Question about Samsung PCN5425R 54" Rear Projection Television
I have a shadow on my bigscreen tv.Where s the adjusting screw?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems that you have to replace the convergence IC and check power resistor for leakage, if values are not exact you have to replace them. The typical cost to get this fixed by a pro is about $300 - and it doesn't mean that he/they will do a job better than you do. The parts are less than $100 (about $20-$30 for the IC's) if you want to do it yourself. Replacing only the IC's MAY solve the problem; however, many people have also had blown resistors requiring replacement. Why would you ask should you replace both of the IC's if only one is shot?! If one is shot the other one is not far away and for that little price of the chips it worth changing them both at the same time. Also the convergence board should be checked for cracked solder. If you replace the ICs and the resistors are shot, the ICs may blow again almost immediately, meaning you may have to do the repair twice. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 10, 2010
2004 Honda VT 1100 C2 Shadow Sabre carburetor adjustment
Hi, Anonymous it should be noted that the "AIR FUEL" mixture screw adjustment "ONLY" manages your idle and has no effect on any other circuit also any intake leaks must be repaired before the A/F adjustment procedure can be performed otherwise you will never obtain a proper idle and you will waste a lot of time chasing the impossible. The A/F mixture screw's purpose is to fine tune the fuel charge entering the combustion chamber. The following applies to both 2 and 4 stroke engines:
1. The mixture screw may be sealed at the factory with a Welch Plug please review the following video for removal.
https://www.youtube.com/watch?v=wAXcksgvDkM
2. The mixture screw manages a range of 3 complete 360-degree counterclockwise turns from the bottom/closed position.
3. The mixture screw should have a spring and o-ring for tension and sealing integrity.
4. Turn the mixture screw clockwise until it gently bottoms out, this makes the fuel charge very lean and the engine should not idle if it does then the pilot/idle jet is too big and needs to be replaced with the next size smaller.
5. Turn the mixture screw 1 and 1/2 turns counterclockwise to establish a baseline for starting the engine.
6. To fine-tune the idle circuit, adjust the mixture screw 1/4 turn in or out to achieve maximum idle RPM, wait 15 seconds between each adjustment for the idle to settle.
7. Never go past 3 full turns out this will make the fuel charge rich, foul plugs, and produce black smoke out of the exhaust, if the engine RPM keeps increasing past 3 turns the pilot/idle jet is too small and needs to be replaced with the next size larger.
8. After achieving maximum idle back out the mixture screw another 1/8 of a turn then adjust the throttle cable idle stop screw to 950-1050 RPM.
9. This procedure works great on 99% of all engines, for the 1% that demand a more robust throttle response on aftermarket monster fuel delivery systems additional tweaking outside the box may be necessary.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1995 VT1100C2 Air Fuel Mixture Pilot adjust
VT1100 Mixture Screw Location
Honda Shadow VT1100 Owner Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda shadow vt1100 Owners Workshop Manual
Apr 27, 2014 | 2004 Honda VT 1100 C2 Shadow Sabre
Carb adjustment
Besides the idle set and idle mixture, there are no other adjustments you can make without rejetting.
Feb 14, 2014 | 2007 Honda VT 750 Shadow
1999 Honda Shadow VT 750 air fuel mixture screw location
Hi, Mike for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing and printing please click on the blue links below. Good luck and have a wonderful day.
Adjusting the Mixture Screws
Honda 1998 VT750C Service Manual
Honda VT750C Owner Manual
Oct 24, 2011 | 1999 Honda VT 750 CD Shadow A.C.E. Deluxe
About 6 inches from the left side of tv there is a red shadow to pepole or writing. when cold the problem is not there. seems as it warm up the worse it gets?
you need to have the stk 392-120 replace but some restor 2.8onm to this will fix red line it a coming thing for this set if a game xbox or ps2 or 3 or eny games will miss up the bigscreen bad to
Dec 07, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Red shadows around images on screen, setting convergence doesn't help
HELLO. it not in adjusting the len's it's in the convergance board. the IC'S ON THE BOARD NEED TO BE REPLACED."GOOD LUCK"
Jul 25, 2008 | Akai PTH5498 54" Rear Projection...
Samsung dlp tv
Yes, it could. There is a light pipe in the light path that could now be broken from the bumping or it could just be out of line from the bumping. Another problem could be the mirrors in the projection path could just need adjusted by the 3 screws that are beside the mirrors. This may also happen when bumped.
Mar 20, 2008 | Samsung HLR5667W 56" Rear Projection HDTV
Convergence
corbey1984,
Look for bad pico fuse feeding B+ to convergence amps,two are
hiding under the heatsink amps are on, more fuses in power supply ...............................What part # did you use and what price / mfr. ?.............................T
Cris1983,
please verify your model number on back of your tv..........T.
Nov 30, 2007 | Samsung PCL5415R TV
RCA Bigscreen Television
it was storming outside and the color of my 46inch rca started changing and the writing in commericals had double letters
Sep 17, 2007 | Televison & Video
Sony kdf-e50a12u rear projection lcd bravia. red...shadows
try this http://www.avforums.com/forums/showthread.php?t=459681
Aug 11, 2007 | Sony KP-61HS10 61" Rear Projection...
Open Questions:
Samsung PCN5425R 54" Rear Projection Television Logo
51 people viewed this question
Henry  Thomas
Henry Thomas
