Question about Samsung SGH-I200 Cell Phone
How to disassemble the back cover to reach internal display panel to clean it up from a tiny dust?
    Problem Solver:
  • 10 Answers
I dont know yet lick it
Posted on Feb 06, 2010
How do I disassemble a Vizio E3D470VX Smart TV, to clean out the dust inside the Screen
Hi Alonzo,
To clean the dust inside the screen, you will have to disassemble the LCD panel. It is a very risky job and there is every chance of damaging the LCD screen unless you have a real good experience of doing it. If you are not good at doing such jobs, please let some professional do it for you.
Jul 05, 2016 | Vizio Televison & Video
How do i disassemble the DirecTV RC71 Remote?
Check for more screw(s) behind the label/sticker. Also, you may need to have a flat edge screwdriver or knife to prise open the remote.
Sep 24, 2014 | Directv Televison & Video
Casio sea pathfinder fogged crystal. Worked in yard. No water exposure other than sweat. Advice please?
condensation inside a watch means the watch's internal temperature and humidity reached dew point.
The watch needs to be disassembled "completely" and dried out. Get the battery OUT! Get a can of dust remover spray and get it dry. You can use some alcohol and a swab to clean it too. But careful, alcohol may act like a solvent and the parts may melt. If its been a few days, it might be too late. If you don't have the tiny tools or patience to do this yourself, try a local jeweler. They'll tell you right up front if its shot or not...
May 06, 2013 | Watches
I have had a lcd tv for aout 3 years recently the screen has been going dark,out of focus on the left side,sometime a line appears across the screen and divides the colour of the picture. What an I do
hello!
the problem is display panel connectors or panel itself(bad case). To solve it, you must disassemble the set till the point, when you will be able to see
t-con(display controller). It, usually have metal shield over it. you need to unscrew those tiny screws, may be remove sticking foil too. After you see the board itself, there are 1 or more flat ribbon cables connecting t-con board to display panel itself. Plugs have plastic locking, fragile! First, unlock the left side(opposite to your view) and pull cable out, then carefully reconnect it. If more, than one, repeat the procedure. got working? assemble everything back. Still have the problem: try to do the same with the other end of the ribbon(s). those, what connect display's boards. You may have insufficient space to reach plug's locks. Invent something to accomplish the task: use tweezers or metal picks. Try not to break anything. In most cases this problem caused by dust/dirt accumulation at those connectors. If nothing helps, I've seen the panels itself doing that. that's the end of DIY project, may be TV itself, unless you purchased extended replacement plan. cost of the panel will void any reasonable repair!
good luck,
thanks,
Alex.
Jan 08, 2012 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Hi, im using hp all in one 2060. My problem is that, tiny ants had scattered inside my printer and I don't know how to disassemble the printer,please, give us a help, for me to clean them up. Thank...
Hi
Switch off your printer. disconnect the power cable or USB cable, and take him out or your room, take one blower and open the printer front cover and switch on your blower and clean the all dust and paper scrap...
May 30, 2011 | Office Equipment & Supplies
Dust under screen.
The camera has to be taken apart. First - the front cover, then the back cover. You will need some compressed air.
Tom
Sep 20, 2009 | Kodak EASYSHARE M1063 Digital Camera
The images displayed are purple. I sometimes solved the problem by adjusting the focus. Now it remains purple all othe time.
Hello...The problem you're describing is related to the green lcd and most likely the main board(green channel). If the focusing removes the purple(you have *that* much dust in the unit?) then it *is* dust. You should be able to focus on the dust particles twice--dust on the front of the lcd and dust stuck to the back of it. I'm gonna give you the color table so you know what to look for and what you're seeing. Red LCD=cyan(baby blue) onscreen; Green LCD=violet(purple) onscreen; Blue LCD=yellow onscreen
If you have a lot of dust(and the green lcd usually is the main culprit by the design of the lcd panels around a glass "cube" internally) you might try blowing some air into the unit when it's cool. However, the unit probably needs a good cleaning--remember to clean the dust filter! To properly clean the unit, a trained tech will have to perform the job. The lcd panels are DELICATE and precisely positioned for displaying a sharp image.
Sep 18, 2009 | Dukane ImagePro 8755A Multimedia Projector
Large dust circle on a Toshiba 50H95 RPTV
No the front panel will only give you access to the CRT circuits. Remove the back panel. UNPLUG your set. You should be able to reach inside (its a stretch for sure) to clean the screen, clean the tubes and if you reach up behind you can actually clean the mirror. This will greatly improve your picture. Do not use windex just a damp soft cloth then dry with a soft cloth. The mirror cleaning is most important to get a nice bright picture. Over the years the mirror tends to get dull. Hope this helps.
Jan 20, 2008 | Televison & Video
Apple Cinema Display 23" HD - Dust on inside of screen.
Well, I pretty much knew that the display would have to be disassembled to clean the dust out. I should have been more specific by asking if the display "could" be taken apart to clean it out, especially since the dust is in between the image and light source layers.
Jan 15, 2008 | Apple Cinema Display 23" HD Monitor
Need to disassemble Mitsubishi VS-6041 60 in Rear Projection
Wow, You are asking for a complete disasemmbly. If this is necessary, you have to remove any screws you can find that are connected to the front panel. Usually they are in the top of the set ( you'll find them after removing the mirror panel and mirror ). I wouldn't remove any tubes as the tube convergence would have to be all reset and that would require a cross hair generator. I do hope this has helped in some way, but all I can do is send you my best wishes as I certainaly don't suggest disassembly if there is any other way. Good luck
Ed
NC Electronic
Mills, Wyoming
Nov 24, 2007 | Mitsubishi VS-6041 60" Rear Projection...
Samsung SGH-I200 Cell Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
