Question about Singer Quantum XL-6000 Computerized Sewing Machine
Neddle brakes - Out off the course when sewing large patterns
My "Singer Professional XL-1" needle, when sewing some patterns (large ones), goes out off the course (to the right) and brakes. The needle it's right, and have oiled machine...
  • Janie Aug 26, 2013
    How do you adjust clutch for needle to go up and down again after fixing the buffer?
  • berndlberg Jan 31, 2014
    The buffer is fixed with two screws and can be moved left and right. This have to be adjusted so, that the clutch releases before the needle stitches onto the plate.
The reason of this missbehave is a destroyed plastic buffer, which is attached to the move limiter for the needle bar frame. It is quite a little delicate to open the machine's housing due to some hidden scews. Neccesary is to open it. You have to empty the accesory drawer. Then you have to remove the underside cover. The right side cover must be removed as well (take care of the screw which fixes the middle part of this. It is found from below through a small channel, just fitting a screw driver through the hole). Below the movable small table at the lower left front, there is a small turnknob for adjusting the horizontal alignment of big patterns. This knob has to be pulled out, also the round cover below it (best use a little hook and pull the cover out at its small hole seen from below). Remove the two screws directly under the movable table. Remove all screws, which are fixing the front cover from below the machine. Remove the hood which covers the needle bar just as you would like to change the light bulb). There are two scews to be removed holding the front cover. The foot presser handle has to be removed as well. Now gently pull the front cover off the machine. It might be neccesary to help moving the cover at the upper side, inserting a screw drivers blade into the gap between cover and machine frame. The cover should snap off now, if there are no forgotten screw connections left.
After the cover is released, take care of the ribbon cable, wich connects the display etc. with the electronich mainboard. the ribbon cable can be teared out carefully of the mainboard connector. Now you have clear sight onto the needle bar's mechanics. if you push the needle bar to the right, you can see, that the needle bar frame is stopped from a small metal piece, fixed with two screws. At the touch point of the frame and the metal piece, there is (or was) the plastic buffer, which is now destroyed and has the consistence of used chewing gum.
There are two choices: Either you find a spare part metal piece with good plastic buffer or you will have to improvise the buffer by handcrafting it.
After you repaired the metal piece, you will have to adjust it.
Moving the needle bar to the right, the needle bar clutch have to release the needle bar before the needle is over the point to stitch to the plate.
Remark: Due to the different length of the screws it might be a good idea to give some notes, which length belong to which hole.
Wish a good success,
Bernd
Posted on Feb 17, 2011
Cxl manual
User's Manuals, including yours, are available as a free download the Singer Sewing Machine website. Actually, when you enter CXL you get the XL-50 user's manual, which is essentially the same machine, although a few of the patterns may be different. The CXL, XL-50, XL-10 and XL-1 are basically the same machine; I own a CXL and XL-50, and love them. They can sew SIDEWAYS--straight AND zigzag stitch!
Jun 12, 2014 | Singer Sewing Machines
Adjust timing
Presuming your needle is clamed in fully up position & is not needle bar height problem,this needle/hook timing should get your local sewing machine technician to get it adjusted correctly.
Oct 24, 2013 | SINGER 7470 Sewing Machine
Singer Sewing Machine 534 repairs
hi it sounds like the timeing has moved on (1) and also on (2) would need to be seen by dealer.
Apr 09, 2013 | Sewing Machines
My neddle keeps bending the side and breaking
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
Dec 03, 2012 | Singer 2732 Mechanical Sewing Machine
I am on the second letter of an embroidery pattern and the needles keep breaking. I have tightened everything as much as possible. I have never had this problem before. I am using the correct needles. Any...
I have a babylock serger & I use SCHMETZ UNIVERSAL NEEDLES on the serger & I don't have any problem with the serger
you should also check the tension to make sure it correct for fabric & needles
also make sure the needle is not in backward--flat side goes to the back of the machine.
if you need a manual contact babylock customer service
Mar 26, 2012 | Singer Quantum XL-1000 Computerized Sewing...
Thread keeps breaking on my singer XL 5000. Seems like after i cleaned lint out of bobbin area i started having the problem
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Mar 17, 2012 | Singer Quantum XL-5000 Computerized Sewing...
Neddle screw wont tighten neddle in
There is a small metal rod about 1/2" long that fits into the hold in front of the screw that holds the needle secure. I didn't realize that I had dropped the rod until I could not tighten the needle. I found the rod, put it into the hole and was able to tighen the needle.
Jun 22, 2009 | Brother XL-5130 Mechanical Sewing Machine
Singer xl1000 will only sew backwards
Electronic problems require professional to diagnose, sorry.
May 13, 2009 | Singer Quantum XL-1000 Computerized Sewing...
Singer quantum cxl sewing machine needle hitting metal
Your needle is probably to long or you need to open it more
Apr 08, 2009 | Singer Quantum XL-1000 Computerized Sewing...
I have a quantum cxl. It will sew normal stiches but it will not sew the decorative stiches
The needle shaft sticks to the curved arm and won't come down because a piece of plastic, about an eighth of an inch thick had broken from age. It prevented the shaft from staying up on the needle arm. Open the cover, try to stitch decorative stitch and see what I mean. Purchase a package of 4-10 by 1/2 nut and bolt pack. Screw the nut all the way onto the bolt. Using needle-nosed plyers, Carefully bend the curved arm slightly, and place bolt into the hole on the top of the needle shaft. Nut will keep it in place. Lowering the needle shaft using wheel, carefully bend arm back in place. Try decorative stitch. It should work. It does for me.
Aug 03, 2008 | Singer Quantum XL-1000 Computerized Sewing...
Singer Quantum XL-6000 Computerized Sewing Machine Logo
168 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
