Question about Gigabyte GA-7VKML Motherboard
System shuts down at times. May take several times to try and reboot. When I try to reinstall windows with a CD Recovery Disk, I get an error which says Bios ACPI not comliant and will not go any further. Have installed new power supply, have run chkdsk which shows no errors, have installed new memory.
    President:
  • 2,351 Answers
Enter you're bios and disable ACPI. Wait until you have at least SP2 installed before enabling ACPI. While in the bios open, Hardware Monitor & MISC Setup. Watch the CPU temp. See page 53 in you're manual.
You're system shutting down may be caused by the CPU over heating. This is a safety feature for all MBs. Suggest that you remove the CPU heat-sink assembly from the CPU. Check the thermal past / tap. If it is dried or cracked replace. Remove the old using house hold alcohol on a clean rag. (Not dripping wet). At this point there is no need to remove the CPU. Clean the CPU's fan and blow out any dust build-up within the assembly. The heat build up will cause you're system from booting untill the CPU cools. This is why it seems to take awhile for you're system to boot.
Link to Gigabyte GA-7VKML manual; http://europe.giga-byte.com/FileList/Manual/motherboard_manual_7vkml_e.pdf
Gigabytes main site for GA-74KML;
http://www.gigabyte.com.tw/Support/Motherboard/Manual_Model.aspx?ProductID=1306
Cheers'
Mike
Posted on Feb 06, 2010
Boot cd acer AX3400-B3802
What operating system is on this machine ?
What do yo see after booting up ?
1. If it is not booting up and you do not see the selftest screens and it gives a number of beeps then shuts down: count the number of beeps, that can tell you what is wrong.
2.If it is finding a harddrive but then gives a black screen which says something like "operating system not found, insert disk" or "grub error, run grub recovery" then you might need a cd or usb drive to boot from.
You might try Acer's e-recovery if you had that on your computer:
https://www.youtube.com/watch?v=H2xoMEPfiPQ
Else look here for Win 7 answer:
http://www.tomshardware.co.uk/answers/id-1751047/copy-boot-disk-win.html
Note on the link to Microsoft the answer of Andre da Costa.
At a friends computer:
1. download the iso
2. burn a cd disk using the program Imgburn as Andre says.
Then run it on your computer:
NB. you might first need to change the boot order in the BIOS, press DEL or F10 (the right button is displayed during the selftest on screen somewhere) find BOOT ORDER or POWER UP ORDER in the BIOS and put CD drive in first position
Look here for what to do:
http://windows.microsoft.com/en-us/windows/what-are-system-recovery-options#what-are-system-recovery-options=windows-7
open the 3rd option:
To open the System Recovery Options menu using the Windows 7 installation disc or a USB flash drive, or a system repair disc.
If you have reinstalled the operating system and Microsoft Genuine Check gets bothering you: call Microsoft support and explain that you had to reinstall due to harddrive failure, you will be given a new key for your windows. I have done so several times after hardware failures and reinstalling, they always have given me a new key. But you will have to make clear it was due to hardware failure, f.i. new motherboard, harddrive failure.
Jun 28, 2014 | Acer AX3400-U3032 Desktop - Black...
Missing or corrupted system 32 wont install off windows xp disk
try going to the bios and change the boot sequence for hard drive to cd
put the copy of xp in the external hard drive and reboot the computer
when it powers up it should boot up off the external hard drive
if that works go to computer --device manager and find recovery section
you may also go restore to a previous date and try for a fix from there
go google and get to microsoft and find that file download for xp and install it
if all that works shut the computer down and reboot back to bios and change back to reboot from hard drive
remove the disc from the external hard drive
Mar 13, 2017 | Compaq Mini 110c-1001NR Notebook
When the computer boots, it display bluescreen
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.If after running the Check Disk Utility you still have problems you will probably need to reinstall windows. Look into doing a Repair Install so that you don't lose your data.
