Question about ViewSonic VE150 15" LCD Monitor
White Color Screen Display
I have a Viewsonic VE150 15" LCD monitor, currently the monitor can be switched ON, and there is a display on the monitor when hooked up to the computer. The problem of this LCD monitor is the display, the screen displayed in the monitor is too little, not clear, the picture is just like you are turning on the brightness of the CRT monitor to the max until you can only see the picture a little, and the rest is white or light grey. Please advice. Thanks! My email is yewnen@hotmail.com
SOURCE: No display, green light on ViewSonic VP201b 20.1 LCD
I have two broken VP201 monitors with different symptoms. One was black screen green light - like yours. The other was purple speks flying all over the screen., purple tint.
I swapped the power supplies and display boards, both monitors had original problems. I swap the inverters and the monitor which was black screen now appeared to work okay - but slightly pink and the monitor which was purple speks is now black screen.
I would therefore assume that both my inverters gone, one being on it's way out. You probably have the black-screen case.
Posted on Aug 27, 2008
SOURCE: ViewSonic VA912b (Back light with blank dark screen)!
Wow, many people are having this situation. Mine died out about 2-3 months ago. Same problem. need help :[
Posted on Oct 14, 2008
  • 11 Answers
SOURCE: always seen brightness and contrast not exit
try turning it on and off, wait a few hours then turn it back on. it that dont work, turn it off then leave it till the next day then try. it should work.
Posted on Jul 28, 2009
pravinbhavsa
  • 348 Answers
SOURCE: viewsonic VA902b too bright. menu control greyed out
open the monitor draw the screw and there is a big black part called E.H.T.to which has preset to rotate it with screwdriver in on condition of monitor untill sufficient brightness will come
Posted on Mar 09, 2010
  • 16 Answers
SOURCE: ViewSonic N1700w with Black stripe on right side of display
Sounds to me that you have a bad connection/wire to the CCFL bulb on that side of the display. Should be an easy fix, do it your selfer thing.
Posted on Mar 31, 2010
WHITE SCREEN
hi if your monitor just display with white screen no picture the cause would be a bad lcd controller or bad lcd panel. but before you come up with trouble shooting inside of the monitor you can check first a loose connection in the vga port or tried with replacing a new vga cord.just let me know if you need further assistance i'm glad to help you good luck.
Nov 05, 2012 | ViewSonic Computers & Internet
I have 17" LCD viewsonic
Yes you can if you can source one however it may be more cost effective to replace the monitor.
Nov 03, 2010 | Computers & Internet
My viewsonic vx2025wm 20.1 lcdmonitorgoes green,sometimesyellow,then returns towhite screen
check your cable connection if the color changes.. as normally bad or lose display connection will cause this problem..
but if it turn to total white without any image.. then most probably the LCD monitor is faulty..
but there are some cases when your display card that is giving this funny problem.. if it get too hot.. check your PC display card whether the cooling fan is turning or jam.. this is the main cause the display card get overheat and give you funny display...
May 23, 2010 | HP Computers & Internet
My viewsonic has poor image display what can be done.
Change screen resolution and color settings from the 'display settings' area within the operating system.
Dec 05, 2009 | ViewSonic VG700b 17" LCD Monitor
ViewSonic VA912 half screen dead after 30 minutes
first i confirmed that the problem was in lcd.then i predicted that some display chip on the motherboard are getting heat.due to which the display was performing irregular then i switch on A/C of my room.and the temperature was cool. and the monitor was working fine.
Apr 29, 2009 | IBM E54 (Pearl, White) 15 in.CRT...
Half monitor display and other half will be some different color.
Click -Start then Ctrl Panel - then Display - then Settings...
make sure you have 1280 x 800 (32 bit) .
or just hit the default tab .
Jan 15, 2009 | ViewSonic VA1703wb Monitor
Screen goes white after 12 seconds
Per the first hit on Google for 'viewsonic fades white', http://forums.worldofwarcraft.com/thread.html;jsessionid=A68BB7FE4AF6EC93EB730E8588C865A2?topicId=4064461903&sid=1
(which you should go on and read in another tab,) you need to contact Viewsonic about an inverter board (for the CCFL backlight) or switching your backlight to LED while spoofing the INVERTER_OK signal to keep the display from giving up as it does.
So...this should be a hint that you should respect others' time (or be moved to increase usability) better by searching for cures in similar Viewsonic monitors, and of course checking the obvious search terms.  Viewsonic evidently has a nifty knowledge base available for all on the web, so that one would be a nifty surprise.
Aug 18, 2008 | ViewSonic VX1945WM LCD Monitor
KDS K717s 17" LCD Monitor
The white screen tells me that the display cable (inside your monitor) may be unattached or broken.
The color bands if they are vertical or horizontal lines tell me that your display cable needs to be replaced.
So overall replace your display cable. If this doesn't entirely fix the problem your logic board (inside the monitor) needs to be replaced.
Feb 21, 2008 | KDS K717s 17" LCD Monitor
Dec 27, 2007 | ViewSonic NextVision N1700w (Black,...
ViewSonic VE150 15" LCD Monitor Logo
44 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
