Question about SanDisk Sansa m250 MP3 Player
Sansa m250 Player -No Screen Display after changing new battery
Can anyone help me??? , I have changed a new battery to Sansam250 , but the screen does not turn on at all, or sometimes it turns on and goes off immediately .
  • 8,596 Answers
Get the same brand batteries as the original
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard.
Posted on Jul 06, 2008
SanDisk, 2 GB Sansa mp3 player won't charge
I was having the same problem with my Sansa e250. My wife has the e200, and we didn't have any problems with that. I saw that someone on here suggested to lock the mp3 player with the tiny metal switch on top, so I did, and the battery charging icon on the bottom of the screen came on and stayed on, and the mp3 player worked. thanks!
Because of this I would suggest checking to see if it's locked or unlocked and then change it to charge it.
Jan 16, 2008 | SanDisk Sansa m250 MP3 Player
PC won't recognise player
I had the same problem with the m250. Updating the driver made it work.
Jan 03, 2008 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa m250 MP#
Try doing a hard reset on a Sansa m250:
  1. Turn off the Sansa. Just pull the battery out for a second and then reinstalling the battery without pushing any further buttons.
  2. Plug the Sansa into a computer4.gif, and open "My Documents" in the computer.
  3. Open the Sansa file as if it were a drive, then go to the "MUSIC4.gif Specific storage" file.
  4. Right click the "MUSIC Specific storage" file, and press "Format."
This should hard reset the Sansa m250. This solution has worked for me.
I do not know if this will work on other Sansa m200 type .mp3 players.
Dec 30, 2007 | SanDisk Sansa m250 MP3 Player
My sansa m250 help
click refresh on your windows media player!!
Dec 27, 2007 | SanDisk Sansa m240 MP3 Player
Sansa - sandisk m250 troubleshooting
  1. Turn off the Sansa. Just pull the battery out for a second and then reinstall the battery without pushing any further buttons.
  2. Plug the Sansa into a computer, and open "My Documents" in the computer.
  3. Open the Sansa file as if it were a drive, then go to the "MUSIC Specific storage" file.
Dec 20, 2007 | SanDisk Sansa m250 MP3 Player
M250 sandisk
Dec 13, 2007 | SanDisk Sansa m250 MP3 Player
Frozen
Mine froze in play position, but no sound.
Here's what worked for me. Mine is the Sansa M250
1)Plugged the player into the PC and removed all the MP3s
2)Downloaded update program from Sansa link below
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
3) Install the program
4) Plug the Sansa into your PC.
5) Program automatically starts and allows you to check for software update. Do so and let the program update your player.
Fixed my freeze problem. Player working perfectly now.
Hope this helps.
Dec 05, 2007 | SanDisk Sansa m250 MP3 Player
Failure to swith on
Use the same brand battery as the original - everyone seems to be haivng this problem when switching out the battery.
Nov 21, 2007 | SanDisk Sansa m250 MP3 Player
Sansa m250 is frozen on initializing screen
my e200 does that im sooo pissed it just stays on the screen turns blue than goes back to home screen. i let the batteries run out and the same thing still happens!!
Nov 21, 2007 | Audio Players & Recorders
My m250 won't turn on
Hi. Seems like your M250 is experiencing some system errors that prevents it from either powering up or booting up completely. To resolve the temporary power loss (not powering up even after changing batteries), try this: 1. Remove the battery 2. Press and hold the "Menu" button for 30 seconds. This is to completely discharge the player 3. Insert a brand new battery and try to power it on If this procedure still does not revive the player, try this to format the player and upgrade its firmware: 1. Enable the "Hold" switch on the side of the M250. You would know the "Hold" switch is enabled when the "orange-colored" surface is showing 2. Plug the player in to the PC. (The minimum operating system requirement for the M250 is Windows XP and above). The M250 should be recognized as a "Removable Disk" when browsed in Windows Explorer 3. Right-click on that drive letter corresponding to the M250 and select "Format". 4. Follow the on-screen prompts to format the player 5. Unplug the M250 from your computer, then disable the "Hold" switch. Then try powering it on. 6. To upgrade the firmware of your M250, again enable the "Hold" switch and plug it in to your PC. 7. If you have internet access, then use this link to download the "Firmware Updater" from the Sandisk website: http://www.sandisk.com/Retail/Default.aspx?CatID=1376 Save this to your desktop and double-click on it to run the updater program. Follow the on-screen prompts. I hope this helps. The M250 is a great player. Syd :)
Apr 06, 2007 | SanDisk Sansa m250 MP3 Player
SanDisk Sansa m250 MP3 Player Logo
41 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
