Question about Amana Dryers
LEA30AL Amana Electric Dryer will run then automatically shut off like it is getting to hot then won't start again until after it has a chance to sit for a while
  • Amana Master
  • 2,509 Answers
Sounds like you have a bad motor,itried looking up your model number but it's not the full number,could be a thermister in there but usually when the dryer heats up and dies it's the motor
Posted on Feb 06, 2010
My Amana Electric Dryer Randomly stops working and it won't start up again , it can take up to an hour for it to work again. Model Number LE8407W2.
There are safety sensors that will break the current when it gets too hot or if the sensors themselves are failing. This will shut the dryer off or make it quit heating. After cooling down or at random times the sensor may make connection again allowing the dryer to work. These can only be checked out using an OHM meter and must be checked when they are not allowing the dryer to run.
Jan 22, 2013 | Amana Dryers
How do i get the front off my amana lea30al dryer
Service guide. Spring clips release the top like in this video:
Sep 21, 2012 | Amana Dryers
Speed Queen Heavy duty Dryer appears to shut down because of over heating. We have had this dryer for quite awhile and the kids are all gone now so we actually don't use it as much. It doesn't...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 14, 2011 | Speed Queen AES28AWF Electric Dryer
I replaced the thermal fuse because there was no heat. Now the dryer over heats and shuts off. Everything checks ok on ohm meter. The timer works in the "no heat" mode. Could it be the timer...
after you changed the thermal fuse did you clean out the dryer and the vent line?if not you blew the fuse again and it will keep doing this until you clean out the duct that the lint filter slides into,vac and blow out the motor and the cabinet where the motor is and blow out the vent line,if it's a long run remove the vent line from the back of the dryer and blow it out with a leaf blower.the dryer went over 300 degrees from lint buildup and popped the thermal fuse,it's a safety so the dryer doesn't run hot and start a fire.if the dryer is running and sfter like 20 minutes it shuts down and won't start for a while until it cools down then the motor is bad also probably from the dryer running to hot from the lint build up.
Apr 08, 2011 | Amana DLE330RAW Electric Dryer
Amana DLE330RAW Elec Dryer starts then shuts off & wont turn on
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jul 08, 2010 | Amana DLE330RAW Electric Dryer
Amana dryer not advancing on auto
Make sure the vent from the dryer to the outside is clean.
Reduced air flow can cause your symptom.
You can remove the vent hose from the dryer and operate the dryer in the automatic cycle.'
If the timer advances you know the vent needs cleaning.
Clean the lint filter housing also.
A flashlight helps to see all the way down the housing.
Jan 20, 2010 | Amana ALE643RB Electric Dryer
Our amana gas dryer. runs for about 20 mins and shuts off. try to resart and there is busing noisefrom the controls on top. if sets for 45mins. it will start again. until it gets hot. and then wont work.
The problem is in the gas valve coils. They sit on the top of the gas valves. When these coils are energized open the gas valves and allowing the gas to burn. If one or more coil malfunctions, the dryer shuts off. It is usually difficult to properly test the coils and replacement is the best solution.
Sep 25, 2009 | Amana Dryers
RUNS AND HEATS UP BUT THEN QUITS LIKE IT OVER HEATED
Check for good air flow from wall end of flex hose. If weak, remove the lint screen and retry. If now ok, soak the lint screen in detergent and hot water. Hard to tell if this is the correct answer.
Aug 01, 2009 | Whirlpool LEQ9858L Electric Dryer
Dryers Logo
164 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
