Question about Culligan Sediment Water Filter
Culligan Estate 2 Model 01010091. Back wash will not stop.
Culligan Estate 2 Model 01010091 back wash will not stop.
  • 10,319 Answers
The back flow filter is clogged. It will need to be cleaned out. When it is clogged the pressure reverses so the valves will stay open to clean without shutting off
Posted on Feb 06, 2010
Where do I find the modle number
You should be able to find it either printed somewhere on the front (such as Whirlpool Combi Heaty Wash) or on the sticker with the serial number on the back of the unit
Oct 15, 2014 | Estate Washing Machines
I'm just a tentant asking a question before calling maintenance. Is the agitator suppose to only turn in one direction? I thought it was suppose to be a back and forth movement. This model is a...
You have a 2 part agitator.
The bottom portion moves back and forth. The upper corkscrew moves clockwise only,pulling the laundry down and around the tub.
Jul 21, 2011 | Estate ETW4400VQ Top Load Washer
Need to reset auto timer for back flushing for culligan model # FA-1054 would like online manual
That model # does not work. 10x54 denotes the size of the tank. Is this a Gold Series, Medallist?
Softener, Filter?
RJ
May 30, 2011 | Culligan 34" Whole House Water Filter...
I have a culligan house hold water filter 950. After I replaced the filter and screwed back in the blue housing that holds the filter, turned the water back on I CANNOT get the blue housing to stop...
Take the housing back off and make sure the seal is where it belongs and before you put it back together lube the o-ring with some o-ring lube this well keep it from moving with the housing as you tighten it up. You can use some other type lube but it should be food grade lube.
Feb 13, 2011 | Culligan Home
Water has been trickling to the drain for at least a couple of hours now, maybe longer. I just noticed it this morning. It's currently in regular run mode and not in regen mode. I put the valve to...
There is a problem with the main piston/sealpack assembly and it needs to be replaced. You can get this kit at Culligan and replace it yourself, if you are handy, it takes about 20 minutes. Replace the refill piston at the same time. Or have Culligan do it.
RJ
May 15, 2010 | Culligan Sediment Water Filter
Culligan 01010091 (mark 89) softener will not auto
clean the drainage filter then it will work correctly again
Mar 05, 2010 | Culligan Sediment Water Filter
My estate washing machine wont drain. I dont know how to get the back off my machine or where the pump is to check and see if sock or something in it
You do not remove the back. The whole case comes off by first opening up the timer panel, then removing 2 clips and unplugging the lid switch on the case. If it runs but won't pump out, then something may be clogging the drain somewhere. If it will not run to pump out, the lid switch is bad.
Feb 13, 2010 | Estate TAWX700JQ Top Load Washer
I need a culligan n8 custom water conditioner manual
The Culligan N8 Custom and Estate 2 water softener systems are basically the same system. Here are a couple links for N8 manual to reset timer and Est 2 manual for other settings on systems that have "DIP" switches to set gallons settings.
http://www.culliganprowater.com/timer-reset.aspx
http://www.culliganwater.com/residential/resources/pdfs/reference/household_and_commercial_circuit_boards.pdf
RJ
Dec 27, 2009 | Culligan Sediment Water Filter
Culligan Sediment Water Filter Logo
1,341 people viewed this question
Top Culligan Measuring Tools & Sensors Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Culligan Measuring Tool and Sensor Expert? Answer questions, earn points and help others
