £100 in the UK then it's a no-brainer as the new model will cost far less than the repairs.
Sorry to disappoint you, but some faults just cannot be economically repaired. I hope that my answer has still been of use to you and that you take a moment to rate my answer.
May 01, 2010 | Nikon Optics
We gave our son a pair of Bushnell Binoculars, and we are having difficulty getting a good image. We have carefully followed the instructions with no luck. The problem is that we are getting a double...
The binoculars need collimation. The two sides are supposed to be parallel, if they are not you see two heads on horses, two footballs, two baseball bats etc. Check the binoculars for any external signs of damage. Are the front housings sitting properly in the body, is one of them not straight? If there is no obvious signs then you will need to take them to someone who can rebuild them for you. Usually the place where you bought them should be able to help you with a repair centre.
Dec 30, 2009 | Bushnell Falcon 13-3450 (10x50) Binocular
Double image, cannot adjust
Well, you can't, but a repair guy can. The body actually splits into two to access the collimation screws. Not a job for the faint hearted as the plastic has a tendency to crack if you don't prise them apart at the right spot.
Dec 27, 2009 | Nikon Travelite III (8x23) Binocular
I am seeing a double image whel I look through my binocular.
Most binoculars should allow you to grip the two sides and pull them closer together to fit the distance between your eyes.. Have you tried this?
What you should see is the two images come together to form one.
If you have tried this already and you still get the two images then it's possible the model is just too wide for your eyes.. If they're new you could try return them for another type that fit better..
If this works for you then here are the instructions for setting up the binoculars to give you the best result for your eyesight..
This is more common than you would think.. Here's how to set up a pair of binoculars to suit yourself.
Any good binocular will be able to do this and the reason is to allow you to adjust them for the difference in strenght between your two eyes. I wear glasses myself and sometimes contact lenses so it's good to be able to quickly adjust them.
1. turn the binoculars over so you are looking at the underside.
2. on the eyepieces can you see on one eye(usually the right eye) a little plus - minus marking. The eyepiece should be able to rotate a little to each side of this marking.
3. Set the rotating eyepiece to the middle setting.
4. Look through the binoculars as normal and bring the two sides together until you form the two circles that you see into one.
5. Pick an object app 10 meters away.
6 Presuming that the adjustable eyepiece is on the right hand side then close your right eye, look at the middle distance object you chose with your left eye and use the central focusing knob/wheel in the middle to bring your left eyepiece into focus.
7. Now, close your left eye and adjust the rotating right hand eyepiece while looking at the same object until your right eyepiece is in focus.
8. The binoculars should now be set for the differences in strenght of your eyes and you can use the middle focus control as normal.
Most binoculars have a soft rubber eyepiece that can be folded back for people who wear glasses but I, like most people I know who wear glasses, find it horribly uncomfortable.
This method allows you to set them for yourself and if someone else uses your binoculars you can quickly reset them for you.
Hope this helps...
- Oh yeah, sorry, forgot to mention.. This set up is so you can use them without wearing your glasses.. Much more comfortable!!
Oct 20, 2009 | Sharper Image Optics
See two images at higher power.
Your binoculars are out of collimation. That means that the optical path needs to be aligned. Binoculars are designed so that the focus point of each barrel is the same over long and as short as possible distances. Binoculars that are properly aligned will still show a double image if you attempt to focus at something close that is too close for the models design. However this is not the same for long distances. The image at a long distance must not be doubled.
If they are under warranty and you haven't damaged them by dropping etc send them for repair to the manufacturer or ask the retailer where to send them.
If you are going to pay to have them fixed get a quote first. Binoculars that are of the zoom variety are not well thought of among binocular officionados as the quality of image degrades at higher magnification. For the price of repair you may be able to source a higher quality non zoom binocular.
Jul 20, 2009 | Sharper Image Spion (AR001)
Double vision
take it into an outdoor shop and they can check the mirror alignment, seems that it may have "altered' itself
Jun 22, 2009 | Zeiss Classic B/GA 524013 Binocular
Double image - one above the other
yes , they have to be realigned, if you want call me and we can talk further 5088331232...larry
Apr 22, 2009 | Steiner Tasco Offshore 54 Binoculars
Binoculars
Gently squeeze the two barrells together (they should be able able to do it easily). I believe it's called the interpupilar distance. If you can't get the binocs to do it, take them back to where you bought them.
I admit I bought a cheap pair on the internet on which the barrels do move, but they don't get close enough to totally eliminate the double vision thing. No wonder I got them at a decent price.
Jun 22, 2008 | Steiner Genuine G.I. 7 x 50 Binoculrs with...
Remington Optics 9X63 Premier Series Binoculars - 8000 w/ FREE UPS Logo
208 people viewed this question
Top Remington Optics Experts
ray gallant
Danny Kuhlmann
solver2010
Are you a Remington Optic Expert? Answer questions, earn points and help others
