Question about Emerson EV787 VHS VCR
Vcr won't rewind
I have an emerson EWV 404. When I push rewind it turns off. Then I turn it on and it ejects tape. At times it won't except tape at all. It plays and records fine, just won't rewind or fast forward. I was going to clean the mode switch but i can't find it.
thank-you
FATS9
Kimi
  • 277 Answers
SOURCE: The unit will fast forward and rewind, but won't play
This is a problem with the process called 'tape loading' - pulling the tape loop out of the cassette and wrapping it around the spinning video drum, engaging the capstan and pinch roller and reel rotation. Check all the belts above and below the deck. Belts can appear to be firm but if they do not return immediately to their relaxed length when you stretch them 25%, they will need to be replaced. With the cover off, observe the behavior when you hit play. (You may need to put a piece of cardboard over the cassette to block external light from interfering with the start/end tape sensors). Assuming this is a basic VCR (no instant start features), you should see: 1. The video head drum begins to spin. 2. the roller guides move smoothly on the tracks, wind the tape around the drum, and stop snuggly pressed against the 'V-stopper' at the end of the tracks. 3. The pinch roller moves into position and presses the tape against the capstan. 4. The tape begins to move and is wound up by the takeup reel. 5. The picture and sound appear on the TV. With a 'rapid or quick start' (or it may be called something else) transport, the tape moves to a half-loaded position when the cassette is inserted. This is at an intermediate position partially pulled out of the cassette but not wrapped around the drum. On VCRs with a real-time counter and/or index search capabilities, the tape will be in contact with the control head. With an 'instant start' transport, the tape will fully load around the spinning drum when the cassette is inserted but the capstan will not engage and no tension will be applied to the tape until you press PLAY or REC. (After about 5 minutes, the drum will stop and it may unload to the half loaded or unloaded position.) Note that for VCRs with a real-time counter and/or index search capabilities, the tape must be in contact with the control head (but not the video heads) for all relevant modes. These VCRs (which include many modern units) must therefore pull the tape at least partly out of the cassette. In all cases, the completion of the sequence results in approximately the same mechanical configuration during PLAY. Several likely possibilities when it shuts down: 1. Everything occurs as above, picture and sound appear for a few seconds, but then the VCR unloads the tape, ejects the cassette, goes into REW mode, stops, or shuts off. Two common causes: The takeup reel does not turn and tape spills into the machine. This is sensed by the microcontroller which aborts record or play and attempts to save your valuable cassette. Most likely cause: old/dirty idler tire. As a test, turn the idler tire inside-out. The fresh surface will now work well enough to confirm this diagnosis and will continue working long enough for your replacement idler tire to arrive. See the section: "General guide to VCR cleaning and rubber parts replacement". The takeup reel is turning properly but
Posted on Nov 22, 2005
radar001
  • 1051 Answers
SOURCE: VCR tape is stuck - will not rewind or eject.
There schould be a release buuton on the rear of the machine. It's usually recessed and may be difficult to see. Press this with the yip if a ballpoint pen and extract the tape. If the tape is wrapped around the record/playback heads your only option is to remove the top cover and manually remove the tape. Sounds difficult but if you take your time it's not too bad a job.
Posted on Mar 08, 2010
Testimonial: "Thank you! - no button - took the top off. I depressed a lever next to the tape switched the VCR back on and pressed the eject button - it worked!"
techman
  • 3130 Answers
SOURCE: Tape is stuck in VCR- Fast rewind and forward
ok sorry man gotta step in Its not the pinch roller as you claimed that picks up the slack on the tape its the pinch roller that would cause wow and flutter in audio on a tape on slower speeds what picks up tape slack is the takeup reel. Theres many reasons why the takeup reel dosent pick up the tape and there fore the unit "eats the tape" it could be a gear assy or even on older units could simply be the rubber drive wheel. Or a belt problem and I know these JVC s really well and its a combo the drive belt as well as the pickup gear assy.
Posted on Apr 04, 2006
mattozan
  • 555 Answers
SOURCE: Stuck video tape
Is the tape protection guard rotated upward (and the tape engaged with the heads)?
