Question about Refrigerators
How do i tighten my door handles on my kitchenaid superba refrigerator. It has small screws on the handle but they dont tighten??
  • 4,793 Answers
The small screws are for the covers.remove them covers will fall off showing handle screws use loctite to secure so they dont work loose.....
Posted on Feb 06, 2010
Fix loose handle on kitchenaid refrigerator
Look for small hole at each end of handle if it as them use a small Allen wrench to tighten. If no holes. Some have prices of trim that hide screws others just pull off The handle has to be grasped firmly push in towards frog and pull up to remove than you can tighten studs
Feb 05, 2016 | KitchenAid Refrigerators
How do I tighten handle on kitchenaid refrigerator model ksso42qtb00
look for allen screws from behind the handle were it is hard to see. they will be very small.
Oct 11, 2014 | KitchenAid Architect Series II KSSO42QTB...
The handle on the front of frig is loose....how do I tigthen.
Hi.
The handles are retained by tiny screws. You will need an allen key to tighten the screws. If the handle is damaged you will need to replace the part. If you need to replace the handle buy the single handle rather than the kit. The kit will be more expensive.
Please refer to video and diagram below. Click on the diagram to enlarge the picture:
Here replacement parts for this model.
Regards.
Ginko
Aug 19, 2011 | KitchenAid Superba KSRG25FK Side by Side...
Bottom door handle loose
There is a 3/32" allen set screw on the under side of the handle. Just tighten the set screw and your problem should be resolved.
Aug 24, 2010 | KitchenAid KBFA25ER Bottom Freezer French...
I have a kitchenaid KBLS19KTSS 01 bottom freezer, and the freezer handle has come off on one side. do I need to disassemble the door to reattach it? Or, do the small screws on the bottom of the handle...
It looks like your handle is the style that slips over a screw that is threaded into the face of the door...
According to your owner's manual you most likely just tighten the small allen head screws to secure it. It lists the screw size as 3/32. You should have been left the allen head with your paperwork when you bought it.
Jun 12, 2010 | KitchenAid Refrigerators
Handle of refrigerator is loose. How can you tighten it?
Use an allen wrench to back off both the upper and lower set screws (Note: you do not need to back them all the way out). The handle will then easily pull away from the door. With a 1/4" socket, tighten the screws holding the upper and lower lugs on the door. Place the handle back on and tighten the upper and lower set screws.
Oct 24, 2009 | KitchenAid Superba Architect KSCS25INSS...
I have a ksbp25fkss side by side fridge and the door handle on the freezer is loose, but the handle is not the one depicted in the manuel. the handle must be tightened from the back or inside of the door....
you should have trim below and above the handle if not then and its a stainless steel door then there is small round opening on the side of the handle you'll need allen wrenches once you loosen the allen the handle slides up or down then you will be able to tighten the stud post screw then reverse the mounting -----------------be cautious of scratching the stainless steel door when removing the handles
Sep 01, 2009 | KitchenAid KSCS25FKSS Side by Side...
The door handle on the freezer of my GE Profile Bottom Freezer Refrigerator came off.
Hi, Please get me the model # from the label inside the refrigerator and I will look this up for you. Most handles have a set screw that tightens down.
Vic
Jul 11, 2009 | General Electric Profile PFSS2MIXSS...
Door Handle Loose and tightening with allen wrench does NOT work ...
Just did this on mine today. Use an allen wrench to back off both the upper and lower set screws (Note: you do not need to back them all the way out). The handle will then easily pull away from the door. With a 1/4" socket, tighten the screws holding the upper and lower lugs on the door. Place the handle back on and tighten the upper and lower set screws.
Jul 25, 2008 | KitchenAid Superba Architect KSCS25INSS...
Handle loose on Refrigerator
To fix this you will need an Allen wrench small one there are 2 set screws on the inside part of the handle (on side toward the center) you wil need to tighten these to fix your problem
Feb 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
455 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
