Question about Samsung SyncMaster 204T Monitor
I have a SyncMaster 204 T that the back light wont always light
I have a SyncMaster 204 T that the back light is starting to not come on when i turn on the switch. You see the image or portions of the image for a second and then it goes black. If you try turning it on and off enough it eventually lights. Can this be repaired? Are their backlight repair parts?
  • 11,361 Answers
Look for bad caps in the power supply first, see example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
report back what you see so we can guide you further.
Posted on Feb 08, 2010
Apple Cinema Display LCD Monitor on pc wont turn off properly
Contact 1 (800) 204-4427 @ Apple TV Technical Support phone number and get quick assistances through an online help support. Troubleshoot all technical issue for Apple TV. Learn Apple TV Technical Support 18002044427 Number and much more on...
May 09, 2017 | Apple Computers & Internet
My syncmaster 204 bw power button is flahing blue
Your inverter board is faulty. Repair and it might work.
Jan 03, 2011 | Samsung SyncMaster 204BW LCD Monitor
I have Samsung SyncMaster 204, when I turn in on it is completely dark and then gradually begins to brighten. Can this be fixed? Thank yoou ORObles
More likely to have bad caps with bulging top in the power supply, post back what you see inside so we can guide you further, see failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 15, 2010 | Samsung SyncMaster 910MP 19" LCD Monitor
Power Button Light Flickers, wont' turn on
Your monitor has a common problem, the power supply board is blown. Because of the heat trapped inside the monitor parts called capacitors have been damaged. We have a repair guide on our web site for the Samsung 214t series and your 204 is very similar and they use the same parts to repair them. Check out our site at: www.ccl-la.com/badcaps.htm
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Aug 28, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
SyncMaster 204 Samsung monitor has no power
Have you tried to plug it in else where?
If you did and still same problem then from what you said I was hopping that it wouldn't be your problem, but you will need a new monitor.
Mark
Mar 29, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung 204B random blank screen
I too have a dual monitor Samsung SyncMaster 204 setup. My monitors started flickering, then a week later had turn on problems like your describe. I found a fix on this fixya website and followed the fairly techie suggestion. It worked. I wrote up a .pdf set of instructions so others might also benefit. Hope this helps. Doug
Feb 07, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Key is stuck in ignition and car wont start
When the battery is dead, the key cannot be removed. You can either charge the battery, and remove the key or, there is a access panel (small) under the steering column, remove this, and push a small pluger to the left, while holding the plunger, remove the key.
Dec 27, 2008 | 1997 Saturn SL
My samsung Syncmaster 940mw wont turn on when the pc is turned on
Your needs internal servicing by experienced person. Capacitor or ERT may be malfunctioning
May 25, 2008 | Samsung SyncMaster 940MW 19" LCD Monitor
Syncmaster 204 picture fades out after few seconds
Screen control on the fly back transformer may be defective. Replace the flyback transformer.
Apr 07, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Computers & Internet Logo
244 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
