Question about Kenmore 23313 Whispertone Bagged Canister Vacuum
The beaters wont turn
The beater bar wont turn
  • 701 Answers
You need to replace the belt. Here is the belt you need:
Kenmore 23313 Belt
Posted on Feb 06, 2010
My Dyson vaccum leaves a row of multiple lines on my plush carpet. I've never had s vaccum leave more than the two wheel lines. I called customer service and they had no solution for me!
It's the beater bar brush. Turn it over and use a screwdriver or knife, and run it the full width of the beater bar to remove the hair and string and other debris that get wound up on the beater bar-NOTE you do NOT have to remove the beater bar or take apart anything. As long as the beater bar spins, and there are no missing sections on the beater bar- this will work. Beater bar could also be worn down- be sure that the bristles extend past the bottom of the vacuum- ALWAYS DO THIS WITH THE POWER OFF
May 03, 2017 | Dyson Vacuums
Beater bar wont turn replaced belt didn't fix the problem
you may have to take the beater bar off and clean out the hair,and string off of both ends, thats where the bearings are.
Jun 21, 2015 | Eureka 5856BVZ Boss Bagless Upright...
I have strong hose suction but none below and beater bar is not turning
Beater Bar Belt Likely Broken--Can Be Checked By Removing Cover(s) Next To Beater Bar (on bottom)
Feb 27, 2015 | Dyson DC33 Multi-Floor Upright Bagless...
My XV 11 Vacuum keeps on bringing up the message " My vacuum is stuck"
This message generally means that the beater/brush bar is not turning. Try rotating the beater/brush bar manually to see if it can turn freely. If not, you will need to remove the beater/brush bar and ensure that it is clean; that the orange end caps on the brush are free of hair and dirt, and that the bar housing area is free of obstructions.
Note, when I said "beater/brush", it could be either/or, depending on whether you're using the "standard" beater bar, or the upgraded pet brush.
May 31, 2014 | Neato XV11 Vacuum
Installing new belt
+>> Unplug the mains lead from electrical socket <<+
• Turn cleaner over in flat position.
• Release lower plate by rotating the 3 lower plate latches to the UNLOCK position.
• Remove lower plate and remove any dirt that may exist in belt area.
• Remove beater bar by gripping the belt side of the beater bar and carefully lifting it out.
• Remove worn or broken belt.
• Clean beater bar and the end caps.
• Loop new belt around motor shaft and beater bar belt groove.
• Reinstall the beater bar by inserting the end cap of the beater bar to the slots at both ends of th beater bar.
• After reinstalling the beater bar, turn it by hand to make sure that belt is not twisted or pinched and that all rotating parts turn freely.
• Reinstall lower plate by hooking front end of lower plate into slots on front of nozzle.
• Press lower plate onto nozzle and secure by rotating the 3 lower plate latches to the LOCK position.
Jan 12, 2013 | Panasonic Mc-Ul594 Eco Max - Bagless...
The brush on my Electrolux Versatility will not spin. You can spin it by hand, but the motor will not spin it.
Hello, W/D here.
Since the brush will not spin, but the motor works, either the belt has come off of the motor shaft, the belt is worn past it's useful life, or the beater bar has seized.
1. Turn off the power (unplug).
2. Remove the bottom plate. With the plate off, use your finger to test the tension of the belt. It should be tight, and roll when you roll the beater bar by hand.
3. Remove the beater bar and belt. Inspect the beater bar, particularly by the bearings. Remove any twine, hair, etc.
4. Inspect the belt for abnormal wear. If there is any significant wear in the belt, replace it.
5. Reassembly is in the reverse order. Place the belt on the beater bar. While holding the beater bar close to it's position, place the belt on the motor shaft. Rotate the beater bar bearings to their proper position and install the beater bar. Replace the cover plate.
Best regards, --W/D--
Jan 29, 2011 | Electrolux EL8502 Versatility Bagless...
Hello. i only have one arm and am trying to figure out why my beater bar wont turn on my dyson dc14. the belt smells a little too. thanx, trixie
Sounds like the beater bar is frozen in place. This sometimes happens when the ends of the bar become stuck in the holders. The solution is to remove the beater bar and clean the small holders on each end removing any debris that has built up. Spray with a little WD40 and then manually rotate the beater brush around the holders until it is free, then replace. Be sure the belt is installed properly.
Sep 09, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Vacuum won't pick up any dirt - there's no roller marks when vacuuming carpet. Roller does turn and filters are clean.
When you turn the roller, you should feel some resistance from the belt. Remove the base blate that surrounds the beater bar. Check the belt. Take care in removing the beater bar, so you can get it back in the same way it comes out. Clean the beater bar while you have the bottom open. If you remove the beater bar to replace the belt, take the time to inspect the cavity behind the beater bar where the vacuum picks up. That is where vacuums usually stop up. Reassemble the vacuum. If necessary, slip the belt over the motor shaft and then slide the roller undre the belt. Install the beater bar back in the sockets and replace the base plate.
Best regards,
--W/D--
Aug 12, 2009 | Dyson DC14 Bagless Upright Cyclonic Vacuum
Vacuum turns on and suction in hose works, beater bar won't turn
If you hear the motor in the head running and the beater bar isn't rotating, you probably need a drive belt. With the power off, make sure you can rotate the beater bar freely by hand, if it isn't bound up.. then locate and remove the baseplate screws to gain access to the beater bar itself, you'll see a drive belt pulley system and chances are, a broken belt. Replace it with a new one by pulling the beater bar assembly out of the housing and plcing the belt onto the motor shaft pulley as well as the beater bar pulley.. nest the beater bar back into the holder and reinstall the cover. Hope that helps !
Aug 14, 2008 | Eureka Vacuums
Kenmore 23313 Whispertone Bagged Canister Vacuum Logo
214 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
