Question about Refrigerators
The freezer has quit freezing. The refrigerator
The freezer has quit freezing. The refrigerator part works well. Is there a seperate fuse or what should I check for to correct the freezer not working?
    Sergeant:
    Champion:
  • 263 Answers
Your refrigerator 100% depends on the freezer (unless you have a sub-zero brand fridge, that has 2 compressors). So your fridge will be warm soon too. There is no fuse in the fridge. Try unplugging it for 24 hours and see if that helps, otherwise it's better to call for service.
Refrigerator repair orange county, ca
Posted on Feb 06, 2010
Why did my refrigerator quit working but the freezer side still works?
Your freezer is probably froze up with ice. Pull all your food out of it and shut off the refrigerator. this will let the coils warm up and melt the ice.on the freezer coils. There are coils behind the freezer that freeze up up. I ran a hair dryer in there freezer on low for a few hours to speed up the process.
Aug 06, 2014 | Whirlpool Refrigerators
My top freezer of my refrigerator is not cooling
you first need two know if you have a single compressor or two seperate ones seems like you have two seperate ones eather the freezer compressor has died or the thermostat or freezer compressor needs re gasing
Aug 14, 2012 | Kenmore Refrigerators
Freezer is freezing about 25 degree,but the ref. will not get below 40 degree.
It's quite normal if freezing is not reach on 40 degree, it's already high temperature. Remember the lower the temperature setting the higher the freezing of refrigerator, the higher the setting the lesser the freezing.
It's simple as that friend. Good luck!
Jun 12, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer compartment freezing too much even when fridge turned down to 1 - how can we turn off freezer compartment as doesn't seem to have a seperate control Thanks
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Apr 21, 2011 | Refrigerators
We have had sears tech's here 3 seperate ocassions. They replaced a circut board, thermostat, and heater on 3 seperate occasions. Today I noticed the refigerator getting warm, looked and the freezer side...
you have an airflow problem in the freezer. Is something blocking the vent in the freezer compartment? cold air is produced in the freezer section and flows to refrigerated side through air vents. If they are blocked, the air cannot flow from the freezer and it will freeze over. Not a major problem, just move your stuff around.
Nov 24, 2010 | GE GSH25JSTSS Stainless Steel Side by Side...
Freezer portion doesn't freeze.
check settings. if good check if compresor is running. a relay on compresor could fail
Feb 10, 2010 | Maytag Admiral Top-Freezer Refrigerator
Ice maker freexes ice together
maybe too much water going in to the ice maker
Jun 30, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
FRIDGE COMPARTMENT FREEZING
try this,make sure you dont have anything blocking your blower in the freezer.if that is okay if you have seperate controls for the freezer and the fridge,try setting the frige setting lower and the freezer higher,this makes the blower work more in the freezer.hope it helps.
Dec 06, 2008 | Refrigerators
Freezer on the bottom model # PBF2555HEW Freezer works refrigerator not cooling at all
We let the fridge thaw for two days, cleaned it from top to bottom especially the coils and underneath. We moved it outside and used an air compressor to blow out the dust and dirt around the coils so nothing was damaged in the process. It works like a charm and probably more efficiently too. Before it had quit working it was freezing in the refrigerator part. So that was an indicator something was clogged. Moisture that collects and freezes blocks the air from circulating. The freezer worked great! But ice cream was too hard.  Now it's just right.
Apr 06, 2008 | Maytag MBF2256H Bottom Freezer...
Open Questions:
Refrigerators Logo
81 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