Apr 24, 2012 | HEWLETT-PACKARD 630 Notebook
Igxprd32 error
Apr 13, 2012 | Computers & Internet
My computer went to a blue screen and says fatal system error the initial session process terminated unexpectantly with a status of 0x00000000 (0x0000034 0x0010037c). The system shut down.
Dear Sir,
Please have the problem solved by having the system
repaired. This is actually being caused due to a corrupted
or missing system file. Please have the instructions to
having it repaired
Repairing Windows XP using CD installation
The CD installation for windows XP allow you to repair windows whenever there is file missing or corruption or improper function of Windows. This tips can be useful before you opt for a complete format to your computer.
Your first step is to boot the computer using the cd installation.
Below message will display:
Press Enter to setup Windows and accept the license agreement. Then select the XP installation you want to repair and then press R. 1wq9asrj-2-s-.png
Windows xp will copy necessary before reboot. You will be asked to press any key to boot to the CD. nzlmbj8t-2-s-.png
Do not press any key. Windows will boot to installation screen automatically and start installation.
After installation, enter the CD key (windows registration key) to finish repair.
You can now remove the cd from the cd drive and reboot the computer for appraisal
Jul 14, 2011 | Dell Inspiron 1525 Notebook
I need to reboot my laptop
To reboot it just shut it down, take out the battery and the charger for 15 minutes and start it up again.
To return it to factory setting you need to reinstall Windows. Either use the recovery cd that came with the laptop or any other Windows install disk: put the disk in, reboot, a window will appear asking you to choose the boot device so select the cd and follow the instructions on the screen.
Mar 14, 2011 | Acer Computers & Internet
Acer 5100 Vista Boot up issue
sounds like you need to reinstall the operating system. if you don't have the disk you can call acer and they will send you the disk. they might charge you for the disk usually between $15 and $30.
Mar 01, 2009 | Acer Aspire 5100 Notebook
How do I...
NTOSKRNL.EXE is missing or corrupt.
Related errors:
Below is a listing of the full error message that may be related to this error.
Windows NT could not start because the below file is missing or corrupt:
C:\Winnt\System32\Ntoskrnl.exe
Cause:
Keyboard issue
Miscellaneous corruption
Corrupt boot.ini file.
Missing boot.ini file.
Missing or corrupt ntoskrnl.exe file.
Windows NT installed on a partition bigger then 7.8GB
Corrupted hard disk drive or severely corrupted Windows.
Solution:
Keyboard issue
This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer.
Make sure the line pointing to the operating system and it's drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
Microsoft Windows XP users:
If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648.
Microsoft Windows NT and Windows 2000 users:
To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
Boot the computer with your Windows NT three setup diskettes or the Windows 2000 setup disc.
In the setup menu, type R to start the repair.
When prompted for the ERD diskette insert the diskette and inspect the startup environment.
If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
Select the operating system you wish to fix, and then enter the administrator password.
Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
Type exit to reboot the computer.
If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the
error message as shown below.
OS Loader v4.01
Disk I/O error status=00000001
Windows NT could not start because the below file is missing or corrupt: winnt\system32\Ntoskrnl.exe
Please reinstall a copy of the above file.
If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
Once at the recovery console type chkdsk /r
Once completed type exit and see if issue is resolved.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186.
Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
Oct 09, 2008 | Dell OptiPlex GX110 PC Desktop
I do not know how to use my product recovery disk on my toshiba satellite
Insert the Toshiba Product Recovery CD and turn on the system while holding down the C key. This will allow the system to boot from the CD. Select either a Complete Recovery (this recreates all the partitions and formats each one, this may reboot the system several times depending on the size of the HDD and the number of partitions) or Standard Recovery (this just formats drive C:). This will then restore the operating system as shipped from the factory. A Toshiba Tools and Utilities CD is supplied for reinstallation of drivers and utilities without reinstalling the complete operating system.
Jul 16, 2008 | Computers & Internet
Gigabyte GA-7VKML Motherboard Logo
109 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
