Question about Kohler - Toilet - Two-piece - Highline - K3427-RA-G9
Kohler Highline Class V tech toilet. Bowl does not fill. Why? What can I do to fix it?
  • Bob Korsu
    Bob Korsu May 11, 2010
    Is water running into tank then directly into bowl or is there no water running?
  • 349 Answers
Check tank for fill line running from fill valve to overflow tube. It will be a 1/4 " line that allows the tank and bowl to fill. It should be connected from fill valve and connected at the top of overflow by a clip or hanger.
Check out the water level in tank to make sure it is filling to line on overflow or within 5/8" to top of overflow pipe.
Posted on May 29, 2010
Kohler 4634aa is running and I've already changed the flapper, could it be the valve?
Yes it could be valve just cause you changed the flapper doesnt mean that you stop water from filling in tank the valve that shuts water of can still be running the water will go down the bowl fill tube that is were the black tube goes that connects to the top of white pipe the simple whey to find out is just push down on black float and water will stop add in tank let off black ball and water should stop or just lift up on float arm and water should stop bend float arm if necessary.
Jun 28, 2014 | Kohler Highline - Comfort Height Two-Piece...
Brand new kohler highline k 11499 96. Tank fills fine, but when I flush the toilet it lets about one fourth, if that, Water out of tank into bowl before canister float slams shut???
most modern flappers(what you call a canister float if i understand you correctly) have some type of adjustment feature which controls this.(like maybe rotating the flapper one way or the other) the old fashioned way was to take up the slack in the chain attached to the flapper so that when someone pushes the handle the flapper is pulled higher. make & model # or a pic would help me say w/certainty how yours works. just text me here if you need anything else and good luck:)
Jul 27, 2011 | Kohler Bath Highline K-11492-96 Biscuit...
The bowl will not hold water. This is the second toilet we tried because Kohler thought it may be a faulty tank but same problem. Everything works correctly in the tank but after flushing the bowl will...
the tube that goes from the fill valve to the fill tube may not be installed correctly. the water must be going in the tube and not the tank. also it is a water conserving toilet so it uses less water also it is a comfort height toilet and to make it taller the bowl is extended so the water may seem even more shallow.
Jan 18, 2011 | Kohler Highline - Comfort Height Two-Piece...
Last toilet flush did not take. (It was a bowel movement, but not excessive toilet paper.) Bowl fills, water does not go down. I have plunged entire bowl filled at high level twice. It feels like air...
Sorry to read about your problem, I hope this helps you out.
if the plunging does not work, you will need to have a rotor-Rutter , their is a clog down the line
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 28, 2010 | Kohler - Toilet - Two-piece - Highline -...
I have a Kohler Highline toilet that sputters
Did you try to lubricate with something waterproof to stop the squeak? How about grease? Petroleum jelly, something. Or how about a weight on the high side to balance it out as it goes up. A lead sinker or a penny. Hope this helps.
May 25, 2010 | Kohler Highline - Comfort Height Two-Piece...
BRand new elongated Cimarron shoots water out of bowl durng flush
Is the fill line in the tank loose? Does it just shoot water into the tank itself? I had this issue until I realized the while fill tube is supposed to be pushed into the black cylinder/small plastic tube in the middle of the stopper assembly. After i pushed the line into the tube, the bowl would always only fill a little bit. Now it fills almost a 3rd of the way up the bowl and doesn't bubble during flushes.
May 09, 2010 | Kohler Cimarron Comfort Height elongated...
My toilet want fill up in the bowl..eventhough the water is filling up in the tank
Problem is the flapper make sure it did not fall off the mounting clips or it may need to be replaced
Nov 05, 2009 | Kohler Cimarron Comfort Height elongated...
Kohler - Toilet - Two-piece - Highline - K3427-RA-G9 Logo
736 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
