Question about HP LaserJet 4 plus Printer
I HAVETHE PRINTER SET ON LETTER SIZE BUT WHEN I GO TO PRINT THE PRINTER DEFAULTS ( "LEGAL TRAY EMPTY."
    Genius:
  • 1,018 Answers
More than likely, the print data coming at the printer contains either a PJL Command for legal size paper or a Printer Control Code for legal.
Check the page setup on the application to make sure it is set correctly.
You can also do a "print to file" off of the printer properties page. Name the file something simple like "Legal Error" Windows will assign a ".prn" file extension to the name.
Then send the fie to me at don.farr@hotmail.com. I can verify the error is in the data file and if necessary correct it for you.
Don
Posted on Feb 06, 2010
Load legal message
You will need to go into the printer's settings and change the tray 2 paper size back to letter. This printer is an oldie and does not rely on the paper tray to tell it what size paper the tray contains. Another possibility is that If your program is sending a print job (which will over-ride the printers settings) that somehow is set up as legal, then you will need to either abort or cancel the print job on the printer or install a legal size piece of paper into tray #1 (the manual feed tray) and then press GO or CONTINUE on the printer to complete the print job!
Good Luck!
Rich Lilja
Oct 28, 2013 | HP LaserJet 4 plus Printer
When I print a "letter" size document I have to push the green button to make it print. If it is legal it prints automatically to the legal tray.
Obviosly your magazine (Place of taking paper) of the printer is set to legal. The lights is lighting, couse the printer is telling you: You want me to print on letter, but I don have any letter, so please confirm that you want me to print on legal.
In order to avoid this set the printer to all types of paper available.
Jan 29, 2013 | HP LaserJet P2015dn Printer
My Lexmark T640 does not seem to recognize paper "tray 2". I want to print legal, but it only prints from tray 1. How can I get the printer to recognize and use tray 2 so I can print legal AND letter?
2 things
1st make sure the paper guides are set correctly on the trays for legal make sure it's exactly on legal or it put the tray into universal mode. (To clarfiy the guides in the back which allow you to put legal in the tray.)
2nd Go into menu and then to paper menu and adjust/ confirm the settings for tray 1 and 2. Based on your question tray 1 is letter and tray 2 is legal, so make sure both of the tray size and type are set correct.
Oct 21, 2010 | Lexmark T640 Laser Printer
My HP 4100N printer often automatically selects to print from tray 1 (the manual feed), when I want to print from tray 2 (the automatic feed). How do I set the default tray?
HP Laser Jet 4100 HP Not pulling paper from Tray 2
Action: The 4100 will look at tray 1 first then tray 2 If tray 1 is empty it will pull from tray 2 if the papersize matches the job otherwise back to tray 1 and ask for the paper. Your machine likely thinks the paper in tray 2 is not the size you want. For instance you have LETTER in tray2 But the machine thinks it is legal. The LJ 4100 detects the paper size in tray 2 automatically. If you print a configuration page: MENU them INFORMATION then ITEM then CONFIGURATION PAGE then SELECT. The page will print and show what size paper the machine thinks is in Tray 2 if it says LEGAL and you have LETTER you need to Check The Paper Backstop in TRAY 2. The back stop sets the length of the paper if it is not at Letter (8 1/2 x 11) the machine will not detect LETTER. Even if it just a little bit off or between positions.
If it is set at LETTER then you may have bad switches in the machine that are operated by the tray. Or the arms on the tray that operate the switches are not moving properly. You will find the arms on the rt, side of the tray and feel them change position when you move the backstop.
Hope this helps helps. Please keep us updated and remember to rate this answer. TF
Oct 18, 2010 | HP LaserJet 4100n Printer
Settings in HP Printer LJ 4100.
Hope this helps.
Mar 23, 2009 | HP LaserJet 4100n Printer
Want to print on legal size paper from Tray 1 (top) as default
print menu - config and verify paper is being sensed correctly. If paper size in tray is not set correctly printer will ask where to print from
Feb 12, 2009 | Lexmark T640 Laser Printer
Paper tray?
Two possible solutions;
1) Check the settings in the printer driver for the default tray. The other user could very well have changed them and set tray 1 as the default tray.
2) Check the paper size settings in the paper tray. Pull tray 2 out and check the paper guides. Make sure the paper guide in the front and left of the paper tray are set for the correct media type (letter, legal, etc.)
The printer reads the tabs in the back of the papertray to identify the paper size. If someone moved it while loading paper the printer identifies another paper size and defaults into the tray that has the size of paper required to print.
Hope this solves your problem.
Nov 19, 2008 | HP LaserJet 4100n Printer
Tray output
You should configure TRAY 1 as Legal only.
and Tray 2 as plain letter.
Specially when you specify from what tray/paper type to print.
This can be easily configured from the Printer Properties within the Printers and Faxes section of the Control Panel.
Jan 26, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Keep getting "11 load letter in tray 1" message
Are the print jobs being sent to printer all the same page size?
Are they all print jobs sent letter page size and your printers cassettes are set for A4 or something?
Your printer is asking for letter size paper, because any paper it has is not set to letter  and document that it is trying to print has been sent as that size.
Check what options you have on print driver on pc as far as Tray defaults, paper type and size settings
Check printer settings via its keypad as to tray defaults, paper size set for each tray and paper type, some printers have paper size switchs on their trays too.
Oct 26, 2007 | IBM Network Printer 12 Laser
HP LaserJet 4 plus Printer Logo
73 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
