Kenwood stereo intergrated amplifier a-76
I have an old hifi that i woul like to power up again it gives great sound but im having a few problems getting the instruction manual any ideas ive been trying kenwood but they dont have the manual due to the age of the product
  • Ononono May 03, 2008
    Hi there!! I also searched but it is quite hard to get! I didn't succeed sofar...
    But I have another problem as well: only the signals from the cd player (DP-76) and tuner (T-76L) produce sound. To be more precise only those two ports in work. If I connect the cassette-deck to either ports it does work. Can anyone tell me if this is a common problem and most important can it be fixed??
    Thank you very much for you're reactions!
    Onno.
    p.s. if I get my hands on any manuals I'll send 'm trough!!
  • vioden2006 Jan 04, 2009
    nu am telecomanda
The only tricks to power up again are this:
Amp to Equalizer : Use the "Connector " of the Amplifier - IN and OUT and connect them to the Line IN and Line Out of the equalizer;
All modules: Use the system control cable like in serie, for example the lowest connects to the above and from thsi one to the other above and so on;
Regarding Power: both CD, Deck and Tunner have different colors to connect to the Amplifier power source, you can't miss it;
Audio Cables, just follow the IN and OUT with correct colors and you are done!
Rgds,
TrepaTrepa
Posted on May 17, 2009
What is the wattage output of the kenwood ka 728 integrated amp?
Specifications Power output: 130 watts per channel into 8? (stereo)
Frequency response: 20Hz to 20kHz
Total harmonic distortion: 0.007%
Input sensitivity: 0.2mV (MC), 2.5mV (MM), 150mV (line)
Signal to noise ratio: 69dB (MC), 87dB (MM), 107dB (line)
Output: 150mV (line)
Dimensions: 340 x 109 x 369mm
Weight: 9.2kg
Year: 1984
Kenwood KA 828 Manual Stereo Integrated Amplifier HiFi Engine
Nov 15, 2016 | Kenwood Audio Players & Recorders
Connect tv to hifi speakers
It doesn't lokk like your TV has an analog out for your Kenwood system. It might have an optical out but unless the Kenwood has optical in then you'll need to upgrade to a Home theater system with HDMI.
Feb 03, 2015 | Samsung Televison & Video
I have a kenwood full automatic turntable KD-67F ac 120v 10w 60hz. I dont know how to get the thing to work what else do i need? speekers? or other things if u could let me know it would be a great help
First of all you will need an amplifier, because a turntable has no sound power and its impedance needs to be balanced by a phono input, often found on a receiver or an amplifier. Then you will connect the speakers to the receiver or to the amplifier. I believe that a good start would to buy an old cheap stereo receiver, which has phono inputs, where you connect your kenwood turntable. Hope this will help. Flavio/Brazil
Sep 18, 2010 | Kenwood KD-291RC Turntable
Leads for old kenwood car stereo amps
Hey wdalley69, I've got the KAC-8070. My setup has the crossover module for it.
Oct 27, 2009 | Kenwood Car Audio & Video
Kenwood stereo synthesizer tuner t-85l
T-85L is a component of a hifi system not suposed to work alone. You have to connect it to another Kenwood component (an amplifier like the A85 ) through a special cable to power it on/off. The special cable can be used point to point or as daisy-chained.
Nov 05, 2008 | Yamaha HTR-5830 Receiver
Kenwood UD-551M hi-fi stereo ...problem
power problem of power amplifier .
if you can open the cover we can give try to solve this problem.
nuwan
Sep 02, 2008 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
Need a new transformer for an old kenwood stereo intergrated amplifier ax-31 cant find out where to get 1
let me give you a tip ;) power transformer has thermal fuse inside its tape-bounding area. try to locate it and check..transformer might be Ok and fuse has blown.
Aug 13, 2008 | Kenwood Audio Players & Recorders
Vintage Stereo Connection ???
Hi spanky
Where to start :) I am excited thinking about them :p You got 2 totally cool pieces of classic vintage gear there in the C2 and the Marantz. I have a C2 preamp myself (gathering dust but wont sell it cos its excellent) and the marantz would be totally cool to have(but then I am a little biased towards 70's vintage marantz). They ruled the roost in HiFi amps throughout that decade.
Because they are both integrated amps, you could use them as standalone systems with a pair of speakers, and just plug your favourite gear into them. If you just wanted to run up a nice sounding HiFi, I would sell the kenwood gear and just keep the Marantz. The Kenwood kr1100 has the edge in power, so if it is grunt you are looking for use that. Because vintage sound is all about stereo, you only really need an integrated amp to get great results.
the specs are
# Kenwood Model Eleven G (KR-11000G) Receiver
120W per channel min RMS, both channels driven, at 8 ohms from 20 to 20.000 Hz with no more than 0.03% total harmonic distortion.
Dynamic power output 440W at 4 ohms
Power bandwidth 5 Hz to 70.000 HZ
Frequency response 5 Hz to 100.000 HZ -1.5dB
Signal to noise ratio 115dB
The marantz is a little lower in power at 75rms a channel, but will have the sonic edge in vintage sound over the kr1100. Look them up on ebay and you will find that they do have some value to collectors and people seeking nice tone. There is an 1152 for sale here for AU$900
Best bet is to fire up the 2 integrated amps,and see how they are going. Run them for several hours to be sure there is no strange noises and crackles. Then decide if you want power or finesse.
You could also run both amps from the C2 preamp by connecting to the Amp in connections to the rear of the integrated amps.
happy to talk to you more about it, hit me with a Fixya if my advice was helpful to you. I would keep the marantz, use that and sell the rest and buy some nice speakers:)
regards
robotek
Jul 20, 2008 | Audio Players & Recorders
1,656 people viewed this question
 Grubhead
Grubhead