Posted on Aug 13, 2008
phil_frye
  • 295 Answers
SOURCE: loads tape then stops - won't play rewind fast
Way to go. Usually if you use anisotropic Alcohol with a few Q-tips works well I've found.
Try cleaning the other tap path items like the capstan that the pinch roller get's pushed up to also with this Alcohol. The cleaner the better the tape goes through. Much better picture.
Blessings,
A/V Media Guy
Posted on Nov 19, 2009
Testimonial: "saved the deck - I was going to replace it! fast response too! Thanks"
Stuck video tape
Aug 13, 2008 | Emerson EWV403 VHS VCR
I have Emerson TV/ VCR / Dvd. The tape rewinds,but just before time to stop/eject, the power turns off. Is it safe for me to squirt WD40 into the slot when there's no tape inside? Or should I just buy a...
Do not put wd40 into the unit as it could attack plastic parts making it worse. You can squirt Servisol Video 40 without harm to the device. However i would have a look inside by taking the top cover off and see if you can see any damage or objects stuck etc. If you can find the VCR's mode switch that might need a clean with Servisol.
Apr 07, 2011 | Emerson Televison & Video
Tape stuck in vcr. when you press the eject button vcr starts to work but shtuts off the power Model number DVR-3034N. I have only taken the front and back covers off. Turned slanted roller untill the...
It sounds like the tape is jammed in the vcr, remove the top cover of the machine this will expose the tape. If the tape is spewed in the mechanical section and around the video head, get a pair of scissors and start cutting the tape and carefully remove all tape particles, when all tape debris has been removed, plug in vcr turn on and eject. If the tape looks good, you may have a loading basket problem, bad idler ***. or broken drive belt. "Lets hope for the best"
Jan 25, 2011 | Emerson Televison & Video
My grandson was watching an old VHS tape and pushed something. Now, all I see when I turn the t.v. on is "counter00.00" and then the t.v. shuts off in about 3 seconds. I have lost the owners manual. HELP!
Left up the VCR tape gate,see,if the tape still in there?Yes,unplug,10 mins.replug the Tv and push the tape forward botton.Let the tape go forward about 5 sec. eject the tape take out.Grandson probally rewind the same seen to many times,causing power power shotdown mode.
Aug 09, 2010 | Symphonic SC3813 13 in. TV/VCR Combo
Tape ejects after playing for about 30 minutes
it could be dirty pinch rollers causing the tapes to tighten and be ejected. try fast forarding the tape to the end and rewinding. if this does not cure the problem, run a wet cleaner tape through.
Mar 05, 2010 | Emerson EWV403 VHS VCR
Tv turns on but will not play tape that is in the machine. after
some times you can hit the power and eject button about the same time and it will eject the tape try this a couple of times to see what happens if that does not work then you can take the back off after you unplug from outlet for ac there is a belt that is black that should look like a long ruberband turn the pullys one way or the other to eject the tape manualy.
Feb 11, 2009 | Emerson EWC1303 13 in. TV/VCR Combo
We have an emerson vcr model ewv 401a. It is new only used twice in the past yera or so. Put in tape, tape was stuck we were able to remove the tape but the vcr keeps turning self off after about10 seconds...
there is an acrylic post inside that directs a light beam to several different places so when the light beam is broken then it tells other parts that the tape is loaded this could be broken off or if the tape broke off inside a piece could be wrapped around a capstan or drive post causing the machine to think it is at the end of the tape and to turn itself off.
Dec 15, 2008 | Stanley 100 ft. Tape Measure, FatMax
Emerson EWR20V4
this is more of a belt problem, look for a worned belt.
May 16, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Tape stuck in VCR, won't eject.
depending on th einternal design of the vcr. look for the loading/unloading mech, by finding the blak rubber belt that is looped from the motor to a pully. now turn it one way. it may thak 25 to 50 complete rotations of the belt. try turning both ways, one will load & 1 will unlaod. good luck.
Jan 24, 2007 | Emerson EWV601 S-VHS VCR
Emerson EV787 VHS VCR Logo
1,390 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
