Question about Jenn-Air JS42SEFXDA Stainless Steel Side by Side Refrigerator
Temperature to low reads -75 at times - Jenn-Air JS42SEFXDA Stainless Steel Side by Side Refrigerator
    Sergeant:
    Champion:
  • 263 Answers
That is way too cold. Should be around -10 to +10
It's very common for this fridges to have main board problems. Try to defrost it by unpluging it for 24 hours. There is an on/off switch on top, when you take off that cover by lifting it up.
Jenn-air refrigerator repair in orange county, ca
Posted on Feb 06, 2010
When your pressure is132 youe heart rate is 75 and puls is 75 what tha mean
I am thinking what they meant to say was that your blood pressure is 132 over 75 and your pulse is 75. Blood pressure has two readings, a high and a low one. If this is the case, your blood pressure is fine and your heart rate (the number of times your heart beats per minute) is also fine!
Mar 31, 2017 | Health & Beauty
How do you read the transmission dipstick it only has 25 c and 75 c
I think those must be temperature marks. If I am right, 25 c would be the transmission fluid cold temperature, and 75 c would be the fluid hot mark or level.
Sep 03, 2013 | 2004 Kia Sedona
How do you tell if a goodman ck36-1b has proper level of freon.Lets say it is 75 degrees outside and I added to where the low side reads around 30 and the high side is around 120-130.(orignal problem was...
The correct way is to evacuate the system,pull a vacuum then charge with a refrigerant scale.
In lieu of that you can charge by pressure and get close.
Normal operating pressure would be 68 psi on the suction side and about 225/275 on the high side.
You do have to calculate the outdoor and indoor ambient temperature.
At your 75 degree outdoor air a low side pressure of 60 psi or higher would be acceptable.
Your 30/130 is too low.
Add more refrigerant.
Make certain the indoor coil is clean and the fan motor is working correctly.
Have the leak repaired.
Apr 25, 2011 | Heating & Cooling
The oven stopped working and had error F3 on the screen. We unplugged and waited then it worked for about 1/2 hour and stopped with the same message. What's wrong
Sorry to read about your problem, I hope this helps you out.
Oven temperature sensor open
Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luckSorry to read about your problem, I hope this helps you out.
Dec 26, 2010 | Hotpoint RVM1435 Microwave Oven
The temperature of the large oven is low by about 75 degrees F to the readout . Can this be adjusted?
check the oven tempreture sensor do an ohms test on it at room tempreture should be reading 1100 ohms if it were less then you would replace the sensor if the sensor is at or around 1100 message me back there are a couple other things that you could also check thanks again
Rick
Dec 18, 2010 | Dacor Epicure ERD36 Dual Fuel (Electric...
Set at 75 but stays at 80 and won't cool down until night time.
Sounds like you're low on refrigerant. You might try to measure the room temperature and the temperature coming out of the grill. The temperature coming out of the grill should be about 20° lower than the room temperature. For instance if the room temperature is 80°, then the temperature coming out of the griil should be about 60°.
May 07, 2010 | Honeywell Electronic Programmable...
Change the digital read out for time and charge.
There are actually two hidden buttons that you cant see below the start button... Change the amount to what you prefer and press the hidden button across from the low temp. button twice.
Hope that helps, Mike
Nov 19, 2008 | Dryers
Ge stove
Replace the temperature sensor inside the oven cavity. It looks like a small metal rod. Be aware you will never get an accurate temperature reading with those cheap 5 dollar things. After the oven is preheated, you must wait 10 minutes and take a reading. Some models have a temperature adjustment, it's listed in the owners manual.
Oct 28, 2008 | GE JBP69 Electric Kitchen Range
Jenn-Air JS42SEFXDA Stainless Steel Side by Side Refrigerator Logo
91 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
jasbo
jasbo
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
