Question about Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch
I have a hotpoint fridge with water on the door. Even with the temp turned to its warmest setting the water like freezes up. I unplug the unit and open the frezzer door wait 30-45 min and it clears up. If you time it right you will get a small piece of ice that purges in the line
    Sergeant:
    Champion:
  • 263 Answers
Very common problem. Usually it is caused by a bad insulation of the door. Try turning it off for 72 hours. That way not only the insulation of the door will thaw, it will also dry out. It should last longer, when it's not wet. The easiest solution is to replace the door, but it's not reasonable pricewise.
Hotpoint refrigerator repair orange county, ca
Posted on Feb 06, 2010
Everything freezes
Make sure it is level.
Nov 25, 2013 | Hotpoint Refrigerators
Whirlpool french door refrigerator
What is your model number? With the model number I can look up the components that may be causing this problem. Example would be a defective thermister or thermostat control. Thanks Sea Breeze
Apr 24, 2013 | Refrigerators
Hotpoint RLA51 fridge keeps freezing up
A fridge makes cold air in the freezer only and blows it into the fridge throu a little air door with a small fan, one of your temerature adjustments will open and close this little door and the other ajustment (the thrmostate) will turn on and off the compressor at what ever temperature you have it set for. if the little door is closed to much the cold air can not get into the fridge fast enough to make the temperature cold enough to turn of the thermostate. This will cause items to freeze near the air door as the air comming out of it will be something like -20C. to fix this it sometimes helps to open this little door more... something like "freezer temp warmer" and also to turn the "fridge temp warmer". if that does not do it, then the thermostate may be faulty, to test it slowly turn it down untill the fridge turns off, if it only turns off at the off position, replace it. also one last thing , sometimes the airdoor can frost up and restrict the air from blowing into the fridge, so you can unplug the fridge and leave the doors open for the weekend and let everything thaw out. then set all the controls for normal and plug back in. Make sure you do not leave the unit plugged in or sometimes the little door light can get so hot it may melt the plastic lining in the fridge.
Feb 08, 2013 | Refrigerators
Fridge freezer hotpoint fridge wont get cold!! and the freezer is not freezing
Empty the freezer & fridge, turn the unit off, leave the door open for 24 hours, to let all the ice melt off the coils, then turn it back on & make SURE the doors are closed well.... You will know that this was the problem in about 3 hours, when the freezer is back at normal temp.....
Be sure to put some towels in front of the unit, and also inside the freezer when it is off, as you may have more water (melted ice) than the drain pan can handle.....
Jul 13, 2011 | Refrigerators
The refridgerator side is too cold- i have it set to the warmest setting and everything is still freezing in the fridge. Any help would be great thanks.
try to adjust on a warmest setting then observe unit if not replace your thermostat means the sensor is deffective iinstall new thermostat.
Feb 05, 2011 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
Hotpoint RLA30s Freezing!
check the ptc overload relay it could have stuck and is supplying power to the compressor all the time even if the thermostat is off,its on the compressor body where the wires go to the compressor
May 11, 2010 | Hotpoint RLA30 Compact Refrigerator
Fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Mar 11, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
Ice in my fridge
Without seeing this I can't tell you a price or exact fault but the first free thing to try that could likely fix it. unplug the unit from the power and leave both the doors open for 48hrs so the unit is 100% defrosted then try again. cheers.
May 31, 2009 | Hotpoint RFA60 Bottom Freezer Refrigerator
Fridge freezes food even though its set at warmest temp
what it sounds like is either your damper is stuck or your damper motor is bad it will probably be in the top left of your refrigerator side
Dec 30, 2008 | Jenn-Air JFC2089H Bottom Freezer French...
Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch Logo
136 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
