The tv clicks for a long time before starting. When I turn it on, it tries to "turn on" and clicks for about 2 dozen times before it actually turns on.
techman
  • 3130 Answers
SOURCE: RCA light comes on and then goes off. Tv doesn't turn on
Is this your set?http://tv.rca.com/NR/rdonlyres/A2ED8EB5-A0AF-401F-A380-3CB61D5EBEB1/0/D52W20_222Chassis.pdf If it is, there could be a bad solder connection in the start up power supply or there is a resistor that will get loose or change value. It gives the power supply the start up pulse from the flyback transformer. there are no user replaceable parts inside this set, and the longer you wait to get it serviced, the more its going to cost. Unless you have a service manual and understand how the SMPS works, please play it safe and call in a pro to assist you in this repair. Good Luck Please do not forget to rate this thread.
Posted on Dec 09, 2006
  • 81 Answers
SOURCE: TV turns on......eventually
check for a bad cap ,relay sound ok or could be a bad solder connection in the power supply at the regulators
Posted on Dec 15, 2006
SOURCE: RCA D52W20 cold start issue?
i am looking for an owners manual for the d52w20, can anyone help me out here.
kimmipoo_2000@yahoo.com
Posted on Jan 18, 2008
  • 3 Answers
SOURCE: TV Will Not Start Occasionally
I was having same problem, then on 4/4/08 it went out with just a blue screen, with no signal, then it would turn itself off in about 4 seconds! Not to happy here! its 3 months out of warranty so no help from vizio. my buddy had the same problem a month or so ago with same tv GV42L HDTV. if your handy you could do it yourself, like i will when part gets in. saving some money! its the main board ***'y you can look it up at vancebaldwin or shopjimmy.com. i would just keep using until the screen goes blue. Hope this helps
Posted on Apr 05, 2008
pauman
  • 248 Answers
SOURCE: Clicking noise when turning on the tv. Everything works but the clicking.
When you turn your tv off turn it off using the remote control then turn off the tvs switch itself... Try this for a few days hope it works for you.
Thanks.
Posted on Jun 22, 2008
How do I turn web guard off a metro pcs phone
try this if can help you
1. Re: How do I turn off "web guard" I keep getting an error message and it says to try again. I have tried a dozen times.?/
gramps28 Super Citizen Silver
gramps28 Aug 15, 2011 2:12 PM (in response to danielmccullough@msn.com)
To disable Web Guard, perform the following steps:
1.After logging into My T-Mobile, under Manage click Your profile.
2.Next to the Phone controls section, click the Edit link.
3.Click the link on the line of the phone number which you would like to turn Web Guard off of by clicking the Turn OFF link.
4.Click the Save changes button when finished
goodluck
Jul 04, 2014 | Cell Phones
Sanyo Clicking/Ticking Sound
That is caused by the insulation on the EHT cable or tripler leaking.
Jun 12, 2017 | Televison & Video
2000 mercury grand marquis 4.6 fuel
Voltage drop test the electrical circuit , do know how to do automotive electrical testing . Lose connection , resistance in the circuit , lose ground Mastering Voltage Drop Testing with Pete Meier and Jerry Truglia Testing Electric Fuel Pump Problems with Voltage Drop Test
Feb 27, 2017 | 2000 Mercury Grand Marquis
I have a '96 samsung 25" tube tv. model # TXE2546 - series # 3CAG700429. when i turn it on it has always made a click sound a couple of seconds afterwards. the "power & timer" led light flashes about...
This problems the FBT-the Flyback Transformer have cold solders.Must resolders the FBT.The right side wall of the FBT-the "H" horizontal transistor,must be also resolder too.
Oct 18, 2010 | Samsung TXJ2754 27" TV
Press on button but it clicks a dozen times before it turns on
If green and or red lights are flashing while the TV trys to start the lamp is burnt out, time to replace.
Apr 29, 2010 | Toshiba 52HM95 52" HDTV Projection...
Subaru starting problem
Just a sugestion: Replace the relay turns you inition on, usualy in the fuse box or in the engine bay
May 13, 2009 | 1999 Subaru Legacy
Sony FD Trinitron WEGA KV-24FS100 24" TV On/Off problems
I have spent about 4 hours tonight researching several tech sites and the Sony service manual for the same problem with my Sony KV-32HS510 unit. I was able to download the manual from a website http://www.eserviceinfo.com/downloadsm/31649/Sony_KV-32HS510.html and a TV Repair training lecture paper at http://www.repairfaq.org/sam/tvfaq.htm#tvhvp .
These TV sets have a safety feature where it will shut back down if a high voltage is indicated. Unfortunately, the electronics for these safety features are not very reliable and give false indication. Letting the unit sit off lets the capacitors leak voltage as well as cool off. These two factor help with the unit not falsely indicating a high voltage condition.
The D Board seems to be the most common failure component, but a 6 times flash could be an overcurrent/voltage failure from the A, B, or M boards. A 7 times flash is a Horizontal Deflection Stopped error with no additional information given in the manual for a fix. Again, in most blogs, the D Board seemed to the source of the failures.
A refurbished D Board part no. A1300319A can be bought for around $200 with a new board at $550 per the www.partstore.com site. Then add $100-$200 for an actual TV service technician and you have a repair bill approaching the costs for a new flatscreen TV.
Some tech types posted that they have actually repaired their boards by replacing individual components for around $40. You may find a service shop that can do the same component level repair at the $100-$150 level cost. It turns out that the closest authorized Sony repair shop is 2-1/2 hours away from us. Good luck finding someone close by.
We were able to get our TV to come back on after dozens of attempts and plan to leave it on until it dies all together. I may attempt my own D Board replacement when the time comes.
Dec 14, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Doesn't turn on
Pretty good chance the power supply board is bad. A number of capacitors will become leaky and you lose all power. Some techs still know how to do component Laval service but most just change the board $$$$
Jul 10, 2008 | Polaroid FLM-2601 Television
Sva-usa vr30
I've experienced the same problem with my VR-30 and what worked for me was I actually unplugged the power from the TV, waited about twenty seconds and then reconnected and when I turned it back on it worked fine. I've had my tv for about 2 1/2 years and I've had to do this probably a half dozen times so I've gotten used to it. Hope it works for you too.
Apr 02, 2007 | SVA-USA VR30 30 in. HD-Ready LCD...
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
