Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Water does not dispense - Bissell 1699 ProHeat Clear View Upright Steam Vacuum
  • 701 Answers
That means that you need to replace the pump belt. Here are the belts you need:
Bissell Proheat Belts
Posted on Feb 06, 2010
No cleaning formula or water is coming out of the dispenser. Any suggestions.
Just a thought, did you fill the dispenser or just the bladder inside the dispenser with water? The bladder inside is filled with water through the hole on the left side of tank. The waste water then goes in the tank around the bladder, a 2 in 1 deal.
If you have filled it correctly and are still having problems, please write back.
I hope this helps. If it does, please place a vote or comment for me. Thanks,
Handie Andie
Mar 30, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
Water not dispensing
Check the release valve on bottom of clean water reservoir unscrew if needed, once again if your not sure run hot water in the solution tank through the system to help remove old soap residue and always run hot water through to prevent future problems after cleaning carpet and storing.steve
Jun 06, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Water and cleaner dispenses from handheld attachment only
He could be right but most of the time when it doesn't dispense water and cleaner it means that the pump belt is worn and needs to be replaced. I would try that first (only $4.99) before I spent $100. Here is the pump bet you need, it comes with instructions:
Bissell 1699 Proheat Belts
Dec 31, 2009 | Bissell 1699 ProHeat Clear View Upright...
Water does not dispense on wash cycle
this would be the soap/ water valve. it is stuck closed or isn't opened.( no cure for an non-opened valve, just replace.)
Jul 16, 2009 | Hoover F7220900 SteamVac V2 Upright Vacuum
Bissel proheat no water will dispense
Check all your hoses and make sure that they are not blocked and everything can run freely through your sstem
Apr 25, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Water tank doesn't dispense water
water is not coming out or sucking up water
Aug 24, 2007 | Hoover F5906-900 Upright Steam Vacuum
Hoover floormate problem
I found a solution posted by someone elsewhere on this website. Try doing a search for Hoover Floormate H3000... The posted solution is as follows:
Remove the liquid dispenser and set it aside. Locate the plastic "plunger" piece in the machine that is surrounded by a black rubber circle (the one on my machine is blue/grey in color...). Place a small drop of hot glue on top of this plastic "plunger" piece and let it dry. Replace the liquid dispenser and test the machine. This solved my problem and my machine dispenses liquid properly again!
I really appreciate the original poster who posted this simple solution.
Aug 16, 2007 | Hoover Floormate H3000 Upright Wet/Dry...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
106 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
