Question about Master Bilt Commercial Freezer DD-66CG
We have a Master-Bilt DC8 Ice Cream Storage freezer. It starts gradually warming about three weeks after we defrost it. Defrosting fixes it for a short time. We've had a repairman who replaced a part and added refrigerant but the problem still persists. Any suggestions?
    President:
  • 1,515 Answers
Hi, It sounds to as though you may have a small refrigerant leak in the system. I wish I knew the part he replaced, it must have been in the refrigerant circuit to have to add freon, or it was low in the beginning. They are sealed systems and only require freon if they develop a leak. I think what I would recommend at this point is for them to check the charge again. If it is low, by E.P.A. law's, they need to add dye to locate and repair leaks the second time around, if it is low only. Maybe you can let me know what part was replaced, that would be somewhat helpful.
Sincerely,
Shastalaker7
PS How are you defrosting this box? Most low temperature boxes have a defrost clock on them. Yours may not.
Posted on Feb 06, 2010
ICE BUILDS UP IN LIEBHERR FREEZER
Needs a new defrost timer. If ice builds up then you are not defrosting. If you are not defrosting then the t-stat will read the ice and think it is down to temp and shut off.
Mar 23, 2014 | Freezers
The freezer works fine, but it ices up on the inside.
If the ice is clear and hard, the issue is a leak during defrost (if it has such a cycle)
If the ice looks like snow, replace the door gasket(s).
Jun 15, 2011 | Master Bilt Freezer Single Door Ice Cream...
Everything in our freezer is frozen solid except for the ice cream which is soft and mushy, the freezer is only about 3-4 years old and we checked and it is turned up to the coldest setting, any ideas what...
If this is a self defrosting model make sure that you don't have frost build up on the back wall of the freezer causing the air not to circulate like it should. If you do have frost build up other items will eventually start thawing as well. If this is the case you have a defrost problem.
If this is not a self defrosting model then make sure it does not need defrosting.
You normally will notice ice cream being soft before you notice other things thawing.
Also make sure the door is shutting good and you may try putting the ice cream in a different location.
Jul 20, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Walk In Freezer won't start up
It sounds like your drain heater is the type that should be deadended. Power makes the circuit between the material it is made of. It is to just be warm, not hot. I've not seen this in some time but that's how they used to work.
Generally speaking, walk-in freezers have bunches of controls.
http://www.master-bilt.com/pdfs/io_manuals/condensing_unit_io.pdf
go to this web site as it will cover the M series unit. Do this first and if you are still having a problem, get back to me.
Jan 20, 2010 | Master Bilt Commercial Freezer 860808
I have the same problem
Most probably defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer. This can also be caused by the drain hole being blocked by ice. You MUST remove all ice in drain under freezer coil. Use turkey baster to squirt hot water into hole and use hairdryer to defrost.
Aug 24, 2009 | Freezers
Freezer very cold, no air going into fridge it warm ANY SUGESTION
hi there,
check the blower fan inside evaporator,there is fuse on the back side of your refrigerator for cooling fan,check on this using multi tester if busted replace fuse.
Jul 06, 2009 | Maytag 15 cu. ft. / 425 liter Upright...
FREEZER TOO WARM
Hi, Are you seeing ice or frost? Is frost building up on the freezer back wall? I can help you, just need to be clear.
Thanks
Vic
May 24, 2009 | Freezers
Upright freezer
sounds like your freezer isn't maintaining a constant (cold) temp. A variation from cold to warm would cause your problems. Normal opening the door and looking for the ice cream over and over would cause a gradual increase in glacier activity in the freezer. I don't know of any quick easy fix-but wait, how about checking the door gasket? Get a piece of paper, close the door on it, move the paper all around the door, testing to see if you can pull it out easily (bad gasket), or does the paper not want to come out?(good gasket) If the gasket seems ok, it may be time to retire the global ice cream warming freezer countrycurt0
Aug 04, 2008 | Freezers
Master Bilt Commercial Freezer DD-66CG Logo
110 people viewed this question
Top Master Bilt Freezers Experts
Dennis Boxerman
Gil Shultz
Charles T Nevin
Charles T Nevin
Are you a Master Bilt Freezer Expert? Answer questions, earn points and help others
