Question about Philips HTS3500S System
I have a problem with philips hts 3100/05. audio suddenly stopped whilst watching t/v, audio still seems to work whilst playing dvd disk
eagle338
  • 4889 Answers
SOURCE: philips hts 6510 no disk prompt does not play dvd
Ok looks llike a lens problem..Try this
Get a lens cleaner CD with liquid..Put two drops of liquid on the brush of the lens cleaner..insert the CD in your drive and play it..If it plays fine otherwise you will need to replace the lens..Get it replaced rather..should run you about 25-50$.If you want to get it repaired give it for repair only in a Philips showroom..
Posted on Oct 15, 2007
SOURCE: Unlocking code for Philips HTS 3500s DVD
any unlock codes for Philips HTS3544??
Posted on Aug 13, 2008
has worked fine but now doesn't play any dvd. comes up with 'no disk' on tv monitor. please help
Posted on Oct 12, 2008
SOURCE: HTS 3300 - No Disk Error
i had the same ploblem sometime last year and all i did was to put a cleaning disk(the ones with a cleaning brush on) in it a couple of times...and it works fine since then!
Posted on Jan 04, 2009
jell587
  • 447 Answers
SOURCE: I'm looking for the region cod, the Philips HTS 3544
TURN ON THE PLAYER
PRESS OPEN/CLOSE
USING REMOTE PRESS STOP-7-3-4-4-6-6
YOUR REGION AREA WILL APPEAR. PRESS "0" TO UNLOCK ALL.
Posted on Feb 19, 2009
RECENTLY I HAVE BOUGHT A PHILIPS HOME THEATRE MODEL - HTS 3265 . ONE DAY I WANTED TO PLAY STAR WARS MOVIE DVD INTO IT. BUT NOT OPERATING.IT IS SHOWING REGION AND STOP PLAYING. PLEASE GUIDE ME FOR THIS...
HI,
ur dvd player has region lock . it will not play all the disk. check the DVD OF STAR WARS MOVIE which region it belongs. jus try the following not sure is it work or not
Open the tray. Press 99990 on the remote.
by doing this ur dvd player will become region free
then insert ur dvd and try.
for region 1 and region 2 code is 99991 ,99992 respectively.
feel free contact through fixya.
ok
Dec 21, 2010 | Philips HTS-3565 Theater System
Can I connect a blu-ray player to the hometheatre system?
Technically, yes but not so it would yield BD-quality audio or video. You need a control receiver that accepts either HDMI/DVI INPUT for 720I and above video. The digital audio in will probably suffice.
Jun 14, 2010 | Philips HTS-3555 System
On one particular DVD (UP from Disney/Pixar) a certain section keeps repeating. When I stop the DVD to try accessing the root menu it freezes up and the entire sound bar locks. The only way to resolve this...
Those discs have a very strong copy protection mechanism to avoid making digital copies on PC systems but some DVD players won't play them because of that, if you have the original movie, download a copy from the internet, burn it to a dvd-r disc and play it. It's perfectly legal because you already bought the movie. The downloaded copies have no copy protection and will play better than the original.
The PHILIPS DVD-Home theater players are specially picky about non-standar disk like the one you're trying to watch.
Jan 12, 2010 | Philips SoundBar DVD Home Theater with...
Plays cds not dvds
Hai,
This is is due the lense and motor section problem, to resolve this issue you need to replace the lense and motor set.
Feb 11, 2009 | Philips HTS-3555 System
Region code
I have a region Code For A Philips HTS-3544 which is 1 model Down. You can try it, it may work or it May Not.
Heres How:- power on the TV/DVD without any disk in the player.Press open/close eject.
Press Stop 7.3.4.4.6.6 ( on the Remote )
The menu code appears On The Screen.
Press 0 for region Free, or the region Code Required.
Power Off and then on Again, if the codes have worked, your dvd player is now region free.
If this works please rate as Fixya.
many thanks mike @ Compurepair.
Aug 28, 2008 | Philips HTS-3555 System
Aug 07, 2008 | Philips HTS3500S System
Philipe home cinema - No Disk Error
Hi, the best thing to do is to reset the device back to factoy settings, how to do that is mostly written in your manual. Also unplugging the power for 5 to 10 minutes might help.
Aug 07, 2008 | GE MA90559 Rear Speaker
How Do I Hook This Thing Up?!?
See what audio outputs your tv has. See if your HTS has matching inputs. If it does connect them with the proper cable(s). Connecting to the tv should cause your HTS to work with anything you are watching on the tv.
May 15, 2008 | Durabrand STS92 System
Philips HTS 6500 not reading my DVD's
I bought this item in Nov. of '07 and it worked great...for about 3 months then the dreaded no disc message appeared and has ruined my life. Howvever after not using this DVD player for a month or so i had decided to tinker with it to try and get it to work and it appears i have found a solution that is working for me so far. After being fed up with Philips and trying their "solutions" because as we all know the U.S. sells DVD's with the wrong region code (ha funny Philips people) i began trying to make this stupid peice of garbage work in any way. What i came up with is this: 1.) insert your DVD and wait to see what happens. When you get the no disc readings this is what you do. 2) Eject the dvd but do not touch it 3). While the dvd is sitting in the slot press and hold down the play button on the remote control and continue to hold it down 4) it may take awhile but give it a chance, and hopefully the DVD will "resume play" and start anew. If holding the play button down does nothing then try holding it and releasing it in intervals until something happens. If nothing ever happens then i guess you SOL. I know this is not an desired fix to the problem but so far it has worked for me. I noticed this because the stupid thing will would read a cd and this got me thinking. This way is kind of a jump start to get the dvd going....hope this helps someone
Feb 20, 2008 | Philips HTS-6500/37 System
Philips hts 6510 no disk prompt does not play dvd
Oct 15, 2007 | Philips HTS-6500/37 System
Philips HTS3500S System Logo
171 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
