Question about Sharp AR-407 Copier
How do i reset the operator key, and how to fix a h3-01 problem??
  • Sharp Expert
  • 316 Answers
Heat roller high temperature detection
Posted on Jun 06, 2010
How do i fix sharp copy machine AR5520N with error code H5?
H5 error is protection against big damage of the fuser caused by multiple paper jams in the fuser area. First clean and check paper way, check sensor operation and then reset the error. Reset with key operation # - INTERRUPT - CLEAR - INTERRUPT - 1 - 4 - START
Aug 14, 2016 | Sharp AR-5520N
How to fix c-3723
C 3723 Fusing abnormally high temperature detection pressurizing side.Check the fusing unit for correct instalation,check the open/close operation of the upper right door.To reset turn OFF.Press and keep pressed the Utility key and turn ON.Keep pressed Utility key while Trouble reset message displayed.Release the Utility key ,touch the message and turn OFF.Wait 1 minute and turn ON.
Jul 28, 2014 | Konica Minolta Bizhub C253 Copier
the E001-004 means that fixing unit is overheating and you have abnormal raise of temperature.
You can try to reset / clear the error in service mode:
1) Press the asterisk key (*) on the operation panel.
2) Press 2 and 8 simultaneously on the numeric keypad.
3) Press the asterisk key (*) on the operation panel.
Choose:
COPIER-FUNCTION-CLEAR-ERR, then turn it off and back on.
If this doesn't help's you, you need to chnage the fixing assy.
Aug 07, 2011 | Canon imageRUNNER C3220 Color Copier
Error E000001-0004
The E001-004, means:
The difference in temperature between the
non-contact thermistor and the end thermistor
remains 80°C or more for 500
msec.
... so, that means, that you have trouble in fixing assy.
You can try to reset the error code in service mode.
1) Press the asterisk key ( * ) on the operation panel.
3) Press the asterisk key ( * ) on the operation panel.
The initial screen now appears.
Select:
1) Select this item, and press the OK key.
2) Turn the main power OFF/ON.
If still after the clearing procedure, error still persist, You need to replace the fixing assy.
Hope that helps!
Jul 24, 2011 | Canon imageRUNNER C3200 Copier
How to format phone memory?
Basic Reset or Soft Reset This option restores the .ini files from the ROM.
Does not erase data (photos, videos, documents) or applications from
a third party. Key Code *# 7780 # (click this combination of keys on the
keyboard in the mobile)
2.- Total Reset or Hard Reset This option restores the original operating system from the ROM.
Formats the C: partition and deletes all data including the memory
card. Key Code *#7370# (click this combination of keys on the keyboard
in the mobile)
Important:
To proceed to reset, the battery must be full and the mobile device connected to the charger. If during the course of reset,
the mobile stop receiving electricity it can ruin the internal flash
memory of the mobile device and stop function.
Code for reset 12345
Hope this help.
Mar 09, 2011 | Nokia E62 Smartphone
Canon ir 5055 has an error e000004-0010. how di I fix this?
This is a fixing error code - there is too much temperature difference detected by the thermistors. Mostly a error reset will take care of the problem. You have to get into service mode first. Press the additional function key, then press the 2 & 8 keys at the same time, then the additional function key again. Then copier, function, clear, err, then OK. This clears the error code from the copier. Then power cycle the copier and the copier should be operational. If this doesn't work then you will have to have a technician fix it. DO NOT keep resetting the code. There is something wrong with the copier that needs to be taken care before major damage is done to the copier. Good Luck
Dec 08, 2010 | Canon imageRUNNER 5570 Copier
How to fix a none responsive button in hp 35s calculator
Resetting the Calculator
If the calculator doesn't respond to keystrokes or if it is otherwise behaving unusually, attempt to reset it. Resetting the calculator halts the current calculation and cancels program entry, digit entry, a running program, a SOLVE calculation, an ∫ FN calculation, a VIEW display, or an INPUT display. Stored data usually remain intact.
To reset the calculator, hold down the C key and press GTO . If you are unable to reset the calculator, try installing fresh batteries. If the calculator cannot be reset, or if it still fails to operate properly, you should attempt to clear memory using the special procedure described in the next section. If the calculator still does not respond to keystrokes, use a thin, pointed object to press the RESET hole.
The calculator can reset itself if it is dropped or if power is interrupted.
CLEARING the MEMORY
If the calculator fails to respond to keystrokes, and you are unable to restore operation by resetting it or changing the batteries, try the following MEMORY CLEAR procedure. These keystrokes clear all of memory, reset the calculator, and restore all format and modes to their original, default settings (shown below):
  1. Press and hold down the C key.
  2. Press and hold down the R/S key
  3. Press i (You will be holding three keys simultaneously)
  4. When you release all three keys, the display shows MEMORY CLEAR if the operation is successful.
Mar 02, 2010 | HP 35s Scientific Calculator
ERROR CODE 4H ON AR-5316
There is a problem with the fuser unit ( exit where it gets hot), unfortunately you need to replace
either 1- thermofuse, 2- thermistor, 3- heater lamp
Sep 10, 2008 | Sharp AR-5316 Advanced Digital Imager...
Waste ink near full
if in case the tank is replaced or not, you may reset the tank counter to get your printer operational, here is the sequesnce.
1) Enter SERVICE MODE.---
By pressing Menu-Copy-#
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Skip step (6) since there is no [OK] key on F30 or F50 printers.
Aug 18, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Canon iR2016
most times eoo1 can be reset in service mode if there is no damage to fixing unit. 1) Enter service mode.
Press the operation panel user mode key, 2 key, 8 key and user mode key in this order.
2) scroll to "clear" and press ok then scroll to "err" and press ok.
if that does not work you can go back into service mode as above and instead of scrolling to "err" scroll to "all" and press ok. power off then on. doing this will clear settings service techs might have made but i've done quite a few and had no probs
Mar 29, 2008 | Office Equipment & Supplies
Sharp AR-407 Copier Logo
78 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
