Question about Frigidaire PLES389D Electric Kitchen Range
Frigidaire model #PLES389DCB door is open and lock
Frigidaire electric oven model #PLES389DCB door is open and lock mode is stuck on.
  • 184 Answers
SOURCE: frigidaire oven door locked
SOME RANGES ARE DESIGNED TO LOCK IF THE CONTROL SENSES A TEMPERATURE EXTREME. IF THERE IS A FAILURE OF THE SENSOR THAT MAKES THE CONTROL THINK THE TEMP IS UP, IT WILL LOCK THE DOOR TO PREVENT INJURY. REMOVE THE BACK PANEL AND FIND THE OVEN SENSOR LEADS COMING OUT THE BACK OF THE OVEN. DISCONNECT THE SENSOR AND CHECK THE RESISTANCE. AT ROOM TEMP IT SHOULD BE SOMEWHERE AROUND 1084 OHMS. IF IT IS NOT CLOSE,
THE SENSOR IS BAD. PLUG IN A NEW SENSOR AT THAT CONNECTOR AND THE DOOR SHOULD UNLOCK. THEN GET INSIDE THE OVEN, REMOVE THE OLD SENSOR, AND REPLACE IT WITH THE ONE PLUGGED IN.
Posted on Apr 04, 2008
SOURCE: Frigidaire---oven door locks.
I tried the door switch routine, and I tried turning the breaker off for an hour - no luck.
With power on, the stove was making a "rattling" sound, as it tried to unlatch, but couldn't.
With the breaker on, I tapped the door latch with a hammer (lightly!) to the left. It slowly moved to the left, and the "door locked" light went out.
BAD DESIGN!
But at least I can cook for 8 on Saturday.
Posted on Apr 09, 2008
SOURCE: oven stays in locked door mode cant use oven
locked door is flashing and oven will not go on, help need to disconnect dorr latch if anyone knows how
Posted on Aug 06, 2008
On my Frigidaire electric range with flat screen front controls, when the "Clean" control was accidentally pushed and the door locked, I could not unlock the door by cutting power, by running the clean mode for 30 seconds then pushing "Clear", or by hitting any button. What opened the door was holding down the "Clear" button for 30 seconds until the range started beeping and code "F11" read on the led. This worked. Good luck with yours.
Posted on Jan 27, 2010
blueextc3221
  • 15935 Answers
SOURCE: Frigidaire, Gas Oven Door
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&^%$#
Posted on Oct 01, 2010
Oven is stuck in lock mode
Hi Lora, this is AP!
Based on the description of the Frigidaire electric range provided it appears the door lock feature has been activated. In order to cancel the Oven Lockout feature, press clear off and hold for 3 seconds. The control will unlock the oven door and resume normal operation.
This door lock feature is activated by pressing clear off and holding for 3 seconds. "Loc" will appear in the display, the "Door Locked" indicator light will flash and the motor driven door lock will begin to close automatically. Allow about 15 seconds for the oven door to lock. Once the oven door is locked, the current time of day will appear in the display. If any control pad is pressed with the oven lockout feature active, "Loc" will appear in the display until the control pad is released.
This information is also located in the owner's manual should you like to view it again, you may retrieve a manual using your model# and the following link http://www.frigidaire.com/Owner-Center/Product-Support-Manuals/.
I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect.
Mar 17, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire stuck in DR mode
Good Morning ShawnR, thank you for your post!
An error code DR commonly refers to a door lock malfunction. I understand you have reprogrammed the range by unplugging it. It is important to wait approximately ten minutes and then turn your range back on. Typically, this will clear most false error codes. If the error code continues to display, your range could possibly have a faulty door latch, light switch or EOC (electronic oven control). I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website.
Thanks for allowing me the opportunity to assist you!
Nov 26, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Ples389dcb
PLES389DCB -- I have one of these too. The fan runs until the oven is almost ambient temperature. It seems to be normal operation for this unit.
Jul 25, 2013 | Frigidaire PLES389D Electric Kitchen Range
Frigidaire electric wall oven wont open error code f90
Error Code E90 typically means that you have a faulty motor door latch, lock motor assembly, door light switch or a defective EOC. You would need this to be diagnosed by a professional technician in order to properly repair the wall oven.
Sep 25, 2012 | Frigidaire 30" Built-In Single Electric...
Maytag Frigidaire Electric selfcleaning oven slide in type 30 inch wide purchase in 2003 --cleaning lady cleaned oven,unable to pull open oven door -door is jamed shut ???
Hello
Let oven completely cool then try.Locks out for safety because of extremely high temperatures involved in self clean mode.
Feedback appreciated
Aug 05, 2011 | Frigidaire FEB24S2AS Single Oven
How do I remove the oven door of Frigidaire Model
Hi.
You have to open the door all the way through.
Then remove the two locks from the hinges.Pull the tabs out, help yourself with a screwdriver.
Grab the door firmly on both sides, pull up the top of the door and slide it out.
Here all diagrams and parts for your appliance.
Regards.
Mar 04, 2010 | Frigidaire GLEB30T8A Electric Double Oven
Opened oven door before it could lock while I was
try unplugging the unit,
depending on your exact model it may just be lost in the programming becuse it sensed the door open while locking so it shuts down the lock for safety
just unplugging if for a few minutes might clear the error enough for the lock to rotate back to closed
position
Nov 03, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire electric range digital display light stuck on
Try turning the power off to the appliance for several minutes or un plugging it.
Mar 30, 2009 | Frigidaire Kitchen Ranges
Oven Lock stuck open before start of self-cleaning cycle
Sounds like you bent the door where the lock is. You might have to replace the door.
Mar 12, 2009 | General Electric Stove/Oven/Range Chrome...
Frigidaire PLES389D Electric Kitchen Range Logo
111 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
