Question about Sony Ericsson Walkman W980i Cellular Phone
Problems to swicth on the phone
My phone does no turn on after i used the USB cable..it just the keyboard lights up and nothing on screen at all..how can i fix this??
  • 17 Answers
This exact same thing happened to me
the solution is to open up sony ericsson pc suite
then under tools click "phone repair" and follow the prompts
if this fails it means your battery is dead, try charging it and try again
i still have no idea what the cause is though
seems like the w980 is just very dodgy
Posted on Feb 18, 2010
    Problem Solver:
  • 10 Answers
Ummmmmmmmmmmmmmm......... well turn it off then if that doesnt work call veriaon a&t or someon where u got ur phone from and say its not working ok
Posted on Feb 06, 2010
No keyboard, lock screen is on, lock code is alphabetical
perhaps you need to contact the MFG and tech support.
May 31, 2015 | Android Cell Phones
MSI MS-7184 keyboard usb and ps 2
Sounds like your processor might be heating up too fast. I would take the computer apart, clean it removing all dust from the fans, check to see if the fan is actually spinning and check to make there the silicon glue has not dried up. It could also be that your power supply isnt supplying enough power but if you haven't added any devices that wouldn't be the issue.
Nov 21, 2013 | HP Amethyst motherboard MSI MS-7184 Socket...
My brand new Samson Graphite MIDI Controler Keyboard hanging whenever i will save an edited data. i have to unplug the cable power or the USB cable to swicth it off and open again for me to use it. th
i have the same same problem with my unit, i really need help !!! The problem is still there , even if you do a firmware upgrade . i also returned the unit to the retail store and have a new one with the same problem, the software editor doesnt work on windows 7 but in windows xp with 1.92 version, please check my video
http://youtu.be/DKn5ArIxl4M
Jan 21, 2013 | Samson Graphite 49 - USB/MIDI Keyboard...
Hello Experts, This is Viswanath Esikala from Bangalore(Near Bomallanali) Iam facing one problem, in lenovo 3000 G430, Problem is when i swicth on button,lenovo laptop is unable to display screen,...
There's a possibility that the problem is with the LCD cable or the LCD itself. If its either one of them, you will not be able to fix that by yourself since you will need to replaced the part itself. But there's one simple solution that may fix the problem if its not the hardware itself.This may cause by an electrical charge in the motherboard itself,Im not really sure how it affects the display of the computer. Please follow this method since it usually fix such problem like that,
1.Removed the battery then unplugged the AC adapter
2.Press and hold the power button or the ON/OFF button for at least 30 seconds
3.Connect the power supply back to your computer then turn it back on.
4. Check if you will see any difference.
5. If nothing happens, try to press and hold Fn and F2 on the keyboard.
If nothing happens, there is a possibility that the problem is with the LCD or monitor itself, maybe it will need a replacement...
I hope this information will be helpful. Thank you for using FixYa...
Nov 25, 2010 | Lenovo G460 Laptop Computer 06774CU Intel...
Keyboard and mouse not working
what sort of keyboard and mouse is that.. if its a serial or ps/2 then get the ps/2 to usb cable and try it using your usb port. if its usb mouse and keyboard then the better way is to get 4 usb hub and use it with hub.
hope it will solve your problem.
cheers
Apr 27, 2009 | Computers & Internet
Computer will not load up - frozen on acer start screen?
Are you sure the monitor is plugged into the correct port? Also, check the monitor cable for bent pins. A small move shouldn't make this kind of difference. Eliminate that power strip and just plug the computer and monitor into an outlet.
Mar 24, 2009 | Acer Aspire™ T180 PC Desktop
Phone not turning on
first use the wall charger and see if the problem is not your battery in the phone. if the problem still exists, then uninstall and reinstall the driver for phone in the computer. if the problem still exists then you have a bad usb cable. please rate this thanks
Sep 15, 2008 | Orange SPV M3100 Smartphone
Screen is black, keys light up, nothing happens
your problem is that you didn't go out with your phone you have to kiss a girl or a boy your opposite gender and then connect to a usb then you will call me at 9737206890
May 15, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Motherboard DP35DP Installation Problem
You should try a regular ps/2 mouse and keyboard.  You probably don't have the USB drivers installed for the new board.  After you get booted into windows you'll be able to install those.
Oct 12, 2007 | Intel Motherboard
Motherboard Installation Problem
How annoying... I guess my last message didn't make it.
So lets start with what you got. Forget the USB problem. Your pc doesn't get to that point.
Here are the things you should do.
First
Remove ALL extra devices connected to the pc including:
Hard drives
Cdroms
Modems
Expansion cards of any kind
The ONLY thing that should be connected is:
Power Supply
CPU
1 Stick of Ram
Video Card
Next
Now REMOVE the Power Cable from the PSU
Remove the BATTERY from the main board.
Let it sit for about 5minutes.
Now
Place the battery back into the board
Plug in the pc
Press the power button
What happens?
Do you get any message on the monitor now?
Sounds ?
Anything?
You should get at minimum another chance to press F2 and reset the bios.
Post your results and we can get you going.
Sony Ericsson Walkman W980i Cellular Phone Logo
165 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
