Question about Samsung SyncMaster 731B 17" LCD Monitor
Blue power light blinks and the monitor will not come on.
  • 11,361 Answers
Look for bad caps with bulging tops in the power supply first, report back what you see so we can guide you further, see example of failed SAMSUNG due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Posted on Feb 08, 2010
Samsung syncmaster 2220 blinking blue light and no image display
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 26, 2014 | Samsung SyncMaster 2220WM 22" LCD Monitor
I have a hp w2207 flat screen monitor. when turning power on, power blue light blinking and no picture. what can I check or look for to find and fix the problem?
That blue blinking light could be the fact that there is not a signal from the PC to the monitor itself. You could have lost your video card, corrupt driver for video card or monitor. If you have a PC with separate video card and a mother board video output, try switching to the one you are not using and rebooting the PC
Jun 12, 2014 | HP Computers & Internet
L246WH blinking light problem
Probably the power supply is failing but periodically recovers briefly.
Jan 05, 2014 | LG L246WH-BN Monitor
My monitor does not turn on and the power button light keeps blinking ... <my Gateway monitor light blinks blue slowly but the screen is blank
This is usually a sign that there is no signal going to your monitor, check all your cables and then reboot.
Jun 28, 2010 | Gateway FPD2275W LCD Monitor
Blink s blue light envision g218a
The blinking blue light indicates your power supply has blown out. The heat buildup in the case has caused parts called capacitors to blow and short the power supply causing the blinking. We offer a repair service for $30 plus return shipping. If you wan to do the repair yourself you will need to open the back of the monitor and look for the bulging capacitors. To see what the bad capacitors look like go to our site at: www.ccl-la.com Replace any bulging caps that you see and you should be back going. You will need to use high temp capacitors marked 105c. If you have any questions about the repair or repair service just let us know at the address below.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Dec 07, 2009 | Envision G218A1 22 inch Monitors
VL 1919 power button blue light blinks and screen
Yea I fixed it ..bought a new monitor......I tried the old monitor on two other PC's same problem.....
Nov 23, 2009 | Computers & Internet
Power Light Blinking & Black Screen
A blinking blue light indiactes that your power-inverter board is not putting out what it should. It needs an overhaul which may be a simple as changing out the capacitors on the boards.
It could go beyong that to transistors or even a bad bulb.
It will have to be opened up to do that.
A picture may show visual signs of damage. If you can take one and email it to me , I'll take a look.
Fran
Oct 18, 2008 | HP vs19 (Silver) 19" LCD Monitor
LCD Monitors x7g troubleshooting
Check some of the other posts as it is probably just a bad capacitor or two and very easy to fix if you can do that sort of thing. I did and mine is back up and running.
Jan 05, 2008 | Sceptre 17" LCD Monitor
Samsung SyncMaster 731B 17" LCD Monitor Logo
219 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
