Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Vegetables freeze in drawers and on shelves why ?
  • 52 Answers
Try checking your tempt control, you may have it on the LOWEST setting. Put on recommended setting, that should resolve the problem. If not, then the thermostat is malfunctioning, then that will need to be replaced.
Posted on Feb 07, 2010
I am getting water on my shelves which freeze in the back and under my vegetable drawer i get puddles of water.
Sounds like the water drain in the evaporator case is plugged causing the 'defrost' water to overflow instead of going down under the unit where it is evaporated.
You may be able to blow out the plug if you can get to the drain end under the unit. on in the lower part of the fridge.
Jul 23, 2014 | Electrolux Refrigerators
Our amana side by side works well, in fact too well. It freezes salad greens in the vegetable drawers and now freezes things like yogurt on the open lower shelves too. We've turned dow the settings to...
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Apr 07, 2011 | Amana SXD524VW Side by Side Refrigerator
Vegetables freezing in crisper drawer
This is an issue with the convection system in the refrigerator, while the cold air trapped withing the crisper drawer remains and the temperature of the moisture in the area drops below the freezing point, the water content acts as a cover and thereafter enables the vegetables to freeze. A slight rearrangement of the utensils within the refrigerator solved the problem
Jan 21, 2011 | GE GSS22SGM Side by Side Refrigerator
Water under vegetable drawers
Look on the top back of ur fridge. in the middle of it u should see a resetacaple. if it is full of water and over flowing there is ur problem. then u have to check about ur cooling unith if not change the setting of u fridge let the frizzer frezze and the fridge stay a bit warmer
Nov 19, 2009 | Bosch KGU32124 Bottom Freezer Refrigerator
Vegetables freeze in the vegetable drawer. Freezer is on lowest setting.
Make sure that you realise that 1 degree is colder than 2 degrees and therefore a setting of 3 - 5 degrees might solve your problem
Apr 14, 2009 | Refrigerators
Vegetable draw is freezing the vegetables
if you pull out the vegetable drawer, you will notice a vent on the left side in the back. get some tape ( I use aluminum tape ) and cover the bottom half of the vent, that will help keep your vegetables from freezing. that should solve your problem. Joe
Dec 12, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Admiral Side by Side Fridge is warm at top, cold at bottom
CHECK TO SEE IF THE EVAPORATOR FAN MOTOR IS RUNNING, ITS IN THE BACK OF THE FREEZER SIDE, MOTOR MAY BE BAD OR SOMETHING COULD BE BLOCKING IT...
Feb 07, 2008 | Admiral 26 cu. ft. Side-By-Side...
GE side-by-side Refrigerator too cold, runs all the time
If the problem is in the vegetable crisper drawer primarily, Google "WR49X10045". This is a simple fix kit for a design flaw.
Nov 28, 2007 | Refrigerators
Fridge bottom has water under vegetable drawers
Make sure the door is closing properly, that nothing is trapped in the door seal, and that the seal isn't torn or distorted. The seals are there to stop moist external air getting in then dropping its load of moisture as it cools. A.
May 16, 2007 | Bosch KGU32124 Bottom Freezer Refrigerator
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
252 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
