Question about Gaggenau VL051707 Hob Ventilator: AS 081-051 Connecting Element to fit GB 031-707 Kitchen Hood
Is the Gaggenau VL051-707 compatible with any other fans?
And, what is the CFM?
I bought the Hob Ventilator and am trying to find options for the fan (if any). I also can't seem to track downt the CFM for the GB 031-107, which is the prescribed unit. It says it can be mounted remotely (outside wall), but I'm hesitant to put it 20 ft away unless I know it has a decent CFM rating...
  • 2 more comments
  • AustingBear Feb 27, 2008
    FIrst, thanks Master_Tech. I'll mount mine in the crawl space, but away from the kitchen. Do you know if any other fan might work? Something that is not $1200? I was wondering if one of the Bosch units might work. Made by the same company and hundreds less.
  • AustingBear Aug 15, 2008
    BTW, I picked-up a used on (freak-find) for $25. Works great and saved over $1000.
  • axlkix May 11, 2010
    Where do you found a used-on blower for 25$? thank you
  • Gary Davd
    Gary Davd May 11, 2010
    I have one in my house I mounted it in the basement on the floor joist the CFM is 600 you need a 6" pipe to an outside cap I did not want to mount it outside due to the weather and did not want to mount it under thew cabniet due to the noise
  • 770 Answers
Not really due to the wiring you will have to rewire the unit see the power in and control power to the ventlator comes from the countertop unit.. unless you rewire it. See the black molex plug under ventlator that is the connection
Posted on Feb 27, 2008
  • Gary Davd
    Gary Davd Aug 15, 2008
    nice job you can always call around and ask dealers for close outs or distb. sale days get a deal there too
The plastic housing on the ventilator fan can it be removed. the reason I ask is the fan is making a noise and may be it needs cleaning or oiling.
The ventilator fan on what exactly?
If you're talking about a small 4" x 4" fan on a computer, you simply replace the entire fan. Remove the old one, get the part number, google the part number, order new fan, replace fan.
Simple!
Feb 07, 2018 | The Computers & Internet
Hi trying to locate a manual for a gaggenau ci380114 hob
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Mar 03, 2013 | Gaggenau Cooktops
Cooker delonghi professional dfs903 6 ring hob has terible fan like noise whenever you turn the oven on which has now become unbearable and occurs whether using the grill, the oven on fan setting or not....
i had the same problem, the noise is coming from a circular fan located under the hob itself. not from the fan at the back of the oven.its a cooling fan.i bought a new one online around £70 and got a local gas fitter to install it. its a real big job and most if not all of the gas connections to the hob have to be disconnected its a big job.but worth it.
i have the same problem with the door,thats what im looking for.
if i find a solution ill let you know
Oct 05, 2009 | DeLonghi Kitchen Ranges
I have a dayton kitchen exhaust blower mod no. 4hz65, 1/25 hp, 1550 rpm, 115 volts, 1.5 amps, 8 inches. it does not seem to do the job, do i need a stronger one?
Remember air will only move as fast as the size of the exhaust pipe in relationship to the fans ability to push. Make sure yours is the proper size for the fans volume.
Jul 07, 2009 | Dayton Exhaust Blower to vent your grow...
Broan attic ventilator appears not to be working
Did you check to see if the motor was warm or made a noise?
May 19, 2009 | Broan-NuTone Nutone Aluminum Dome power...
Chrysler Vision (Eagle Vision) A/C ventilator works all the time at max.
The problem was in ventilator valve resistor, located below glow box, near ventilator. A transistor replacement did the job!
Sep 01, 2008 | 1996 Eagle Vision
Broken mount attic exhaust fan
buy new blade or keep soaking shaft.collar with rust penetrant,
Jul 25, 2008 | Ventamatic Gable Mount Power Attic...
KES3660
The ventilator fan causes the water to evaporate from the drain pan. There may also be a heater element to do it as well. Without it nothing is making the water evaporate so it is overflowning. Might be the fan motor or the switch that is a problem.
Jun 29, 2008 | Liebherr KES3660 Stainless Steel...
Install a new ststem cooling fan
as i recall, the fan is at the back just under the hob and is removable without removing the hobtop - just held in by 3-4 screws. if i'm wrong and hobtop has to be raised, this is quite easy. take off the side panels and you will see 2 screws each side holding the hobtop on. don't confuse them with the screws which hold the plate retaining bracket in place but it is all quite obvious. as a thought, are you sure the fan is faulty? the fact it is not operating doesn't mean it is faulty. the fan is turned on by a fan stat which may also be faulty.
May 11, 2007 | Belling 644 Electric Kitchen Range
Kitchen Ranges Logo
947 people viewed this question
Top Gaggenau Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Gaggenau Kitchen Range Expert? Answer questions, earn points and help others
