Question about Olympus FE-230 Digital Camera
Lens are stuck
Lens is stuck in half open postion unable to take on pictures as camera automatically switches off
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Feb 06, 2010
The lens wont retract(its stuck) thus the camera will not stay on when power button is pushed
FOLLOW this procidure open the camera then rotate the lens and set it like it was before
May 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
My digital Sony camera fell down Lens got stuck
    As in short answer you have to replace the optical lens assymbly.Because due to heavy jurk its motor called sledge motor stsrt malfunctioning and it can not be changed component level. For this please contact any SONY SERVICE CENTRE nearby to you.
Hope you will understand.
Thanks for using FIXYA!
Apr 28, 2009 | Sony Cyber-shot DSC-H7 Digital Camera
My sony
I can fix your camera, it is not an easy thing to post because the post would be forever long....
$20 and it would be good as new.
Jul 12, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Stuck Lens
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 18, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Lens is stuck open
We had the same problem with a Casio Exilim. Had been stuck for months...had nearly given up until I saw another post about banging the camera pretty forcefully to get the lens unstuck. I hit it once on the bottom onto my desk(w/ paper and blotter on the desk-so soft), then twice with the back of the camera against the desk. I turned it on and the lens was unstuck!! Immediately took a couple pictures and it seems to be working fine! If the camera may be lost, you've got nothing to lose to try this out...Good luck!
Apr 26, 2008 | Casio Exilim EX-S500 Digital Camera
Problem with the cap on the lens of digital camera SONY CYBERSHOT DSC P52
I have loaded the program into my computer but am unable to bring up the photo, I think i need a new disc as it says it is corrupted, but I do not know where to get one.
Dec 18, 2007 | Cameras
Cybershot lens stuck
The gearing on the lens is probably damages from the drop. You have two choices:
1. Send it in for a repair (which will be expensive) and claim from your insurance. If it is uneconomical to repair, your insurer will probably pay for a replacement camera.
2. If you're not insured, it may be cheaper to just buy a new camera rather than pay for a repair to a 4(?) year old camera.
Oct 14, 2007 | Sony Cyber-Shot DSC-P72 Digital Camera
Lens stuck in the out postion
Contact customer support Repair cost will be heavy
Aug 01, 2007 | Pentax Optio M20 Digital Camera
Lens is stuck out
push up on the inner lens housing,
Dec 24, 2006 | Kodak EasyShare LS753 Digital Camera
Olympus FE-230 Digital Camera Logo
323 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
