Question about Hitachi 60VS810 60" Rear Projection HDTV-Ready Television
Hello, My Hitachi 60VS810 television went off while watching it yesterday like it would during a power outage. We did not have an outage. After shutting off the blue power led stayed on blinking for a long time. I unplugged the tv for 5 minutes and plugged it back in and hit the power. The lights all come on then go off as usual, but the power light never stays on, it just keeps blinking and after about 10 seconds you can here the tv shutting down again right when it should have a picture. None of the other lights are on at all. Just the power light keeps blinking. I unplugged for several hours and tried it again and it did the same thing. Can you help?? John
techman
  • 3130 Answers
SOURCE: Hitachi 50EX20B Bigscreen TV
You can download a PDF from here: http://www.servicemanuals.net/results.aspx?type=SM&brand=0&model=50EX20B Make sure that the coolant is not leaking out onto the printed circuit boards. i have had the remote sensor cause this problem before and also I have had bad capacitors in the sweep and the main power supplies. Good Luck
Posted on Jun 14, 2007
  • 1694 Answers
SOURCE: will not stay on
RED light is protect circuit = do not disable !
Look for C702 near flyback transformer - might be hidden in
glue = check it = if shorted, replace 102K / 2KV with 3KV =
Sony part # 1-161-754-00 and replace E994 pico fuse.....T.
Posted on Nov 08, 2007
  • 55 Answers
SOURCE: Power button Flashes
the flashing light often shows malfunction ,check the wire connection of your devices something must be wrong .the surge protector you have is for overpower or low voltage too?Ask your neigbours if they have shame problems
Posted on Nov 18, 2007
  • 18 Answers
SOURCE: shuts down after power up 50ux53k bought new 1998
Refer to owners manual will tell you what blinking light means. But at the front not at the back.
Posted on Jan 05, 2008
  • 18 Answers
SOURCE: Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Tv will not stay on
Power board problem. Find a honest TV Tech.
Nov 11, 2013 | Hitachi 60VS810 60" Rear Projection...
Hi, I have a 60VS810 60inch LCD projection and the blue power light flashes but no picture comes on...i just got it for free so i dont know how it worked before..yesterday i did get a blury pic on the...
Flashes of blue light are fault indications. From the number of flashes occurs at one time switch on, you can get an idea about the faulty section circuit board inside. If you wish to get details about these blinks, check this link.
Mar 14, 2013 | Hitachi 60VS810 60" Rear Projection...
I was watching my hitachi plasma tv when the power went off it wont turn on no clicking or any noisy
If you still have led lit on front panel, then you know main ac fuse is good. Check fuses on y sustain board and z sustain board and there will be other fuses in the secondary of the power supply board.
check those also.
Nov 27, 2011 | Televison & Video
Hi, I have a 60VS810 60inch LCD projection. Normally when i turn on the TV, theres a blue led that flashes, and when the blue led turns solid, the screen picture appears. My problem now is that the blue...
It could possibly be the power supply unit or the lamp.The power unit is HA01331. cost is about $120.The lamp is UX21514 cost about the same. Hope this is helpful.
Oct 23, 2009 | Hitachi 60VS810 60" Rear Projection...
Picture intermittently goes dim.
How many hours on the lamp timer?  If 10,000 or more the lamp is approaching end of life and should be replaced.  Lamp will dim when approaching end of life rather than just go out.
Jun 03, 2009 | Hitachi 60VS810 60" Rear Projection...
Power outage.. volume not as loud as before..part bad??
Yes the audio board is going bad there is a capcitor on that and it would need to be replaced.
May 21, 2009 | Hitachi 51F510 51" Rear Projection...
Tv won't stay on
Try removing the back of the set and vacuum out the inside. It should only be a few screws and may even have little arrows pointing at them. Be sure to unplug the set first.
Feb 29, 2008 | Hitachi 60VS810 60" Rear Projection...
No power
Unplug the tv press power on and plug it back in.
some of these units have a reset clearly marked on the back.
connect direct to wall as the surge protector may now have issue.
Jan 27, 2008 | Hitachi 60VX500 60" Rear Projection HDTV
Hitachi 60VS810 60" Rear Projection HDTV-Ready Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
