Question about HP Wireless Optical Mouse
The mouse fell to the ground M-RAF85 from HP and two wires got loose, can I have a diagram of where they should be placed?
2 Suggested Answers
hichbiri
  • 3462 Answers
SOURCE: I'm trying to turn my hp mouse to a usb mouse need wiring diagram
just buy an PS2 to USB converter they cost pennies
Posted on Jul 15, 2015
What is the problem of lP and HP compressor trip immediately after start the machine?
Make sure your ground wire the green wire is not loose and make sure none of your wire are not grounding out tripping the reset button near or around the motor...Make sure your ground wire the green wire is not loose and make sure none of your wire are not grounding out tripping the reset button near or around the motor...
Jun 01, 2016 | Air Tools & Compressors
My headlight fuse blows every now and then, and getting more often. how do I find this and is there a common area this happens on a 2002 electraglide?
Hi Brad, the first place I would look is behind the front fairing, check the headlight wiring harness rubbing against brackets. Then the ground wire connection for the headlight, check for corroded, loose, or broken pins/sockets in the wire connector and ground lug. Next I would check my battery connections, make sure they are clean and tight and check the charging rate, should be 14.3 to 14.7 volts at 2,000 RPM, for a free wiring diagram, please visit the website below. Good luck and have nice day. xlch@mail.com
Harley Davidson Wiring Diagrams and Schematics
Aug 09, 2015 | Harley Davidson FLHTCUI Electra Glide...
The white wire from the plug came loose where does it go? Need to see diagram for wire.
It is the ground wire. If it broke off from the plug, replace the whole plug. There should be a place to attach the white wire to the third round prong on the new plug
Jun 02, 2015 | Filter Queen Majestic Canister Vacuum
How do I wire up a A.O. Smith 3/4hp PB4 Booster Pump for 230V operation?
Here's some more info diagrams for you http://www.electricmotorwarehouse.com/aosmith/AO_CONNECT.PDF L1 is one hot wire L2 is the other hot wire. L1 can not be connected to a L2 wire and L2 can not be connected to a L1. Ground only to ground.
May 27, 2014 | AO Smith 1.5 hp Swimming Pool - Jet / Well...
The left mouse key broke loose on my HP Pavilion dv6-1234dx
Easy fix, no. The fix is to replace the palmrest assembly. The required a large amount of dissassembly of the system.
Work around
Use a USB wireless mouse
Oct 10, 2009 | Computers & Internet
I need a parts diagram for an HP Officejet 7310
Here's a direct link to your model on HP's "part surfer". You should be able to find what you're looking for:
http://partsurfer.hp.com/cgi-bin/spi/main?sel_flg=modinfo&model=OJ_7300_SERIES
*please rate me :)
Mar 15, 2009 | HP Officejet 7310 All-In-One Printer
Can not scroll down or up using the mouse pad. Blue light is on.
Hello spudhansen, Pretty funny that i have the same issue on my HP laptop. what it is the sensor is loose in your laptop. Now you have 2 options a) open your laoptop and reconnect that loose wire or b) http://welcome.hp.com/country/us/en/contact_us.html contact hp and see what they have to say. What i do is just place my mouse on the side bar and scroll up and down that way. If this doesn't answer your problem please post again.
Please post what you do and how you did it. I look forward to your posts.
Nov 11, 2008 | HP Pavilion dv6000z Notebook
Bracket and spring location to reassemble mouse
just buy new mouse, usb or wireless
for $8
or just use it.
2 choices.
10000s of mouse designs there are, good luck finding that level of information.
Nov 13, 2017 | HP Wireless Optical Mouse
Neutral (white) wire connection
Use caution when dealing with AC, it can be deadly.
The black wire by accepted standards is the 'hot' wire and will measure (when active) 110-125 volts (in the US) to ground or the white neutral wire in a normal household system.
The white wire may have a couple of volts when measured to an earth ground or any green (or green-yellow) wire which is (by standards) connected to earth ground, often via plumbing pipes in some homes, or a visible or buried grounding rod driven several feet into the earth.
The black (hot) wire is the one customarily 'switched.'
I would highly recommend you have a qualified electrician reconnect the strayed wires to protect yourself and the fan.
Jul 05, 2008 | Dryers
HP Wireless Optical Mouse Logo
21 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
