Yes, install new drivers, ****.
I tried everything everyone told me.....messed up my computer.....so...I tried something of my own and it worked... My model is a w3050 I downloaded software (Ethernet drivers,audio driver etc.)from a link on one of these forums at Nvidia.com. The audio drivers were messed up with this download no matter how many times I uninstalled and re-installed. So I researched my original audio drivers for this model. Found out they were Realtec Ac'97 audio drivers so uninstalled the Nvidia audio drivers only and left everything else that was Nvidia. Then went tohttp://www.realtek.com.tw/downloads/down... The Realtec website looked for Ac'97 audio drivers found em and downloaded...simple ;)
J'ai un problème avec mon pc je n'arrive plus a lire et à écouter le son de mon pc
I have the same PC , same problem and I can not find the correct driver :-( CAn anyone help ?
You need an applications and drivers disc, you can order it from the manufacturer or try digging through the manufacturers website to get the ones you need.
This problem may be the sound card driver.
First u check the system properties in the control panel whether the sound card is properly installed. if you find any yellow signal on the left side it means that the drivers not installed correctly. first try to install the correct drivers. if you installed the sound card driver correctly the system properties displays no yellow signal.
SOURCE: RELOADED XP
Try getting drivers for the divices that are not working Most drivers I get are on the web site driverguide.com but you need to register and it is free
SOURCE: my sound
This site has EVERY Driver for your Compaq. http://xp4compaq.webs.com
In fact its dedicated solely to Compaq SR2150NX Model. I hope I helped..
The sound idea is usually solved this way: You need to open START- Then CONTROL PANEL-SYSTEM- Click HARDWARE Tab-
Then Open Device Manager. Scroll to Audio Device (If You see a Yellow ?
mark go to #2) Now Click & Delete Driver or Uninstall. RESTART PC-
(Drivers Usually Reload + You Get Sound Back) #2: You have NO Driver
(or Incorrect Driver) Click Update Driver + Go Online to Get New Driver.
hi ahamed
yes there is a yellow signal . i have tried re installing drivers from xp disc but no joy . do i have to download a new driver ?
ddd
i no cna instal drivers to my emachines t6592 and my hard drive is h, I want but my hard drive is c
HI
NOW I HAVE NO SOUND , MEDIA PLAYER SAYES NO AUDIO HARDWARE AVAILBLE ,SOUND AND AUDIO DEVICE PROPERITIES STATES NO AUDIO DEVICE , THE C MEDIA AC97 AUDIO DEVICE PROPERTIES DEVICE STATUS STATES DEVICE CANNOT START CODE 10 .
MY PC IS A SYSTEMAX AMD ATHLON XP 1473MHZ . GIGABYTE TECHNOLOGY MOTHERBOARD. PCI BUS 0 DEVICE 17 FUNCTION 5 .CMEDIA AC97 AUDIO DEVICE VER 5.12.1.50
HOPE THIS INFO CAN HELP YOU TO HELP ME
I tried everything every one told me.....messed up my computer.....so...I tried something of my own and it worked... My model is a w3050 I downloaded software from a link on one of these forums at Nvidia.com. The audio drivers were messed up with this download no matter how many times I uninstalled and re-installed. So I researched my original audio drivers for this model. Found out they were Realtech Ac'97 audio drivers so uninstalled the Nvidia audio drivers only and left everything else that was Nvidia. Then went tohttp://www.realtek.com.tw/downloads/down... The Realtech website looked for Ac'97 audio drivers found em and downloaded...simple ;)
