Question about Boating
Looking for an overhaul manual for MG5011SC twin disc transmission
How do i rebuild a transmission that is not moving forward
First check the fluid to see if it has enough in it.
To overhaul a transmission you'll need some reference material. Check online for transmission overhaul manuals for your vehicle. You can even get the transmission overhaul DVD's which provide a lot of detail.
Jun 13, 2014 | 2003 Toyota Camry
MOTOR HOME WILL NOT SHIFT OUT OF PARK
if you've already tried to do it with linkage removed i think your looking at having trans removed and overhauled sorry can't think of a quick fix
Apr 25, 2014 | Cars & Trucks
My honda fit takes off slow
Is it automatic or Manual transmission?
If it is an Automatic Transmission, that may be a concern on the computer box for the transmission or the clutch lining or ATF.
If it is a manual transmission, try looking into the friction disc or the clutch lining.
Oct 09, 2012 | Honda Cars & Trucks
I have a 99 gmc sonoma that won't go into gear and there is no presure on the clutch pedal it goes straight to the floor but the fluid level is still on full and the fluid has some black looking gunk...
It is confirmed that the clutch hydraulics has faulted. Since there is no clutch the gear links are not engaged. Possible that the master cylinder has failed, possible a leak in the system.
You will need to overhaul this section and the pedal will respond.
Also check on the transmission fluid and the gear settings.
Sep 30, 2011 | 1999 GMC Sonoma
I need the engine and transmission information from the owners manual for my 2005 Haratige Softail Classic. I am in Japan and I need this to get my bike regersetered here. Thanks Joe
The engine is a twin cam 88B, 88 Cubic inches which 1450cc or just about that. That Transmission is a 5 speed belt drive. I think that is what you are looking for if you need more email me at johnamyx@gmail.com. Thank you
Nov 01, 2010 | 2005 Harley Davidson FLSTC - FLSTCI...
Looking for a manual on general overhaul procedures for an old 1979 Webster dual piston air compressor. One piston gets very hot and compressor is quite noisy (sounds like piston slap maybe?).
I have an old De vilbiss twin cylinder air compressor that got noisy. Pulled the head off and found a lot of dirt piled up on one piston (the unit had a very primitive air filter for many years). Scraped the piston clean and washed out the intake passages. Replaced the old filter with an automotive application filter--the compressor sounds like new again. May you have similar good fortune!
Aug 11, 2010 | Garden
Transmission overhauled, however, band overadjusted
Bands are not adjustable. Why do you think it's a band issue? The band only comes on during manual second gear, not second gear while in drive. It sounds like a check ball was inadvertently left out of the valve body during reassembly.
Feb 26, 2010 | Chevrolet TrailBlazer EXT Cars & Trucks
Car wont move in drive orreverse
CHECK GEAR POSITION SWITCH OR MANUAL SHIFT CABLE TO SEE IF BROKEN OR DISCONNECTED.ALSO CHECK TRANSMISSION FLUID LEVEL.MAKE SURE ITS NOT LOW.IF YOU HAVENT DONE A TRANSMISSION FLUID AND FILTER CHANGE.DO IT.IF THAT DONT GET IT MOVING.YOU HAVE A INPUT OR FORWARD CLUTCH PROBLEM.YOU LOOKING AT A OVERHAUL.
Jan 13, 2010 | 2001 Dodge Grand Caravan
No reverse
Automatic or manual transmission?
Automatic= check your fluid. If its low, add appropriate trans fluid.(check owners manual)
If its not low, last ditch might be to add "Trans X". this is a product which can restore enough life to the belts to operate for a bit more. But usually, this is the first sign of the tranny going out.
If its a manual transmission= game over.
Aug 22, 2009 | 1995 Nissan Pathfinder
Boating Logo
46 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
