I have a turbo elite 4 burner built in grill --I have built a ramada above the grill-- The bottom of the roof is 6ft from the grill --My inspector is not passing this grill and ramada because in your manual it says that there are to be no structures above at all !! --- I installed metal sheet panels above grill --per your managers suggestion at store in Tucson -- It did not pass he said I need something from the manufacturer , giving a height limitation or giving sheilding metal specs -- I have spent alot of money buying all of my kitchen --$ 3,200.00 with you guys and I am hoping that you can give me some answers on what to do with this problem !-- Thank You Neil Bentley --Tucson AZ
CHECK WITH "THIS OLD HOUSE " WEBSITE , THEY HAD A SIMIALAR ISSUE WHEN PUTTING IN A RUMSFORD FIREPLACE IN A RENOVATION THAT HAD A WOOD BEAM AS PART OF THE STRUCTURE. INVOLVES MONITORING TEMPS OVER A PERIOD OF TIME FOR TOLERANCES .IT SOUNDS LIKE YOUR INSPECTOR IS NOT WILLING TO GIVE YOU ANY HELP, POSSSIBLY CHECK WITH YOUR FIRE MARSHALL TO SEE IF HE CAN PROVIDE SOME INSIGHT AS TO HOW TO SOLVE THE PROBLEM.
Was this helpful?
Yes
No
Popular Solutions for Barbeques Galore Turbo Elite
Barbeques Galore Turbo Elite 4-Burner with Rear Burner...
the heating element keeps flickering on and off. what should i do? i have a charbroil smoker given...
(More)
the heating element keeps flickering on and off. what should i do? i have a charbroil smoker given to me by a friend but don't have the manual for it.
I have a 3 burner jenn air with the ''lifetime'' brass burners. In the 3 years that I've had it I've...
(More)
I have a 3 burner jenn air with the ''lifetime'' brass burners. In the 3 years that I've had it I've had to **** out each little flame hole with a drill bit anually. The brass is coroding and clogging the holes. I'm somewhat disapointed with the performace of this grill. I keep it covered but the burners continue to corode and burn unevenly and not as hot as I would like. What is there to do?
I have a 25# smoker that is propably about 25 years old and when I plug it into a GFI electrical...
(More)
I have a 25# smoker that is propably about 25 years old and when I plug it into a GFI electrical outlet after about one minute it blows the GFI. What's my problem !!! Thank you Kerry
I have a Town & Country fire place with a MAESTRO Control System which includes a wall...
(More)
I have a Town & Country fire place with a MAESTRO Control System which includes a wall control and hand held remote. There is a red light flashing on the bottom of the wall control under what appears to be a battery picture - but I'm not sure it is a battery. Since I can't get my fireplace to turn on, would I be correct that I need to change a battery somewhere in the switch? The fireplace won't work using the remote either. The instructions that came with this $7000 fireplace do not mention anything like this!
