Question about Frigidaire Freezers
Freezer is not freezing any more model#FFC13K1AW0 serial#WB23846088
  • Frigidaire Master
  • 19,396 Answers
Hi.
To start, this freezer has no automated defrost. The first thing to try is a complete defrost. This must be done as regular maintenance once a year or so.
Empty the freezer, disconnect power cord, and leave it to defrost for about 24 hours.
Defrost must be done even if there is no ice or cool inside the freezer.
If that will fix the problem , than it means that the poor cooling was caused by ice building up on condenser coil. That is called defrost problem.
If that does not fix the problem, and the freezer is still not cooling after full defrost, then the problem is the temperature control, a scarce refrigerant gas pressure, or a compressor issue.
A good thing thing to be tested would gas pressure. All the user can do is looking for visible leaks, or damage to coils and pipes. Gas pressure reading must be done by a technician using professional equipment.
The easiest thing to test among parts is the temperature control.
This is the thermostat located on one side of the fridge. The thermostat is tested disconnecting power, removing the thermostat, and reading Ohms on the part contacts. At room there must be zero Ohms or very low impedance. If the temperature control circuit is open, then the part must be replaced.
In a similar way you can also test the controller (PS426525 - Part 30 on diag 1) this is also a thermal control device integrating a relay. The control will start and stop the compressor, and must be closed at room.
When the controller is faulty, the compressor will not start.
If the compressor is slow to start, then the starting capacitor may need replacement. In this case the compressor may not start at all, or have a slow start that will impair cooling function.
Finally, if all other parts are good, then the compressor motor may be faulty. In that case the compressor will not start at all, or will usually make noise.
Most of this faults can only be fixed by an on-site technician. The compressor is also covered by a special warranty lasing many years.
For this reasons, the best thing to do would be contacting Frigidaire to find out how much of the repair they can cover.
Here all parts and diagrams.
Regards.
Posted on Feb 06, 2010
Why isn't it freezing?
Hello friend, thanks for your inquiry!
From the information you have provided your Frigidaire freezer is no longer freezing and all the lights are on. You may need to perform a reset on your freezer and you can do that by disconnecting the power cord for at least ten minutes. If this does not start your freezer would you be able to provide me with your model number? You can locate the model number on your serial tag which can be found on the inside wall. I look forward to assisting your further. -Matt
Feb 28, 2016 | Frigidaire Freezers
Kenmore Model 10654613300 Freezer over freezing
In the freezer side there is a panel in the back. behind the panel are the evaporators. over the evaporators are heaters you will find one of then broken from water dropping on it the bottom one was broken on mine. put a fan to the freezer and thaw it out. get the model and serial numbers and look on ebay.com. or there is a place called http://www.repairclinic.com/
These are not hard to change but above all UNPLUG THE FRIG OR THEY MAY PUT YOU IN ONE.
Hope this helps.
Sep 21, 2014 | Kenmore Elite Side By Side Refrigerator -...
I have a kenmore upright freezer model 253.9280415 serial WB10612377 that shuts it self off
You would have to find a local refrigerator repair shop or find a new part from the manufacturer. You may be able to find a service manual online someplace and reset the computer. You could try unpluging the power and waiting five min, plug back in and see if that works.
Jun 06, 2014 | Kenmore Freezers
Causes freezer compressor freeze up
with such limited information, I can only answer generic. Most of the time it is because the evaporator fan(s) are not running or the evaporator is frozen over. With further info such as model, serial, or more details on behaviors, I could probably helps some further.
Aug 05, 2013 | Delfield Freezers
Freezer not freezing
If you can hear the motor running it could be the thermostat that has gone or if there is no noise at all it could be the motor that has died, a good easy fix ( sometimes works ) is to turn the freezer off leave it for 24 hours with no power then try turning it on again.
ThanksTalkAppliance.co.uk
Apr 22, 2012 | Kenmore Freezer 20.6 cu. ft. Upright...
My Kenmore upright freezer, serial #WB95125779, model #253.9284213, is not freezing my food? All of my frozen food was spoiled. Can anybody give me any solutions?
You may need freon, or your compressor has died. Either way you need a service guy. Sears has their own service people. It may be under warranty.
Apr 22, 2012 | Kenmore 14.1 cu. ft. / 399 liter Upright...
I need an Imperial freezer gasket for model UL5000ECW4 serial WB01811931.
I have the same model number and my freezer completely defrosted and won' freeze. I assume I have a leek and all the freon (correct spelling) has leaked out any suggestions? My email is bjkirkland@gmail.com.
Mar 02, 2011 | Freezers
Kenmore upright freezer Model # C675-287140J Serial # 08462430AJ water is freezing in bottom tray and building up.
defrost drain may be plugged.shut freezer off,melt ice with blowdryer,and unplug drain.drain probably located behind inner back wall beneath coils.
Mar 08, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer has difficulty shutting off
Check the relay located on the compressor on the back of the unit. Sounds like the relay is not completely shutting down the compressor. Almost like it is still allowing electrical currents to get to the compressor
Feb 20, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezers Logo
61 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
