Question about LG (GCE-8527B) CD-RW Burner
The device did not read dvd
The device did not read Any DVD (Device is LG GCE 8527B )
    Guru:
  • 239 Answers
It's a cd driver & writer not a dvd player
So get yourself a DVD RW drive
Hmm take ASUS or SOny
Posted on Feb 06, 2010
Download driver gh22np21
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
select properties general troubleshoot, select driver click to reinstall drivers click update driver
hope this helps
http://download.cnet.com/lg-gce-8520b-firmware/3000-2122_4-10203021.html
The new firmware offers enhanced recording speed of some CD-R media on your LG GCE-8520B CD-R/CD-RW
Aug 10, 2011 | LG GH22NP21 DVD-Writer - Internal...
RFGSER
make sure that the cdrw/dvd is getting enough power test all leads that are attached to the cd-rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your CD/DVD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd/dvdrw drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
May 08, 2011 | LG (GCE-8527B) CD-RW Burner
Ive bought a dvd rom rw cge-8527b but when i put a cd in (dvd movie or dvd rom nothing happens the disc turn and stop no sign of it the icon stays the same
make sure that the cd rw is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cd rw then plug them back in this will activate found new hardware wizard
hope this helps or
you might have to uninstall then restart your computer then reinstall your cd rom or uninstall the driver then reinstall for this device
also
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives right click you can you will have options to update driver roll back driver select properties general troubleshoot select driver click to reinstall drivers click update driver uninstall then reinstall
you need only do the registry check if you cant see the drive/s in windows explorer/my computer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Mar 27, 2011 | LG (GCE-8527B) CD-RW Burner
I purchased LG SATA DVD writer after installing it, unable to read any CD or DVD. Its detected in device manager but cant ready media. tried to SATA cable & SATA port, still same. Another thing i...
Can you hear it "spinning" the media? If not, you have a "defective" unit (motors or bearings).
If it spins, but nothing is read, then you have a "defective" unit (dead laser).
Take it back to where you bought it, and get them to test it, to prove that it is "bad", and then for them to replace it.
> in Hardware details it shows HL-DT-ST DVD RAM GH24NS50 SCSI CDROM Device.
Normal for most SATA devices.
> it shows as HT-DT-ST CD-RW GCE-8526B ATA device.
Perfectly normal.
Feb 21, 2011 | LG GH24NS50 DVDRAM Burner
HL-DT-ST CD-RW GCE-8527B is problem can't working
If the drive is not working then it will need to be replaced. Check to see if the door opens & lights come on after loading a disc. If they do then it is more likely a driver issue. You can try to uninstall the drive in device manager and then reboot to see if Windows identifies the drive and installs the driver. If the drive is dead then replace with a compatible drive. Hope this helps.
Jul 08, 2009 | ASUS DVD-E616P DVD Drive
No read any cds
Hi there, as per your information the device working well. But not read CDs. So i suggest you install a CD/DVD Reader or rewriter software.
Because, with out the software your DVD/CD device can't able to read CDs. You can use Nero Express software for solving your problem.
Thanks & waiting for your feedback.
Mar 18, 2009 | LG (GCE-8527B) CD-RW Burner
I need a driver
have you tried device manager and right clicking to update driver and allowing internet access
Mar 15, 2009 | LG (GCE-8527B) CD-RW Burner
No read no write
One possible source of difficulty is there are different blanks for "slow" recorders (1x - 4x), "high speed" recorders (4x-10x), "ultra speed" recorders (12x-24x), and "ultra speed +" recorders. The disc manufacturers had to change the way the discs were made to accommodate each successive improvement, so older recorders don't work with the newer disks.
It is possible for some 4x-capable "slow" drives to use the "fast" blanks with a firmware upgrade, but there is no advantage to doing so since you're still limited to 4x recording (unless, of course, you're unable to find "slow" CD-RW blanks).
CD-RW discs for the faster drives are labeled with a "High Speed", "Ultra Speed", or "Ultra Speed +" logos. Make sure you buy the right blanks for your drive.
Jan 15, 2009 | LG (GCE-8527B) CD-RW Burner
LG GCE 8520B CD-RW
It could be that it needs a lens cleaner or realigning, but try this and see if it cures it, sometimes it works. If it still persists go to my computer>properties>hardware tab>device manager and go down the list to cd/dvd drives, click on the '+' and right click on your listed drive and select uninstall. restart the notebook and then the drive will be re installed with drivers automatically.
Apr 15, 2007 | LG GCE 8520B CD-RW Burner
GCE 8527B
it seems that your cd rw burner has reached it's MTBF, or it might have even over lasted it, I myself experienced such problems and the only way to solve it is to replace its read write assembly as a package, it is available at all LG computer peripherials store.
Jan 15, 2007 | LG (GCE-8527B) CD-RW Burner
LG (GCE-8527B) CD-RW Burner Logo
152 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
